Everything posted by BDAZ
I have started using drum dyed veg tan. So no more stained hands, consistent color, even finish, cuts build times in half, a perfect solution for stained hands. Cya! Bob
http://www.vistaprint.com I just purchased 500 card for $14.95. Cya! Bob
Cowboy 3200 Belt
BDAZ replied to Jess Jones's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I have had very little interaction with Ryan but my experience with Bob was exemplary. There was a minor bug with my machine which Bob immediately diagnosed over the phone and had a replacement part on the way that day. Consequently I had absolutely no down time. Again, I would never order a machine like the 3200 via UPS.My experience with UPS as a commercial customer (we do $30K a year or more) is that I would never trust them with heavy packages. If they break it, it not their fault, they blame it on the packaging, Mine arrived on a pallet and it was perfect! It took 15 minutes to break down the pallet and load it into the back of my Honda then 45 minutes to assemble it. Since it had been just partially disassembled, it worked perfectly on the first stitch. Total freight cost from Toledo to Arizona was around $180. Cya! Bob -
What was the extrusion sold for? I'm a lot closer to Mexican Tire than Canadian Tire. Thanks! Bob
I am also in the wetsuit business and neoprene is available in .5 mil. That might just do the trick but I'll have to find a source that sells in lees than full sheet quantities. Great suggestion! Cya! Bob
Cork is a bit thick though it's an option. I'll take a look at the anti skid stuff.. Might be too rough and mark the leather. Thanks! Bob
I have tried clamps in the past. The way my cutting table is set up, it not possible. I'd have to mod the table, plus I want to be able to cut at any angle to the table. Thanks! Bob
I have a 60" straight edge that's NOT from Harbor Freight. It's well made and painted yellow. I have just switched over to drum dyed veg tan for production and the grain and flesh sides are pretty smooth. When I make full length cuts I ennevitbly shift the straight edge. This happens on either flesh or grain side. Any suggestions for making the ruler more non slip? It can't be too thick or it would interfere with the cutting. Some kind of self adhesive non slip sounds like the best route. Anyone have any experience or suggestions? Thanks! Bob
Next Old Time jam is this Friday. Cya! Bob
I would send it out and have an actual cast made using the lost wax process. Then you can make a stamp out of heat resistant metal that can either be attached to a soldering iron branded or simply embossed into the leather. Cya! Bob
I had mine shipped to a freight Depot off I10 and save a bunch of money. If you want to come over and drool on mine, you are welcome! Cya! Bob
Rather than dip dying, I use a nylon paint brush and a plastic paint roller tray and saturate the item. I get a very even finish and I use a bit less dye than dipping. Any excess is poured back into the container. Clean up is a breeze. Cya! Bob
Dye Gone is just a small amount of ammonia and alcohol mixed with water.I usually mix a little denatured alcohol mixed with either dish washing liquid or liquid soap, The orange cleaners containing limonene are excellent and relatively safe solvents. Cya! Bob
Since it is a switch with each step setting a specific resistance rather than a continuous sweep, it it possible that the minimum resistance available is too high to produce the slower setting you desire. The minimum required to get the machine to move is around 12K ohms so I place a 10K resistor in line which then means the slightest resistance added by the pot will get the motor started. Since it is a log pot, a larger movement of the control is needed to make smaller increases in resistance at the lower end and then towards the middle of the resistance range it evens up. With the current set up on the 3200 as delivered from Toledo, I max out at around 150 SPM. I am guessing that the stock pot would double that, but I have never timed it. So from the above you may be able to calculate what your maximum speed would be with the Bob mod as described above. Plan B would be to replace the switch with a 200K potentiometer LOG (assuming that's your maximum value of the switch) with a 10K om resistor in series. That should give you greater control from 0-25 SPM but still allow full tilt. If it were me I would note what the resistance of the switch on the 4th detent before the last and that is the maximum resistance you need. Since I have no idea what the resistance of each detente is, tough to make any recommendations. Best idea would be to pull the switch and then using an ohm meter, log each detente and graph it. Cya! Bob
