zuludog
Everything posted by zuludog
Yes, I've watched videos on strop making. They're OK but it seems to me that you can get far too involved and obsessed about things Making a strop is just about the easiest piece of leatherwork you can do. I've made several, for myself and for friends --- take a piece of wood about 12"/30cm long by 3"/8cm wide by 1"/3cm thick, but it doesn't have to be precision carpentry by any means, adjust the size to suit yourself or whatever you have available Take any piece of scrap leather about 2mm thick or thicker; veg tan if you have it; slightly oversize for the wood Cut it roughly to shape, then glue it to the wood, with the flesh side uppermost. I've used general purpose glue like UHU or Bostick, and PVA wood glue. Place it on a bench with the leather facing down, and stack some weights on the wood - a few books; or some cans; or a small toolbox. Leave it to set overnight Next morning trim the excess leather to the wood, and you're done I used to use Autosol for a stropping compound, but changed to a proper stropping/honing compound. I use Veritas honing compound # 05M08.01 but there are others It will take a little while to get the strop broken in. Whatever compound you use, when it changes to black that shows the strop is working as the black colour is steel that is being removed from the knife edge
Here are two books I can recommend - 'The Leatherworking Handbook - a Practical Illustrated Sourcebook of Techniques and Projects' by Valerie Michael 'Leatherwork - a Practical Guide' by Chris Taylor There are dozens, probably hundreds, of videos about leatherwork on YouTube, watch as many as you have the stamina for. Make it easier by Searching for different aspects and categories - beginners; tools; or particular items, as in your interest list I can recommend videos by Ian Atkinson and Nigel Armitage Have a look at the websites for Tandy, and Goods Japan. They will give you an idea of the types & prices of tools, though there are many other suppliers Try Searching Google for 'leather tools europe' Don't forget this forum! Especially Getting Started; Tools; and Sewing. It's almost certain that most of your questions will have been asked before Have a look at this supplier; they are Italian, and might be easier for you to buy from https://buyleatheronline.com
The Tandy 4-in-1 awl isn't very good, but you can't do much wrong with a round awl, so just keep it for that Instead look for a fixed blade awl. Tandy's stitching awl #31218-01 looks reasonable enough, though I haven't used it myself - perhaps someone else can comment Traditionally you bought the blade & haft separately, then mounted & sharpened them yourself. This is a right tedious job; so see if you can find an awl that's ready made up. Shop around for something like an Osborne, which is a reasonable price Even though an awl is ready mounted you will still probably have to do some final sharpening & stropping yourself I do most of my sewing with a stitching chisel, and only use a diamond awl for opening up holes sometimes, or if the thickness is too much for the prongs
All good stuff! If the prongs on your stitching chisel are too short to go through all the thicknesses of leather, follow it up with an awl - a saddler's or diamond awl, not round The 4-in-1 awl sold by Tandy and others is expensive and not very good; get a simple fixed awl instead You can hold down the leather with a piece of wood if it is difficult to pull out the stitching chisel. Try lubricating the prongs on a piece of beeswax. Also, polish the prongs with a homemade file or 'wand' made by gluing 600 or 800 grit to a sliver of wood, like a lollipop stick If the needles are too tight they may be too big. Try again with John James size 002 You've done a good job on sharpening the knife; a Japanese style works well once you get used to it. Personally I would have sanded the handle to round off the corners and tone down the colour a bit, but if you're happy with it.... I wouldn't remake the sheath. Keep it, to see how you've progressed, and to look back on
Search YouTube for 'Making a Wet Moulded Possibles Bag' There are several videos I haven't watched every one, but all those I have use a wooden mould or former
Sorry, a slip of the keyboard. I meant Ian Atkinson
Be careful when you buy John James needles, as there is scope for confusion because they have two similar numbering systems for needle sizes Size 2/0 is too big for most leatherwork unless you are doing really thick, heavy leather The size you want for most general leatherwork is 002, John James product code L3912 That is clearly explained on this video by Nigel Atkinson between 5min 30secs and 7min 45sec - 'Hand Stitching Leather' though of course it's well worth watching the whole video If, unfortunately, you have bought size 2/0 by mistake, well just put it down to experience, though they might just come in for something in the future. The needles are not so expensive that you couldn't buy a packet of the correct size 002
