retiredff
  • Content Count
    277
Everything posted by retiredff
  1. A good resource for blue jean material is good will. Heading there now... THX for the tip.
  2. I know this ia an old thread but: I most likely have most of these for sale on eBay now. Just look for VTG Craftool pre '64
  3. How hot is just past non-magnetic? Can I do this with bottle LP torch?
  4. retiredff
    New Tools
    great idea with the turnbuckle, I will steal it!
  5. retiredff
    Stamps
    There is a set on ebay now that is with another set of regular alphabet stamps! The bidding ends SOON (less than 18 hours from now) https://www.ebay.com/itm/VINTAGE-lot-of-2-CRAFTOOL-LEATHER-1-2-HAND-STAMPING-SETs-8142-8130-alphabet/112659985487?hash=item1a3b0ef44f:g:3ioAAOSwk~ZaHEHS
  6. I search ebay for french edgers. I look for the widest I can find and they work great for skiving when sharp.
  7. You may have been the one that wrote the comment in post I asked about. I have some rusted tools I'll experiment with.
  8. Saw this on tube. To print out a tooling pattern and print it on tracing paper at the same time to reduce a step; Use rubber cement or a light holding glue and attach the printer paper to the tracing paper for support, I suppose you could use heavy card stock as long as your printer will handle it but both pieces must be the same size or trimmed. Then print ON THE TRACING paper your pattern, separate the 2 papers and transfer your pattern to your cased leather the usual way with a stylus.
  9. That looks really good. I have not tried just the antique paste. Good idea!
  10. retiredff
    Stamps
    I see them on ebay occasionally. search for craftool alphabet stamps
  11. I have 2 knives from Terry Knipschield, the French model and the pull cut model 1. Both are really nice knives and really sharp!
  12. Does anyone make a 3/32" angled lacing chisel with more than 4 teeth? Google gave me nothing. Thanks
  13. Personally I don't like the matting tools. For their size they can't reach into tight places so that limits their use.
  14. When would the backgrounders, bar grounder and matting tools be used? Is it personal preference or is there a standard? Thanks I found this: anyone care to add more?
  15. Hello, I read a post by someone here that said " To improve the impression of most Craftool stamps grind the hammering end flat". After looking at mine all of them are domed shaped. Has anyone tried this? Thanks Tony
  16. Tom- I don't like the glue tape either but if it holds everything together especially on a large piece like a bag it might be worthwhile. Thanks for the reply.
  17. I don't think I have read this anywhere. Is it necessary to use a strong adhesive like weldwood or barge before double loop braid stitching a wallet or anything with a front/back pieces? I have 1/4" double sided sticky tape.
  18. Knothead - the finished rope/cord should be around 1/4" in diameter.
