awharness
Everything posted by awharness
  1. Im intersted in this machine, would you be willing to ship? andrew@awharness.com
  2. Do you still have this machine for sale? -Andrew
  3. Sold, Thank you!
  4. actual foot print of the machine is 24x24 by 52" high, weaver says crated weight is 250... I can lift it by myself though. zip code is 03446 I can put it on a skid, wrap it. box it fork it drop it off at a terminal too! let le know
  5. hey! I just saw this I will look into it today! its not super heavy thought
  6. I have videos if this machine working if anyone would like them I can email them to you!
  7. I have more pictures and videos if anyone wants I can email them to you!
  8. This machine is slick, paints both edges, or single edges, look it up on YouTube! They’re priced new at $4,350 this machine comes with extra foam rollers! Asking $1,750 in NH, can help arrange deliver
  9. bought this machine in March ‘20 it is a Sewpro top and bottom feed skiver. It has two motors, the blade is run continuously off one motor, and the second motor is a servo that runs the top roller feed and the bottom feed. Works flawlessly on veg leathers. This is the correct way to set this machine up! Sergey from Sewpro knows his skivers! I used this for one project, I’m changing my work around need the room! Set up on K leg stand, standard sewing machine e top. Shop around, compare apples to apples! This a a deal at $1,950 in NH may be able to help with shipping
  10. still looking for equipment? I have just about everything you're looking for, and im in NH -Andrew
  11. I understand that, what is most common for carpets? Looking for FAA approved binding for this exact application.
  12. What size binding tape does this binder use? what has everyone used? Poly? Cotton? Sunbrella? Looking to do some carpet applications -Andrew
  13. I just bought one from Sergey at Sewpro and its the top and bottom feed style machine. He adds second continually running motor for the blade, then the feed is off a normal servo sewing machine motor, makes so much more sense, I wouldn't have wanted just the one motor to run all of it!
  14. I have a standard rivet #2 one that i would sell that's on a base, but i'm all the way in NH. but id want to sell these "Bowtie" browband chain links, and dies that I have. Bought 1,000 chrome and 1,000 brass. I have the loop iron and driver part as well as a bag of ss powder coated black staples -Andrew
  15. I could use one of these for my 205!
  16. I have a Fipi FP20 which is giving me some trouble. I took the off the back of the head and the switch isn’t wired, and there are spare and extra wires. I was wondering if anyon can send me a picture of the back of their machine, or you have a wiring diagram. I’ve called around with no luck! Thanks InAdvance andrew
  17. What model Fipi? FP 20 by chance? I need a picture of the back head of how a switch is wired if it is! If you can help me out that would be awesome!
  18. I can’t get the timing right on my juki 341, does the tip of the hook cross the flat spot on the needle on the way up??
  19. I have a juki 441 also, plus I have a juki 341 that Ferdco did over as a 808 (I think) base machine is great, and ferdco did a good job setting them up. You can adjust for all the different feet, feed dogs, needle plates ect. Servo motor would be a well worth it investment, fair price id say
  20. Looks really nice! I’m assuming you cut all the curves free hand? Raised the patent on the drops and the breaching top? Did you use tufting on the saddle? You didn’t cut any corners on this one! Where are you getting your patent? -Andrew
  21. Hey Don, I sent you an email
  22. Beautiful machine, how much does the head weigh crated up?
  23. What’s the needle plate that’s on the throat plate, next to the machine on the table?
  24. Do you still have this machine for sale?