Beat ya to it! I've tried the surgeon's knot on a short length of the thread already, and that is holding. Look it up on Google, it is basically a reef knot with an extra turn . You can see I go backpacking; I've been using that on nylon guylines & cord for years and it works well enough Thanks for the advice though
Try watching IAN ATKINSON as well. His videos are fine examples of neatness and clarity
There are loads of videos on YouTube about leatherwork. Start by searching for 'saddle stitch' and and 'beginners leatherwork tools'. Have a look at those for items that interest you, and you will see how others do their stitching. I can recommend those by Ian Atkinson and Nigel Armitage For several years I used a stitching groover, it was just one of the things that was done. Then about 18 months ago I went to a demonstration & lecture by Nigel Armitage, and on his recommendation I changed to just marking the line of stitching with dividers, which I found were easier to use, and gave better results. I got a pair of dividers from the secondhand tool stall at my local market for £2-50, say less than $3-50, and they do the job well enough I think you will find stitching chisels with 4mm spacing easier to start with; once you've got the hang of things you can get smaller/narrower as you need them. It helps if you lubricate the prongs with beeswax Try 0,6mm Tiger and 18/3 linen thread to start with; get shortish lengths, say 25m; see how you go, and take it from there In theory a chisel is all you need to make the holes, but in practice you might need to do some extra work with an awl. Traditionally you bought a separate blade and haft, then mounted and sharpened it yourself, which is a right pain and takes ages. So look for an awl that's ready to use. Don't use the 4-in-1 awl sold by Tandy as it's not very good, and expensive. I suggest you get the simple fixed blade awl from Tandy (Stitching Awl with 26mmBlade; #31218 - 01) Even so, any new awl can be improved by a bit of sharpening on a fine stone, or fine wet & dry paper, followed by a strop You can make your own strop from an oddment of wood and leather - there are loads of examples on YouTube. This will be just about the easiest piece of leatherwork you'll do If you are starting you may well find it is worth buying into one of Tandy's discount schemes Using a steel hammer on stitching chisels is OK for a while, but eventually it will damage them. You should use a soft hammer, like wood, nylon, or hide
It looks nice & neat, but I wonder......are you using a lacing chisel or a stitching chisel?. I can't quite tell but it looks as though the prongs are flat, and flat in line with the body of the chisel; that would make it lacing. Also the stitching is all in a straight line On a stitching chisel has the prongs have a diamond shaped cross section and are set at an angel to the body of the chisel. Similarly, the awl blade should have a flat diamond cross section, not round. This produces the distinctive saw-tooth or zig zag pattern of saddle stitching. Still, it looks good, and if you're happy with it, fair enough
Thanks; I was thinking of something like that. So I'll finish it as I do for linen - backstitch 3 or 4 spaces then push the needles between the layers, tie it off, and do my best to hide the knot. I think the only way to find out what it's like is to just try it
As you've been doing, but use linseed oil
I've just had a look at those websites. I notice there are 3 grades; 1, 2, & 3; and that you can buy half sized pieces, priced accordingly. Why not get a half sized piece of each, mid grade, grade 2, and see how you go on; it wouldn't be too expensive. Sometimes you've just gotta try it Beware, though the prices seem reasonable, check for shipping costs, import duty, international handling charges, exchange rates, and so on And if you do decide you like the stuff, perhaps you should buy a stack of it before we Leave the EU! (assuming you live in the UK) Nigel Armitage has a video on 'Making a Simple hand made wallet' or some similar title. It is well worth watching Alright, I know I'm going off topic here, but as you say you are just starting, you might like this suggestion - You can make interesting and attractive variations by using different coloured thread. This lady sells short lengths of coloured linen thread from reputable makers at reasonable prices. Contact her directly to find out what she can supply https://kurzke.co.uk
I mostly make sheaths and sew with linen thread as I prefer that to synthetic But I thought I'd make a couple of belts, and sew them with synthetic thread, which is stronger than linen I was going to use Tandy's waxed nylon, then I saw some kevlar thread in my local Tandy store, reduced from £36 to £12 a roll, so I thought I'd try that. Now I have a couple of questions - How can I secure the thread at the end of stitching? It doesn't melt and bead up when heated with a lighter flame. I've tied a knot in a sample length and that seems to work OK; do you think it will stay secured long - term without unravelling? I've seen a video where they cut through a nylon cable tie with kevlar thread. I'm assuming they were able to do that as they used the thread in a sawing motion. If the belt end is sewn down securely and there's no movement I'm hoping that the thread won't cut the leather; any comments? Thanks Zuludog
