Everything posted by Darren Brosowski
Can someone ID these parts
Darren Brosowski replied to Constabulary's topic in Leather Sewing Machines
The slot looks too rough to be a Singer part unless it is very, very old -
31-15 Roller Foot Conversion--parts don't add up!
Darren Brosowski replied to oxeyenyc's topic in Leather Sewing Machines
There are rubber versions available -
As an engineer I cannot understand why everyone copies the 17 class roller foot when in 99% of applications it goes on the straight sewers. -
There are differences in the body castings between model classes and even by factory and date. The front of the upper casting is different on the walking foot machines to allow for the outer foot to move Some of the 31 class walking foot machines from Kilbowie have more clearance under the head and are able to use the DPX17 needle but the US ones can't. That is only for the later machines (1950+) so I assume they had to make new tooling at around this time and decided to make some changes. Obviously the lower casting varies on the bottom end and there are at least three variations- Small shuttle large shuttle roller feed There are multiple variations -
Serial numbers. Singer issued serial numbers of batches so they do not specify the build date. The machine was built sometime between when the batch was issued and the next batch for that machine type. Usually batches for common machine types such as the 31 would have covered multiple versions as the serial number is just for the class. Every now and then there are batches of serial numbers for 10 or 20 machines and these could represent SV's or a special rush order from sales - we will never know.
I have had a few SV machines over the years and most were early versions of machines that later became standard while others were standard machines with a special attachment. 24KSV - I have it around somewhere - is a standard industrial 24k with an attachment to sew circles. The attachment was designed to sew Powder Puffs.I am going to dig this baby out as a close friend has a design that involves making circles 96KSV7 - 96k with reverse, replaced by the 96k41 133KSV12 - darning machine. Quite common in Australia as they were used to repair wool packs. Later formalised as, I think, the 133k19
Not sure what you mean by the 31-15 "not being designed for" a roller foot. Most machines take any standard high shank foot which includes the roller foot. The special presser bar is the style used on the 31 class roller foot, roller feed machines and while not necessary is more solid than the screw on version -
These patchers were built by a number of companies in Europe, mostly Germany but Bradbury built them in the UK as well as companies in Italy, Switzerland and elsewhere. The "ABLE290" I sell is a Chinese interpretation of a portable version.
Leather belts can stretch a bit over time. It needs to be pretty tight. A 29 should turn over very easily and if it is tight then there may be an issue with the machine.
Could also be as simple as the thread not coming off the top spool evenly
- 15 replies
The original machine in this thread reminds me more of a carpet sewing machine than anything else but the fact that it obviously clamps to a bench ruins that theory
Love the colour of the patcher. I usually repaint them black but a dark red colour could be on the way!!
Not being a sponsor of the site I will not do that but I do not mind mentioning if I have a product that nobody else seems to sell
- 21 replies
- singer 45k52
- singer
(and 2 more)
The feet remind me of the set I sell to do outsole seaming with the CB4500
- 21 replies
- singer 45k52
- singer
(and 2 more)
Industrial Singer 133k8 seizing up
Darren Brosowski replied to kikilamour's topic in Leather Sewing Machines
The bottom shaft is driven by a geared shaft and there are caps over the hears themselves top and bottom. Pull them off, bottom first and look at the grease. It can get so hard that it will jam up the gears. Please do not swear at me too much when you put the top set back together -
Source for 135x16 LR #22
Darren Brosowski replied to Colt W Knight's topic in Leather Sewing Machines
GrayWolf, not every needle type is available in every size. I sell the 15X2 in 16 and 18g because I need to buy 1000 packs of each at a time to get a good price. The supplier makes a 21 but not 22g. Even if they made 22g I would not stock in quantity because I would be wary about advertising them as they should only be used in an oscillating shuttle cast iron machine. -
What is an "Automatic Climbing Device"?
Darren Brosowski replied to graywolf's topic in Leather Sewing Machines
To save $US7k most people will handwheel through and use the presser foot lift if they have to. -
Edge Guides Cowboy / Cobra
Darren Brosowski replied to JLSleather's topic in Leather Sewing Machines
I am not sure if the mounting holes on the Cobra head are done in China or the USA but they are not standard on the 441. Both types of guides have their pluses and minuses but I prefer the bed mounted one as it has a thicker roller. -
Back stitching Biothane Beta w/Cowboy 4500
Darren Brosowski replied to Parott1's topic in Leather Sewing Machines
The material is a bastard to sew regardless of the machine. In theory a compound feed machine when well set up should be perfect in both directions but it does not a;ways work in reality/ -
Biggest problem with horizontal hook machines is that people do not always pull the new bobbin thread through the shuttle spring
Here's a challenge for you guys!
Darren Brosowski replied to sparky20006's topic in Leather Sewing Machines
Would not have guessed on this one. I have supplied blanket stitch machines but they look more like an overlocker -
Hand crank support request
Darren Brosowski replied to beginningsaddleman's topic in Leather Sewing Machines
In terms of build quality I am happy to state that these are the roughest machines ever built. Virtually every part is modified to fit the frame so that the machine will work. On the other hand the bloody things are almost indestructible once they are set up properly. Recently someone asked me to fix one of the machines I sold 6 years ago - they bought it at an auction. Once I cleaned the wasp nests out of the needle bar it worked perfectly -
Buying A Cowboy 4500, Is It A Mistake?
Darren Brosowski replied to Doc Reaper's topic in Leather Sewing Machines
Sorry to hear that Doc. A sewing machine is just another lump of metal unless you use it for its intended purpous.. -
Just to complicate things there is the 7205BV which is an entirely different machine...
