Everything posted by BDAZ
You need to have the specific model of the gun and barrel length. Cya! Bob
I have a number of these in stock. They are all professionally labeled with glossy paper labels. As someone who manufactures a liquid product, these bottles are professionally labeled and these labels are NOT going to come off . The labels are die cut with rounded corners. The dye is sold in a standard 1 quart "cylinder round" containers obtainable anywhere. So you may have counterfeit product, either decanted from larger sizes or not Feibings. Cya! Bob
Check Out Home Depot or Lowes. An inexpensive method for apply stains and dyes. Use the glass bottles for storage. You can mix the stains with water or denatured Alcohol depending on the product.
You could ask her to purchase a blue gun of the appropriate model: I don't think it's illegal (yet) to own a plastic gun in the UK?! Plan B would be to find a toy revolver that matches her gun and ship it over. Not sue if there are many available in the UK. Update: http://www.ebay.co.uk/itm/New-Blue-Gangster-Police-Shoulder-Holster-Toy-Revolver-Bond-007-Spy-Gun-P2147-/370988538593?pt=Adult_Fancy_Dress_UK&hash=item5660a3dae1 Cya! Bob
Really interesting stuff WS. I seem to remember reading in a Stohlman or similar book that it was called a camouflage because it would be used to hide the guideline around the edge of a piece. Cya! Bob
- 7 replies
- camouflage
- camoflage
(and 1 more)
My Cb3500 Arrives This Week. Now Many Folks "have A Project" For Me...
BDAZ replied to Tallbald's topic in Sewing Leather
As you mentioned in your other thread you don't expect free hamburger. I would take the approach of say that you will make what they require, as long as it's within your range of interests, for time and materials. That way you are making a few bucks, practicing and learning to make commercial products at their expense. I would call that a win - win. Of course if they want free, then tell em you don't do free, but there are some really good , inexpensive leather makers in Beijing... Cya! Bob -
All the above is correct.THey are designed to give you protection while you file for a full patent or find a buyer for the design BUT for $300 they allow you to state patent pending followed by your assigned number. This may or may not be a useful marketing ploy. Cya! Bob
Thanks!! Cya! Bob
Thanks Tom. We already tried an element based set but the unit is too unwieldy for fine detail and the tip heat is not constant enough. The wire tipped pen style is the only viable option. Cya! Bob
The Razertip has an extra pot to set the lowest heat setting, not affected at the higher ones. The tips run at two volts so I assume they are changing the amperage of the circuit to control the heat at the tip. The tips are nichrome wire. So one would probably have to reduce the amperage to the tip of alternative units to get lower heat settings. I have been unable to find a schematic of any of the burners... Cya! Bob
I have searched the archives and I can find nothing current. My assistant is a very talented illustrator and I want to buy a pyrography setup to take advantage of her talents. The Razertip seems to be the only one advertising a special low setting for leather work but they are the most expensive. There are others on Ebay that are less expensive but without the extra heat control, which is probably just an extra pot in the circuit I could probably wire in myself. What are the recommendations of the pyrographers on the forum? Thanks! Bob
I have seen a few 3D stamps and alphabets that have been damage by being pressed directly on the round fitting with the ram. The rams foot is cheap and effective, giving much greater surface area for the press. Cya! Bob
If you like the look you can obtain "splits" , the leather left over when thicker piece is split to make a thinner one. This is usually much cheaper than tooling leather and is stiffer and smoother than suede and could wear better than the flesh side of tooling leather, depending on how it's been split and finished. Cya! Bob
I use a rotary cutter, which I strop regularly, for suede. Cya! Bob
The difference is that someone could walk in and drop off an ounce of pot for a custom pouch in CO and you wouldn't have to worry about it. Here in AZ, we'll take the gun instead. Of course your concern about receiving a damaged gun can be covered by a waiver and an arrival inspection. If it's an interstate shipment then the FFL can provide an independent inspection coming and going. Of course that same problem could happen with any article, shipped to your premises for fitting. There's always a few bad apples out there but I can't believe it is a regular occurrence in the holster trade... Cya!
The steel wool (iron) in the vinegar (acetic acid) produces ferric acetate which reacts with the tannins in the leather and turns them black through a chemical reaction. It is NOT a dye as the solution is the color of tea and the reaction is almost instantaneous. Ferric Acetate can be purchased but it is very expensive. I have heard that the less expensive ferric nitrate will perform in a similar fashion. Cya! Bob
I am a former FFL holder and I don't believe you require one to take temporary possession of a firearm for either service or other purposes, however, depending on the weapon and your state, there may be regulations that you would transgress. BUT, this is Arizona! As long as the weapon is not crossing state lines, and being hand delivered to your premises, there shouldn't be an issue.I shipped a gun to Ruger in Prescott last year via UPS which they returned also by UPS. No FLL involved. BTW I was in Glendale yesterday..stopped in at Cabellas. Cya! Bob
What Rubber Pad And Where To Buy For Shaping Holsters
BDAZ replied to Wizcrafts's topic in Leather Tools
I did some work in carbon fiber fabrication and the setup we used is a vacuum table with fine perforations and then we simply lay a sheet of plastic over the item and it exerts a lot of pressure removing all excess epoxy producing a stronger item. If you were looking for a flat backed holster, I believe you would have significantly higher pressure than a simple back like device mentioned earlier in the thread. Cya! Bob -
I have been using one commercially for the past couple of months and it sews like a champ. I make leather cases, belts and straps and a great bang for the buck! I bought it from Bob at Toledo and their support was excellent! Cya! Bob
The key to this quandry is are you investing in a business or in a hobby? If it's a hobby being run for your own enjoyment and to recoup some of your material costs then you should keep your investment to a minimum and make a few items that you enjoy making. Figure out what will sell at the local craft shows and make things that you like and folks will buy. Your time is less important that saving money on tools. If you are setting up a business then time is money and you need to develop a product like that you can make efficiently and sell profitably. Time IS money and any thing you can do to minimize construction time while maintaining product integrity is worth while investing in. I recently went through this exercise and I have around $5K invested and just hired my first employee. I am not in it to make a lot of money, just to keep the overheads paid, cover my employee and eventually cover my investment. The biggest single investment was a CB 3200 with all the bells and whistles. Remember that your 3500 will always retain some value if you ever need to sell it. I used to work in the wine industry in California and the joke was "How do you make a small fortune in the wine industry? You start with a big one!" I suspect the leather industry is very similar. Cya! Bob
If you feel there is anything unique about the item or the manufacturing process you can apply for a provisional patent, which will cost $300. THis will give you the right to use "Patent Pending" and should let the customer know that you are private labeling a patented product. This should keep him honest yet give him the incentive to market and promote your product. Ever run into Roger Siminof in Ojai? Makes mandolin stuff. Cya! Bob