Yes, that stitching line is just the sort of effect you want The thing obviously works, but it would be a nice touch if you cleaned it up a bit
So far I haven't dampened the leather. All I want to do is to mark a scratch line so I can place my stitching chisels evenly
Search Google for 'Goods Japan' They have a wide range of tools and materials, and will ship worldwide Prices are reasonable and include shipping, though there may be some import duty or handling charge at your own country Delivery time is about 3 weeks Search YouTube for 'leather work', there are loads of videos
I use a mechanics type tool chest, which has a cupboard base and a stack of various sizes of drawers I work on a steel office desk with an extra sheet of wood on top You might find these videos by Ian Atkinson useful - 'Making a Leather Tool Board' and 'Leodis Leather Workshop Renovation' and 'Leodis Leather Workshop Tour'
At the risk of sounding dismissive, I suggest that you don't start with either of those knives I use scalpels for my model planes ( in fact I trained as a biologist and they were left from my dissecting kit) but I think you will find them too light for all but the thinnest wallet type leather A round knife is the ultimate leather working knife, but they are tricky to use and expensive. I suggest you mentally put that to one side, and use a Stanley knife at first. They are cheap, work well enough, and you probably have one anyway. Then when you have got the hang of this leather business you can buy a round knife in the near future, with the benefit of some experience If you are starting, you might think about buying in to a Tandy discount card. There will be loads of things to get and it will probably pay for itself. However, I have heard that the Tandy/Al Stohlman round knife isn't that good. If you're going to get one, you may as well go the extra and get a better make. I'm sure others will advise you
Oh yes, I nearly forgot The key to any good leatherwork is to have absolutely razor sharp tools, so you could make your own strop from oddments of wood & leather. There is a sharpening section on this forum, or search YouTube. But treat yourself to some proper honing/stropping compound. This will be just about the easiest piece of leatherwork you'll ever do Even if you start off with a Stanley Knife (box cutter in USA?) which has replaceable blades, they seem to be better if you resharpen them, probably because you reduce the shoulder of the bevel, and give them a higher polish Whatever knife you use, you will need two. Keep one for leather, and the other for cutting string, opening parcels and so on . It's purpose is to make sure that you keep one knife exclusively for cutting leather
Welcome to the forum! I agree with Battlemunky and others, start with something simple, and build up from there How about a key fob? Depending on how complicated you want to go, it will show you - pattern making, marking out; cutting out; dyeing; edge bevelling; edge burnishing; saddle stitching; tooling; finishing; and probably a couple of other techniques I've missed. They will also use cheaper types of leather to practice on, like offcuts, remnants, or belly leather Make a few for friends & family, and keep the first one for yourself, to see how you have progressed There are loads of videos on YouTube. I make no apologies for repeating that some of the best are by Nigel Armitage and Ian Atkinson Have Fun!
SNAP!
ROCKOBOY - Search YouTube for videos by Ian Atkinson on making a turned leather messenger bag, and a tote bag. I think you'll find them both useful, and inspirational I don't want to make bags, but I've watched these videos, and he shows just about everything you need in small, logical steps (well, apart from the patience) In fact anything and everything by Ian is worth watching
Sticking with chisels instead of pricking irons...
zuludog replied to scrapyarddog's topic in Leatherwork Conversation
That's a reasonable summary. You would still need to use an awl if the combined thickness is more than the length of the prongs Nigel Armitage has reviewed several pricking irons and stitching chisels, just Search YouTube I started with Tandy's chisels, then I thought I'd try something different. However, for the amount of work that I do I was unwilling to pay for the very expensive makes. I settled on Seiwa European, and I'm happy enough with them. Whilst I might get different sizes in the future, I think I'll stay with that brand Note - Seiwa make two types of chisel; 'European' and 'Diamond'. 'European' is the better type, see Nigel's reviews 8 & 9
