Everything posted by Darren Brosowski
Obviously this is not for sewing leather! In part I am posting it here as it shows just how unusual sewing machines can be. I have sold a couple of these to saddlers to experiment with saddle blankets. The full commercial versions sell for around $US2000+ so the Chinese version at $AU415 delivered is not a huge risk.
Trouble Installing Singer 31-15 Roller Foot
Darren Brosowski replied to Daniel G's topic in Leather Sewing Machines
I normally sell them as a full set too. It is not a huge issue. -
Used Consew 206rb or new Highlead GC0618-1S
Darren Brosowski replied to olie's topic in Leather Sewing Machines
Constabulary I have two issues with your post. 1/ Why would you lift up a machine to change the bobbin? On a vertical shuttle machine you just reach in and pull the bobbin case out. 2/ I here all sorts of opinions about the differences between vertical and horizontal shuttles but they are generally both rated for a maximum of M20. The advantage of a vertical, replaceable bobbin case is that it is a lot cheaper to replace when it wears - particularly if you try to push through heavier bonded nylon threads. -
I have a 205-25 here that has the same feed mechanism. The bottom feed is set with the standard lever at the right but the top feed is set independently with the mechanism at the left. This allows differential feed.
I do not push the standard 441 table as it is pretty small and for the same money you can make something like this beast. Everyone has a different idea as to what they want or need.
The problem is that most older machines are second, third or fourth hand old so unless you know a lot about what to look for and the price difference between old and new is significant it is difficult to suggest buying an old machine privately. Generally a good second hand machine would have to be half the new price to justify the lack of warranty and support. Keep in mind I am a dealer so my view may be biased. -
Hi Stropping, I think you contacted me on eBay about the throat plate. Yes it is listed for the 45k1. There are several different plates and the difference between the 91610 and 91609 is the needle hole size. The 98622 shuttle will fit the machine.
I think you will find that the whole shuttle race assembly is clamped into the body and can be adjusted left and right.
Has anyone ordered machinery from Alibaba?
Darren Brosowski replied to tossik's topic in Leather Machinery
nstarleather, I am not sure why you call this a bad experience. Shipping by air is roughly ten times the price so no cheaper overall. As an importer it is up to you to know the costs at your end and that is an international expectation. It is not up to the seller to know or help you with problems at your end. Do your homework. Importers have to make a profit and some of what you are paying for is their knowledge of how to minimise the landing costs. -
You can use a range of binders but will have to drill and tap holes in the machine
Wiz has given you "a" correct answer but I am not sure it is the right one!!!!! Shoe machinery is a very specialised area and you need to be very specific about the question. There are a boat load of machines used to make moccasins; Singer 17 - Seiko TE Singer 18 - Seiko TF Differential feed for the ruffled outsole dual roller for the piping on top compound flat bed for general sewing possibly an insole seamer. As you mention general leather sewing I can only think that you are after a flat bed or cylinder bed compound feed and would suggest a CB227 or similar such as Pfaff 335, Seiko CW8 (LSW or LSC), Consew 227 etc, etc.......
Juki 1541 Cowboy sew equivalent
Darren Brosowski replied to MattG's topic in Leather Sewing Machines
PM me Matt. I am a Cowboy dealer -
Just to clarify.... My earlier post was not to have a go at Keestar as I have done plenty of business with them and they have proved to be very reliable. The machines are generally well set up from the factory and they are very professional. My issue is that importing your own machine is fraught with pitfalls and is not overall cheaper than buying a machine from a local dealer. By Chinese standards the 441 is a very low volume machine and there are not multiple factories making the parts and assembling the machines. The difference is the expertise and support of your local dealer.
Should I buy the FERDCO PRO 440
Darren Brosowski replied to Albob's topic in Leather Sewing Machines
The Ferdco 440 is a GA5/CB105. It is a great style of machine and Bob can help you out with a new one. There are pluses and minuses to these machines which can trace their roots to the Singer 45k series.Simple, rugged and reliable they have been used for leather sewing for over 100 years. They are simple feed so it takes practice and technique to get even stitch length. I am a fan of these machines and sell quite a few as hand crank, treadle and powered. -
Shipping from Australia would be cheaper than the USA and I would suggest buying the head only and using a local table. I would have to get a price as I have not brought in that machine before -
Cobra class 4 sewing direction problem
Darren Brosowski replied to dgkfit's topic in Leather Sewing Machines
Dale, A call to Steve would have solved the problem. Not sure if the machine is new from Cobra or second hand but either way he would help because he wants you to be happy and say great things about his product and service. It is disappointing for any dealer, myself included, to see paople asking questions on a public forum. -
Walking Foot Dilemna: New Compact Or Used Full-Size
Darren Brosowski replied to nascenta's topic in Leather Sewing Machines
If you have the space a full sized industrial is usually the better option. Keep in mind that you may want to fit a servo motor. -
How To "test Drive" A Used Industrial Machine.
There are thousands of machines out there any the 31 was probably only worth $100 to you as a leather belt suggests a very old motor. -
Mate, There is no such thing as too many machines! They all do something slightly different and sometimes one will work better on a certain thread or material than one of the others will. The only thing I would suggest is that you start looking out for something a bit heavier - say a 45k25 or any of that family.
Damp glue can clog up the needle and cause all sorts of problems!
Nippy Skiver Parts In Australia?
Darren Brosowski replied to penguineer's topic in Leather Machinery
The Nippy is one of many copies of the Fortuna so a Chinese part will fit. Nobody here in Australia will have one in stock. email me on darren@ablesewing.com.au and I will get a price for you as I need to get some parts from a supplier in Taiwan. -
Singer 111Wsv65 Info, Please...
Darren Brosowski replied to jasonsargo's topic in Leather Sewing Machines
I have two Singer books that list the needles for some of the WSV models It does not prove anything -
Interesting comment from Bob. My experience with the 335 is mostly with older machines and I have never had a problem with M20 - #138. In many ways it is very similar to the Singer 155/Seiko LSC so I am not sure why it would be limited to #92 - M30 The Serafil should work better than a braided thread so I suspect that either the timing is out a touch or there is damage on the shuttle hook somewhere.
It comes down to what is supplied with the machine. Table, motor and attachments included in the price are the usual difference. The base machine is essentially the same.