http://www.ebay.ca/sch/i.html?_trksid=p2050601.m570.l1313.TR12.TRC2.A0.H0.Xphoto+tent&_nkw=photo+tent&_sacat=0&_from=R40 No shortage here! Cya! Bob
I am guessing that a log pot of the same or slightly lower value would work much better than the switched resistor array you currently have since it's not a continuous range of resistance. With your foot on the pedal, how many clicks does it take to start the motor? Cya! Bob
We met in Prescott. Sorry to hear about the shoulder. I injured mine in a bike crash a few weeks ago and lucked out as it turned out to be a seperated shoulder, not then torn cuff they diagnosed in the trauma unit. It amazing how we take shoulders for granted till they go South.. Good luck and have a speedy recovery. Bob
I made a strop board with various widths of very thin strips cut from 5/6 oz leather. The thinnest is 3/64th and goes up from there. I put a thin bead of white cement on a paint stirrer and place the strip grain side down making sure it is both straight and vertical.I have 1 pair of 3 different widths, one using green and the other white rouge. I draw the tool towards me at the angle I would be pushing and there is a noticeable cutting improvement. I strop with the white abrasive prior to every use.I have some very fine needle files but have never had to use them on this tool. Cya! Bob
Do a search on vinegaroon. This is not a dye but will change the tannins to a jet black in seconds or minutes. You make it your self from steel wool and house hold vinegar. I often will dip dye and the solution penetrates the leather completely. Some folks suggest neutralizing with baking soda but I generally use saddle soap and then oil with olive or neatsfoot. Cya! Bob
This mod will not change the performance of the motor, just allows a more accurate control of the maximum speed. Do you have to turn the switch all the way to achieve full speed or does it happen in the first 25%, 50% or 75%? Based on that answer it would be possible to substitute a control that has more control in the lower speed but will still give you the maximum you need. What is the maximum speed in SPM? Cya Bob!
Let me know what the "switch" says. It should be plug and play. Look at the connector where the switch plugs into the board. Cya! Bob
It's tough to be a photo tent for cost ($11.00) and foldability I sometimes put it on a piece of perspex and light from below as well. This one is 17" on a side. Cya! Bob
It can minimize stretch but not strength since you are perforating the leather to a lesser or greater extent. Cya! Bob
What's This Engraving/carving/dying Technique Combination?
BDAZ replied to Matani's topic in How Do I Do That?
Looks like standard antiquing on a carved image.. Cya! Bob -
This is the final configuration I have come up with. A slight turn of the knob (with the pedal fully depressed) will run at around 16 SPM and fully turned counter clock wise the maximum will be will be 150 SPM. This is a range I am completely happy with. If there is any interest I can order a bunch of jumpers, resistors and potentiometers so you can just swap out the existing pot. I will be putting shrink tubing on the exposed parts, this is just to show what it looks like. If you are handy with a soldering iron you need: 1 x 100k 1/2 watt Log (or Audio) pot with a 1/8th split shaft +-$2.00 1 x 10K 1/2 watt Resistor +- $0.25 1 x JST 2-Pin M+F Wired PCB Panel Battery Connector,JC2 +- $0.50 I'll be sending one to Cowboy Bob on Monday and he can try it and see if it's worth the effort. The mod involves removing the 4 screws on the motor housing plus loosing the pully cover and allowing the housing to drop free. Carefully pull the connector that runs from the speed control to the board. I believe it is marked JP2. Pull the knob off the pot and then loosen the nut and remove the pot from the cover. Plug in the new connector noting that the ribs go into the slot on the connector. Push in firmly, replace the pot and turn fully clockwise. Replace the knob so it indicates 0. Replace the housing and reinstall the 4 screws then re-tighten the pulley cover and you are ready to sew. Excuse the crappy soldering but I was in a rush to get this done and back to sewing! Cya! Bob
