Everything posted by billybopp
Accurately cutting "stretchy" leather.
billybopp replied to Shadders's topic in Leatherwork Conversation
All good advice above, I've used all of them. Another thing to consider is that the leather needs to be relaxed before you start cutting (no no .. not like give it a cup of tea and a comfy chair relaxed). What I mean is that you'll want to lay out the leather flat and not at all stretched nor compressed before you start cutting. It's tempting to pull it taut to make cutting easier, but that will cause problems down the road as it shrinks back to size. - Bill -
@AtomicLeather You are correct, the stamps and roll embossers are bookbinding tools. They're even more expensive than most leather working tools from what I've seen!! - Bill
Depending on the embossing height, if high enough I'd use a combination of layered leather bits to get up close to the level needed then dust goop for the final shape. The main difference is that using just stacked leather, you then have to remove leather to get to the final shape, sort of like whittling wood it's a subtractive process. Goop is more like working with clay, you pack it on and then move it around to get your shape, more of an additive process. I haven't done anything practical with either as I'm a crap sculptor but I did play around a little just to see what it's like several years ago. - Bill
I'm not going to make a joke .... I'm not going to make a joke ... I'm not going to make a joke ...
According to the parts books like it's an "Oil Regulating Screw" - whatever that means! - Bill 255RB-3.pdf Consew255RB-3 parts & opermanual.pdf 255339LSW2BLLSW28BL.pdf
Thanks again Dwight, but no. It's toast. The laptop fell from a table while powered on. I opened the HDD and there's a hard physical crash on the disk surface. I've recovered drives from a minor head touch, but this one you can see bare aluminum through the substrate. - Bill
I've heard that stamp called "Crazy Legs". They do make a really cool looking pattern. - Bill
Thanks for the offer Dwight! Sadly, I don't have the plastic and the drawings were lost when my laptop HDD crashed. Lost a lot of good stuff with that crash including some leather designs that I was working on. - Bill
I made a bigger jig like this years ago, out of thick plastruct plastic sheets, and used chicago screws as the pivot points. To make it a little more versatile, I sized the centering holes the same size as the other holes, and with a couple more screws that allowed me to add a third arm in the center which can be exchanged for different needs, exactly the same length as the ones at the edge. Need extra small belt holes? Make a center arm with small holes that fit that small punch. Need an oblong for the buckle tongue? Make a center arm, use that oblong to punch the plastic the right size and orientation and your oblong is centered and as straight as you were able to make get the plastic. You can also make a couple of holes in the edge arms and add a stiff wire pointer to set up hole spacing to help you move the jig the right distance for even holes. I took the idea so far as to put the design into cad software with a measurement scale on the arms to assist with spacing, and some accessories with the intent of having it laser cut in some nice clear plastic! Unfortunately, before the laser cut folks could get to my project, they went out of business. So, for now - my old jig still works even if it doesn't have all the niceties. - Bill
I can hear the OLD Mountain Dew jingle in my head ..... Good work!
Would something like this work for your needs?? They come up from time to time on eBay and such, although usually missing the blade. https://www.ebay.com/itm/187610770315 -Bill
For the most part, you wouldn't want to split anything wider than 7-8 cm in any case. At that width it gets VERY hard to pull the leather through. I have a small Tandy splitter, and the widest I ever split is 38mm for belts, and that takes a LOT of hard pulling to get through even when the blade is freshly stropped. - Bill
I used to homebrew beer using the same sort of carboy. To make handling it easier, I bought a commercial handle that clamps to the neck. They cost about $5 at the time, probably more now. I also made a carrier harness using nylon straps. Not at all hard if you've got a sewing machine, but it would be a pain to sew by hand. Another type that I made had a double-purpose. I used some old terry-cloth bath towels to sew a bag that covered the whole carboy, sewed on some handles at the top, and closed by a draw string around the top. Beer is light-sensitive, so the cloth helped with that and additionally, put the whole thing in a big tub of water. Water wicks up the towel and evaporates to keep the temperature several degrees below ambient. As for the wicker basket, it's very cool looking! If you have materials and skills it would be great to keep or replicate, but that is certainly beyond my skillset!! - Bill
I Used an Automaker's Emblem on a Key Fob. Did I Do Wrong?
billybopp replied to Gosut's topic in Leatherwork Conversation
Remember back in the day, when you'd get a keyfob with your license # on it, and an address where you could mail them for free return service? Times have changed! LOL - Bill -
Put a couple of notches on that strap, about 1/3 to 1/2 the width of the leather, at an angle, and somewhere around where the widest part of the pipe bowl is, and it could probably also serve as a cellphone holder. I hope that description is good enough!! I can see it in my head, but putting into words is not so easy. - Bill
He probably needed all those bullets to help make him look more regular sized - He was nearly 6'7" tall!
My first rock concert was Ted Nugent in 1980. We rolled down the windows on the drive home, and it took a minute or so to realize we couldn't hear any wind noise! I'm convinced my hearing still isn't entirely back to what it was before! Does that count?? -Bill
It can take several runs of clean water through an airbrush to clean it. Clean immediately after using the airbrush. Dyes usually have alcohol in them as a carrier for pigments, and alcohol can degrade o-ring seals in the airbrush over time. A little isopropyl to clean the airbrush is fine, but again - don't let it sit with it in contact with rubber parts. Dye sitting in the airbrush works can evaporate quickly, leaving pigment behind. What I usually do is clean immediately after use with alcohol, followed by water. If the airbrush is to sit for any length of time, I disassemble it and use an inexpensive ultrasonic cleaner with water and a drop of soap to clean, then put the parts out to let them dry. If the above cleaning tactics don't work, you may need to use the ultrasonic bath more often. - Bill
One of the reasons I've always preferred to do as much of the maintenance on my cars as I could manage is that professional mechanics have nearly killed me twice. Once was a 1976 Ford Fiesta (a BLAST of a little car to drive!). I was in college and didn't have time to replace rear brake shoes, so took it to Ford - I even warned them that the adjusters were finicky on that car and had to be manually adjusted pretty tight. They didn't listen. On the drive home from the dealership, a semi pulled out in front of me on a two lane road, and the brake pedal went to the floor. Fortunately, I managed to slow by downshifting, and there was just enough berm for me to get over on. But my hands were shaking when I got home. The other was a 1968 Buick LeSabre that needed some steering work. Not something that my dad nor I had ever done and didn't have the specialized tools for, so we took it to the dealership. We could have bought the tools and a repair book for what they charged, but didn't really want a single purpose tool lying around, and didn't know for sure how to do the job. We pulled out to go home, and steering worked one direction but not the other. Took it right back by circling the block. They forgot to tighten something or other. Lessons learned.
Very cool!!! That Super Bird would be worth something like half a million dollars now!!
