Dwight
Everything posted by Dwight
  1. When I do a Rhodesian, . . . I do not use welts. I lay out the pattern, . . . put on the clip, . . . stiffener (if needed), . . . decorative pieces, . . . etc, . . . then I get the whole thing real good and wet, . . . and fold and mold the holster to the weapon. The only sewing left to be done is the main seam that goes down the sight channel, . . . along the bottom, . . . and up to meet the trigger guard. I then hang it up to dry, . . . usually on a string through the channel that is the trigger guard. When it is dry (minimum 24 hours), . . . I remove the string, . . . insert the weapon, . . . close it back up tight, . . . check for fit, . . . glue the edges, . . . sand, bevel, and burnish, . . . sew, . . . finish, . . . done. May God bless, Dwight
  2. I've heard it called both a bleed knot and a blood knot, . . . and I have no idea which if either is correct. It is very simply done by making a slit in the bottom piece, . . . parallel to the edges, . . . just slightly longer than the width of the strap, . . . pull the top piece down through, . . . make the same type cut at about the same distance as the first cut, . . . but again in what is now the bottom piece, . . . pull the new top piece through it, . . . and you have the knot. Take a key ring, . . . put a strap of leather around the ring, . . . follow the above directions, . . . the first one will take you 20 minutes, . . . the second should take you 2 minutes. It's really that simple. May God bless, Dwight
  3. I like to make sure I give my customer's their money's worth, . . . and sometimes it is just a little thing. On my belts, . . . I use one inch spacing, . . . and I give them 7 holes. Doesn't sound like much, . . . but a 5 hole belt at 3/4 spacing only gives that customer a 1 1/2 inch movement either way, . . . mine gives them 3 inches, . . . fully double. Just my way of doing things, . . . and not everyone will agree, . . . and that's OK, . . . May God bless, Dwight
  4. If you have to do it, . . . end one thread and start the other between the layers. That is the only way of making it truly invisible that I know of. Sometimes a thread will break or I run out of thread in the bobbin, . . . and if it happens at the tongue end, . . . I'll camouflage it in the "going around the corner" of the belt. Otherwise I just pull it all out and start over. May God bless, Dwight
  5. Camano Ridge has the way I do it, . . . and if they don't goof up the measurement, . . . it ALWAYS works. I knew a guy once who wore "36" trousers. When we measured HIM for the belt, . . . turned out to be a 41. He had worn those jeans enough to stretch them all the way out to where the 36 was just numbers, . . . nothing near a size. I just sent off a $200 belt rig, . . . measured Camano's way, . . . note came back with big thank you, . . . "It fit perfect". Try using some "formula", . . . make a couple of those $200 rigs that don't fit and you'll see that there really is a good way, . . . and it all has to do with measurement. May God bless, Dwight
  6. Yessir, . . . I like those. That will probably be awful close to my pair when I get around to making them. Just finished these up for a cousin, . . . they'll be going home next week. I just wish the next two pair I have to do were as easy as this pair. These are just work chaps for around the old Ky hacienda. May God bless, Dwight
  7. Personally, . . . I prefer to use the "extra" pieces from the exact same hide that I did the project with. That way, the dye is predictable (if you are dying it), . . . the color matches, . . . and overall I think it lends a bit of authenticity to the creation. I have cut fringe from 5/6 oz suede, . . . on down to verrrrrrrrrrry thin stuff. Just depends on the look you want, . . . the product you are making, . . . and the service required. Obviously, sleeve fringe on a Harley jacket is going to be more demanding that fringe on a white, lambskin clutch purse. These chaps went from leg leather to fringe, . . . with the cut of the knife,. . . 4/5 oz suede. May God bless, Dwight
