Everything posted by dirkba
Hi, I have found this in my archives - it might help to achieve a pattern of your own choice. Rifle slip.pdf Pattern formula rifle slip.pdf
Hi, The canvas was salvaged from an old military canvas bag - just cleaned it up. Its pretty simple. 2x 320mm diameter circles and a rectangular piece of canvas 600x1100mm. It could be 500x1100, but I won't go any shorter. Fit pockets according to "scale" and the leather trimmings is done with scrap leather.
Hi Ashish, Here is the follow up to my first attempt...tried my hand at making a canvas leather duffle. I still need to attach handles and a zipper!
I came across this guide for leather belt sizes - perhaps it may help! Dress Belts size chart.pdf
Fully adjustable rifle sling pattern?
dirkba replied to jesters1's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I have made one (using webbing belt) similar to the army slings, but it is used with your arm going through the loop and set to assist you in shooting while standing. Your stability is achieved from the sling forming a tri angle with the rifle and your forearm pushing against the front stock. Check out "accu sling" for more options! -
Hi, I am no expert, but having read a few articles on this topic for a 1907 bayonet scabbard I want to make, the common technique used seems to be by using fine sandpaper on the leather. Applying rubbing alcohol, with a spray bottle, on damp leather will dry the leather out and give it a faded look. A wire brush will also help to distress the leather before you start applying any oil. I would apply the above to the leather before I START THE PROJECT AND ONCE THE PROJECT IS DONE you can focus on the areas that would normally take the most wear and tear. Good luck with the project
If this is an Australian pepper tree stump its probably not the best choice for a stump...the wood is likely to crack no matter what you do. Walnut or eucalyptus wood makes a very nice stump! I would however try and force a metal hoop around the top and as it dries force the hoop down and let it settle at about 4 - 6 inches from the top. If the stump cracks the metal hoop will hold it together. Good luck with your project!
Most Fun I've Had in a Long Time
dirkba replied to Sofaspud's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Spending time with the grandchildren...priceless!! She must have a good tutor -
Whether you would have won or not is irrelevant...!! You completed this "master piece" - so you are a winner!! I wish my skills were that advanced. I like it a LOT!!
Wheat pasture doctoring bag pattern
dirkba replied to T Moore Medicine Hat Saddlery's topic in Patterns and Templates
Thanks fredk - I looked it up and was pleasantly surprised to see the original Gladstone bag was made by J G Beard...now for the co-incidence my surname is Baard. If translated to english means beard...don't know if there could be a connection here!! Wulfing look up this thread if you want to see how the bag was reconstructed. http://www.threadsmagazine.com/item/44990/how-to-make-a-fortuny-gladstone-bag-part-1/page/all It is really great looking, but seems a challenge! -
Hi Wulfing, It is called a doctor's bag and dates back to around 1910 - according to this website https://www.la-belle-epoque.net/english/e_bag_0007.htm -
Fischer Workshops Designer Tire Bag
dirkba replied to cicftaiwan's topic in Motorcycles and Biker Gear
What hide did you use...looks like springbok! Amazing piece of work!- 9 replies
- messenger bag
- fischer workshops
- (and 11 more)
Don't know if this would help...or if this is the type you are referring to. I had to replace the handle on this one for a friend and took a few pictures for future reference. The most difficult to find is the hinge - they are expensive!! -
Distressed/aged checkbook cover
dirkba replied to Chrism's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Hi Big Sioux, Thanks for the info and I am blown away...just could not imagine that check book covers still have a meaningful purpose - and for that I'll gladly "pay my way forward". Let me have you postal detail and I'll send you my prized African Buffalo hide check book cover (no longer used), when an acquaintance from Texas visits in March! -
hi, Just curious...who still uses check book covers in the electronic era? -
Need help securing bullets to a hat band.
dirkba replied to Reverse2057's topic in Hardware and Accessories
Well done ...it looks great! -
Guest Bex, I don't want to blow your bubble...but you may want to rethink using elephant for a laptop bag. Specially if you are going to carry it as a sling bag. I made my wife a bag a few years ago...ended up selling it as a shotgun shell bag. The leather was a bit harsh on her clothing. If you make it as a hand carry bag - no problem! Just my 2c
Tony RV2 - I am with you on this statement! The currency is not in my favour nor is the thought of importing a head knife! So I decided to make my own from a circular saw blade. It is functional and works like a charm
Work in progress Leather Waistcoat/Vest
dirkba replied to Windrider30's topic in Clothing, Jackets, Vests and Chaps
Good luck with ALL the stitching and lacing - you sure have a lot of guts. I have a similar vest, but used real thin leather that I was able to sew. For effect on the pockets I used small spring buck (female) horns and the "sides of the leather" which had rough edges. Don't lose steam...keep going! Once you wear it there is no looking back - just smiles -
Misinterpretation... Bullet by definition: - a metal projectile for firing from a rifle, revolver, or other small firearm, typically cylindrical and pointed, and sometimes containing an explosive. As the reference "bullet" was used I thought the pre-fired shell casing would be capped with a projectile...to make it look like a real bullet! -
Pop rivets or "blind rivets" is definitely the way to go. Make sure they have a good size flange - so they don't pull through the leather headband. You could use a relative small rivet with a washer between the flange and the leather, but everything ads weight and the .357 bullet is already heavy, depending on the projectile weight (normally 125gr / 158 gr). A few of those on your head is going to be noticed....not only in looks but the wearer will feel the added weight!
