Elliot
Contributing Member
Everything posted by Elliot
  1. You did right with him. Her when complaing about price, I would have taken a knife and cut the leather off the horse and sent her out the door with cut up junk! People like them are nothing but parasites. Suck every thing they can out of you and kick you on the way out. Remember them when someone else tries the same, you will be money ahead.
  2. Will it did for a while!!!!!!!!!!!!!! WORK!!!!!!!!!! Had to shut down and restart for other reason. On restart clicked name and went direct to profile, tried few min. latter drop-down showed up. The wonders of MS and I do not have a large enough HAMMER TO FIX IT. O-well
  3. Thank you for the reply. It is working now before when I clicked My name it went to the profile, no drop-down menu. O-well Must be the benifets of the MS system. Thank you
  4. I log in but there in no place to click for getting into the PMs in the upper right of screen, where did it go? Using Firefox
  5. Elliot
    Buckle Wanted
    I bought 1 3/4 heal bar brass or nickel from Oregon leather 800 452 5058
  6. Jim I have 2 of the motors Bob is telling you about. Would not go back to the motor and separate speed reducer. No holes to drill, cutting table for belt clearance. Can tilt the head without messing with the belt tension and just seams to work better or has more control. It will save you time, money, and headache.
  7. Thank you for the replies. Was quoted 6-700 + 80 a month. Salesman would talk over when I tried to ask hard questions. Will stay with dial up and the rusty bean can connection.
  8. What experience have you had with Satellite Internet? Is it better than dial-up, or just cost more? Thank you
  9. Checked the tension disks they are ok, not enough thread run through to wear. It looks to be a bad spring on the bobbin case. Would not put pressure on 69 thread. Will get a new case. Where can I get a US made one for a Artisan 618? I gave the spring a bend and got more pressure. Still getting the high and low stitches in 4in straight runs. And with a 10 lb hammer you get more frustrations worked out.
  10. When sewing leather or cloth about 80-90% of the stitches are either High or low about equal the rest look ok. Thickness doesn't seem to make much difference. Checked thread path not binding, changed needles, changed thread size and needle, fast or slow. Adjusted needle and hook no help. What could be causing this mess. About to fix with 10lb. hammer. I would be thankful of any ideas or suggestions Thank you in advance
  11. They have a web page http://www.pacificleather.com/ info@pacificleather.com
  12. Tandy has that one under #72015 in the 09 catalog. Looks the same as my 2015. Why or what caused it to go bad?
  13. I use what dirtclod does, then I add to it a Mini-Techlite head light and magnification. Their is info on this on this net. Do search here to find more info.
  14. This may help to break the rust. A pan of boiling water on stove, not up to the wood. hold in for 2 min or so to get the heat all through. Then dip into light oil or WD40 at room temp until tool is cool. Do this 3 to 6 times. This should suck the oil into bearing area and break up the rust. Some times works great, other times a wast of time.
  15. Unbolt old, bolt up new. May have to change belt. Auto parts store for that.
  16. I took the cover off (3 screws back of motor) and it is a set screw in the center of the only spring on the control lever. Do only 1 turn at a time, and feel the lever after each turn. Watch for the (pot) speed control wires, they unplug. Half the fun of buying something is opening it up and checking out the guts.
  17. Just install one of the motors from Bob Kovar Toledo Industrial Sewing Machines 1 866 362 7397 It has more power than the servo and speed reducer I was using. Does not need help on 3 layers of 8oz now. The Singer gets it next. This motor bolts right in no holes to drill, can tip the head without taking belt off. Has a internal adjustable brake on it, which is nice for some things. A real savings over a servo and reducer. I think it is a very good buy. Thank you Bob
  18. I had the same experience with Tandy Lace. One spool broke every few feet, all it would be good for is practice splicing. Next one had twists in it that would not come out, another for practice splicing. Next was as stiff as that near famous wedding night male thing, total junk. No more Tandy for me.
  19. A patch for wet suit works well for this. Buy enough for 2 and you will not have to go back a 2nd time. Buy for only one and it seams something will go wrong. Any how that how it works for me.
  20. Just received my book and pattern pack. Worth 3 or 4 times what I payed for them. Thank you
  21. Never did a ruby blade. I would use clear Gorilla Glue, or the Rear View Mirror glue from auto parts.
  22. Springfield Leather is listed as a seller of the Angelus line of products. Their web address http://www.angelusshoepolish.com/ May find some one closer to you.
  23. YOU are fast!!!!! I didn't even think it was worth a snivel, even a small one.
  24. Thank you Am using Firefox. The links above and below it load fine. Had me wondering
  25. When I click the link above link all that comes up is BACK and HOME!!!! What am I doing wrong? Thank you
