fredk
Contributing Member
Everything posted by fredk
  1. I'll start with plain smooth I think. I have plenty of cheap bevellers spare
  2. I think I have 3 Singers, 1 Singer clone, and 2 others - I think *must get more*
  3. There's another type of beveller I shall have to acquire. Might see about rounding some square ones
  4. Did youse happen to notice the reporters name? Claire Sadler !
  5. Three teddy-bears got fed up with just sitting on the toy shelf in the nursery They decided to go out and find some useful work They went everywhere looking for work but found they were unskilled and untrained and no-one would employ them Almost on the point of giving up they tried their luck at a builders The boss told them 'I'm short handed with men off sick but I've got to get this job done. You can dig the hole for the foundations. I reckon you can do that' The teddy-bears worked hard digging that hole They worked all month Then on the last day of the month the teddy-bears arrived for work They went to the tool shed to get their tools but found not all the tools were there They told the boss 'Our shovels are there but all our pick-axes are gone!' The boss replied 'Did no-one tell you? Today is the day the teddy-bears have their picks nicked' boom boom I thank you. I'm here all week
  6. When the OP said 'small' I assumed he meant these; https://tandyleather.eu/en-gb/collections/tools?filter.p.m.filter.category=Embossing+Wheels
  7. Laces or trigger hooks
  8. I would get some lengths of thinnish (3mm to 6mm x 300mm ) nylon plate. Glue three pieces of plate in a stack; bottom is base, 2nd plate as belt edge guide and 3rd is the distance from the belt edge. The 2nd piece would be the thickness of the belt. Run the wheel over the leather as you feed it through this 'jig'
  9. Naa, it should only take a few minutes, 30 mins at most. Use warm water, with a tiny wee bit of dish-washing liquid soap in it. After soaking stretch it along its length in your hands, squeeze out excess water then lace it through the holes. As it dries it will stiffen up and shrink a wee bit tightening up You can do this whether the strap is dyed or not
  10. You could try using a wet strap for the conchos. Pull it up tight wet. Then when it dries out it will be even tighter
  11. I use the Axxx stamps as backgrounders and the Bxxx stamps as bevellers. B series bevellers are available with patterns on their faces You 'walk' them thru a background turning and overlapping the impressions on each hit. They give the background a fine 'hatched' appearance making the main design standout. Hatching, in the way a pencil artist draws
  12. I copy the images and print them out A4 size, then I draw over the lines to thicken them and leave out elements that I don't want, using 'Tippex' (white-out?). When I'm happy with an art work I scan it in. I put it thru my photo editing programme to clean it up and re-size it for the stamp making. I save every stage of the cleaning up and re-sizing so I can go back to any stage
  13. The edit is below the 3 dots, top right. You may still have time to edit
  14. You may not want to know this; but I got a replacement groover off ebay for under £8 inc shipping. Also, I had a choice of the size hole in it. I decided on 1.8 mm
  15. After The Flood Noah was seeing all the animal off his ship saying 'Bye now, don't be strangers, visit me. Go forth and multiply' As all the animal wandered off in many directions there were two snakes left Noah said 'Go, go, go forth and multiply' The snakes said 'We can't' 'Why not?' asked Noah 'Cos we'er adders' boom, boom
  16. If you are making lasts for boots you need to make the last come apart at the ankle otherwise it wont come out of the constructed boot (ask me how I know) A solid last is alright for shoes and boots that only go slightly above the ankle
  17. Optivisor - I couldn't remember the name earlier This is the type I have. But my wee light is broken and I'll have to cobble up a new one
  18. I have and use different powers of reading glasses for my close-up work. General use is 2 diopter, with 2.5, 3, 3.5 and for very close work 4. But the main thing are to have plenty of strong light and don't work in your own shadow I find using a jewelers loup awkward as it used with one eye only I also have, but rarely use a head band with changeable magnifying lenses
  19. Thanks, and a good tip there
  20. That was a method advocated in my medieval circles for making shoes. Not resin nor plaster of Paris but using cement, as in concrete. I used that way to make some lasts
  21. Resurrecting a dead thread; I've not really forgotten this, but nor have I attempted a flask I want to ask about using corn for packing it out - does the leather stretch enuf that there are no wee bumps caused by the corn kernels ? Is the stretched leather smooth at the finish?
  22. Buy Tandy. They're fine. They very good as a starter set. If you can go into a Tandy and inspect the tools. Make sure the shaft is straight. Check the design, make sure there is no flaw on it.
