Everything posted by BDAZ
I hid a snag on a one piece strap I am making. The very end of the strap, which will be stitched into a loop is a lot spongier than I had initially thought. Must be from the neck as the strap was cut along the back. I can't reinforce the area with another piece of leather as the thickness of the leather at the loop is critical. I could possibly glue some fabric as a reinforcement and to prevent stretching or possibly use some liquid to strengthen the leather..but not sure what. Worst case I'll use cordura but I wonder if anyone has any ideas? Thanks! Bob
Consistent Way To Punch Sewing Holes In Leather
BDAZ replied to NewYorkerInSydney's topic in How Do I Do That?
http://www.use-enco.com/CGI/INSRIT?PMAKA=890-8803&&cm_mmc=Didit-_-SEM-_-GglProd-_-GglProd&003=18299132&010=890-8803&gclid=CO3w8PG2sb4CFYlafgodO0IASA Cya! Bob -
I don't get what the 2K pot in series is doing for you. unless you are using that as a fine adjustment once you have the 100K set to an approximate speed. I did a very crude test and figured on my system (remember it's also about pulley sizes) 60 SPM equates to around 60K Ohms. I like the idea of moving the pots off the motor and accessible without sticking one's hands past the belts and pulleys. For those who are analog challenged here's a chart: When I have the log pot installed I should get 50% of the knob rotation controlling the first 10 ohms, so I doubt the second pot is necessary. It would be with a linear pot. Such a simple fix for a significant issue. Cya! Bob
You can use an arbor press. This one has a hole drilled in the ram. A 2 Ton will have enough clearance to use your current tools. For hand stitching I always cut a groove and that keeps the pricking iron straight and keeps the stitches below the level of the leather. Cya! Bob -
Barge is used by shoemakers and seems to be a better adhesive than either Weldwood or the Tandy version. Cya! Bob
Assuming you are gluing to the outside of the case, I would first clean the case with acetone and remove and mold release then I would really rough up the surface with a low grit paper or wire brush. The I would use a high solids solvent based cement like barge cement coating both sides and allowing to dry to slightly tacky. Cya! Bob
But think of the thousands of lawyers that would be pan handling at intersections, clogging up the homeless shelters and wolfing down welfare. Tragic! Bob
I'm not concerned about going fast. I want to max out at 60 spm and have the full range of the pot cover 0 to 60 ONLY. Thanks! Bob
Found the problem! The pot is a 220K Ohm linear pot. The machine is off when there is zero resistance. When I crank it to the maximum that I would eve use, it's around 80K ohms. So that's the answer! Replace the 220K ohm pot with a $.99 log taper (for testing) 100K. If I get the range and speed curve I am interested in, I'll invest in a better pot. The pot is plugged into the board using a standard Molex connector, so one could conceivably have a 20K 60K and 100K and simply plug and play. I have ordered a couple of pots and will install them when they arrive. I have just ordered the pots and connectors and I'll give it a shot. Cya! Bob
The pic s not my machine but one off the net. I assume I also have a 2" pulley. I'll try to take a look this afternoon. Cya! Bob
THis shouldn't be rocket science. I spoke to Bob the younger, and they are not aware that there is an issue. I'll oopen it up when I have cleared my back log..Any chance of getting hold of a schematic? Cya! Bob
Welcome! Just said hello to the new member from LA, where my daughter goes to college at the University of New Orleans. My son goes U of South Alabama. My next rip East will be to New Orleans then Mobile! ... As I mentioned in my last post, you will find someone who knows something about almost anything leather. Cya! Bob
Welcome! You'll find someone who knows something about most things leather on this forum. Last time I was in your neck of the woods, did some kayaking on Bayou Teche.. My daughter is at UNO. Cya! Bob
This is the servo motor I have on my 3200 and I believe it is the same as the one on the 4500 as well. I have running at around 60 stitches a minute maximum but to get there I just barely nudge the pot from it's zero position, I would like to get more control over the lower end of the range but the pot is way to sensitive and just a touch makes a huge difference in speed. I have not seen the schematic of the motor but it sure seems the pot is wrong for this application. Has anyone replaced the pot on their servo? It seems that the pot is probably linear and should possibly be a log type pot. Here is the motor: Thanks! Bob
I've used Legal Zoom to set up an AZ LLC. Piece of cake! However, be absolutely sure you follow the annual requirements to the letter or you give the lawyers a crack to crawl into cockroach style. Cya! Bob
Cylinder Arm Table Attachment That Converts To Flatbed?
BDAZ replied to mcfingrs's topic in Leather Sewing Machines
I think you will have to have a custom table built. Nor rocket science and you can use the existing holes. Possibly one of the vendors like Toledo can make one for you. Cya! Bob -
My 3 knives arrived this afternoon and all appear to be quite sharp and well made and certainly worth the $19.95 each cost. The speculation that these were made by children is ludicrous! While they are probably not of the quality for a hand made knife by one of the well known makers, they will do the job they were designed for at a fraction of the cost. Once I become proficient with these knives I may purchase a high quality US made one if it is justified by useage. Cya! Bob
Taking Payment With Smart Phone Card Readers
BDAZ replied to camano ridge's topic in All About Us and Off Topic
I have been using Bank of America's system on my droid phone and tablet with great success. One of my out of state vendors uses Square for tens of thousands of dollars worth of my transactions annually with no complaints. Cya! Bob -
Here's a technique I came up with yesterday when I was trying to transfer a design. usually use Stapes "Vellum" paper which is translucent, tough and goes through my laser printer with no problems. I couldn't find it and was in a rush so I printed out the design in reverse, taped it to leather then saturated a piece of paper towel with acetone and rubbed the surface. TaDa! The test example is on a piece of scrap and each character is 1" high. The actual piexe is double sized. The lines were completely eliminated by the cuts and beveling. Cya! Bob
- 12 replies
- tooling
- carving transfer
(and 1 more)
My local sushi bar is the best in the area, owned by a Japanese guy and nice folks. The treated me like royalty on my birthday and I wanted to repay the gesture so I thought I would trow together a pen and pencil holder to replace the ugly one (a coffee mug) on the bar. I thought it would be a good opportunity to learn to make a cylinder. The back is stitched with a cross double bar stitch. They loved the holder and they gave me a free sake! Comments and criticisms welcome! Cya! Bob
