Everything posted by fredk
Excellent
I never get notifications, I never have. I just check through the forum to see what I'm missing
I guess that 4 years ago the OP decided on which machine to buy,
#1 favourite dottir is still at Uni. I think she's been out on a few digs as part of her course but getting detailed info from her is like impossible. She takes after her maternal grandfather who only answered questions with, no, yes or silence I bought a pattern for a leather tool box-bag off dieselpunk and I'm now getting things and making cases for them. I have to start on that tool bag too I'll sew straps on the bottom part of the scabbard and have poppers on the top side to hold them closed
A picture of the situation would help But, a glue joint is a poor repair. I would make a new keeper and either wrap it fully around the strap(s) or slice open the sewing joining two straps, push the keeper ends in between and re-sew
yup, nice work In the past a book like this was called a Journal
A belt loop might be a good idea but in this case I don't think its required
The trowel may not be used on too many occasions but maybe quite a bit on those occasions. Confused? Its for my number 1 favourite dottir's archaeology kit, so on the few occasions she'll be on a dig the trowel will be / might be used a lot. Easier to make without straps, nicer with straps? I'll go now and cut leather for them
@Sheilajeanne @Handstitched - there was a video circulating on youtube a while back showing a female police rider with a ponytail riding along and both her and the horse's tail swung in unison, like two metronomes. afair the rider was from Norway, maybe this same rider I've started to make a scabbard for a trowel. Its still at the early stages. Before I go any further I have to decide if I should, or want to, put on retention straps over the back edge. This trowel will just be laying inside a tool box until needed. Opinions on straps? yes, no? The trowel sits on the base of the scabbard with welt pieces fitted and the top part lies in front, yet to be shaped
If you mounted a cross-section slice on a wood block you could make a clicker die Only joking, the metal wouldn't be strong enuf
Lining belt
fredk replied to Tmundiener's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Ya gotta be sure thats what ya want. And ya gotta make sure its all stuck together very well. Its much the same as when I glue liners for bags; I rough cut out the bag pieces, glue them all to the liner leather then cut the bag pieces out neatly and properly -
That looks a real beaut. It would look really well on a chestnut or black I think Welcome back. We've missed you
Not much help, but I got some artificial sinew from Le Prevo. I've not used it yet and I don't know where it is made Scroll down about 2/3 of the page http://www.leprevo.co.uk/threads.htm
Light weight press for making stitching holes quickly
fredk replied to SteveOz's topic in Leather Sewing Machines
That looks the job right enough -
How much of a scallop do you want? Olfa does a 'wavy edge' blade for its 20mm size circular blade knives. I've seen the same sort of blade for 45mm. These would give a very fine wavy or scalloped edge I have a 20mm blade. I'll try it on a piece of scrap and see what the result is edited to add; there appears to be several types of wavy edge/scallop blades from fine to bigger
@Handstitched good job. Good thinking re-purposing the spoon rack By coincidence, I just cleared three work tables of odd tools and leather crowding them. No excuses, just laziness. Tools went back into their proper places. Multiples went into a small tool box. Two crafters, 1/2 a world apart, and we do the same job at almost the same time
No. As I said, this was owned by a member of the Royal Ulster Constabulary - a cop. Looking up the Ruger I see they did a .357 Magnum. I think the plod would have had one of those. Most plods I knew chose to use Magnums as PPW. They were influenced by Clint Eastwood's 'Dirty Harry'. At that time the RUC standard issue was an old Webley 38. According to my friends, it had the stopping power of a marshmallow
I thought I'd share this with you. Clearing and sorting some boxes in my leather work room I re-found this Several years ago #1 son and I were tasked with clearing a rental storage unit. Amongst all the things we discovered was this holster. The previous renter had been in the Royal Ulster Constabulary aka RUC. The RUC was always armed with regulation issued firearms whilst on duty but this was for his Personal Protection Weapon, his PPW, for when he was off duty. The reverse side is stamped; Ruger Speed 6 2/91 I suppose this is the sort of pistol it was made for Remember; I did NOT make this. I found it Its still in relatively good condition considering it hasn't been used or looked after since about 2010, or maybe even earlier. But I think it could now do with some NFO Anyone want to discuss it? its style, the belt slots et cetera
ProPaste epoxy glue
fredk replied to dikman's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Also check out farming supplies. You might get heat-bulbs cheaper from them. Folk who raise birds; chickens, hens, pheasants, quail and the like use heat-bulbs over the eggs to keep them warm before they hatch -
The time is not really a factor. A wee set of 28mm D&D figures took nearly 3 hours to print but I'm not sitting over the printer watching it. One problem I envisage and have come across is that flat items can warp and twist. The larger the flat area the more likely and more severe the warping. A warped template would be hard to hold down
tbh, laser cut templates out of acrylic plastic are superior. I've had a few made for me and I've bought a few. Made in 3mm thick clear acrylic plastic. 3mm is thick enough and being clear I can see just where I'm positioning them
ProPaste epoxy glue
That sounds perfect for insides of leather mugs and bottles. I went by my local fishing tackle place on Monday to see if they stocked this. Guess what - just over last weekend they've changed their opening days & hours. Now closed on Mondays -
That reminds me of a certain film/movie Any of youse ever see, or remember, the film 'The Jerk'? Towards the end of the clip - see what he invents