  8. Just a quick suggestion, . . . as I do this quite a bit. Get a 40 or 50% off coupon off the internet for Joann's Fabric. Go to the rear of the store where they have their canvas and vinyl, . . . some of their vinyl runs just shy of 20 bucks a yard, . . . you get a piece 36 inches wide and 45 inches long for 10 or 12 bucks. You can pattern a whole bunch of stuff, . . . and see how it works out, . . . without cutting leather, . . . and not having to put up with paper or manila folders. I did that especially for a couple sets of chaps, . . . paid off just the other day, . . . lady wanted to see a couple samples of my work, . . . I showed her my vinyl samples, . . . she came within an inch of wanting vinyl chaps, . . . but her buddy talked her out of it. I was hoping she would. Anyway, . . . that's how I would start out. May God bless, Dwight
  9. Good looking first attempt, Tony, . . . Like you, . . . i'd be interested to know too, as the ones I build are pretty much only for show, . . . personal wear, . . . etc. They don't get much bush time. I also really like that old saddle picture you have on there, . . . is that an old Jumbo? My Jumbo looks a lot like it. May God bless, Dwight
  10. Jimbob, . . . how about buying a really good, professionally made, commercial case, . . . then covering the outside with your hand done carvings and stampings? It would save you a lot of time, . . . it would give him a seriously sturdy case (i play music, . . . this IS important), . . . and would allow you to concentrate on the designs, . . . scenes, . . . etc that would bring a real smile to his face. Just a suggestion, . . . but it is what I would do, . . . and in fact, will probably do next winter for my guitar. My 30+ year old case is really good on the inside, . . . but a few too many nicks and dings in the outside, . . . therefore it gets a new skin. May God bless, Dwight
  11. Thanks, guys, for the kudos, . . . as for the belt loop, . . . I do it John Bianchi's way, . . . would probably quit rivets altogether if I could find something that would fully take their place in the stuff I do. May God bless, Dwight
  12. Harley45, . . . that rig is finished, . . . off the table, . . . I started a new thread with it. May God bless, Dwight
  13. Thanks for the good words, guys, . . . in answer to your question, Red, . . . the thumb break just simply was easier to do by hand than to try to crank it around on my Boss's table. Also, . . . when I start out my Western belts, . . . i have the underside keeper in place, . . . but no thread in the machine, . . . I make the holes with the machine, so that they are perpendicular, evenly spaced, etc. About the 3rd hole after the keeper, . . . I put thread in it, . . . and start "Bossing" my way around the belt, . . . in this case it was about a total of about 500 stitches on the belt itself. When I get back to the bottom side of the keeper, . . . I pull out about 16 inches of thread, . . . then hand sew that bottom side of the keeper, . . . and end my sewing on that lower corner of the belt. About 24 stitches in the thumb break and another dozen in the keeper, . . . ala teaching of Mr. John Bianchi, . . . for which I am seriously grateful. May God bless, Dwight
  14. I just finished this one for a customer who is going to wear it horseback riding in Oklahoma. I don't often get to do "fun" ones, . . . this was definitely one of those. I put it on after I got it done, . . . fit like it should have been mine. This is a double layer, . . . glued together, . . . Katsass/Dwight type holster, . . . belt is the same. Have to admit that I did cheat a little bit though, . . . there were only 36 or so hand stitches in the whole rig, . . . rest were done on the old machine. May God bless, Dwight
  15. It will depend on the machine. Some will allow you to do it, . . . some won't because of the "table" arrangement. As you can see in this picture, my machine allows a flat object to go through and just run out on the table, . . . I intended for that to happen, especially for belts. The little box looking thing to the left of the machine is held on with one screw. Remove it. . . . I've got a saddle stitcher that allows me to put any shaped piece in there, . . . including a pre-formed holster. I had to remove the box for this holster, . . . as it would have made the stitches come out not perpendicular to the holster. Again, . . . when I designed the shop, . . . I had that in mind. May God bless, Dwight
  16. Actually, most of my CCW holsters are molded first. I'll sew down the sight track edge on my Cactus and pancake designs, . . . wet mold, . . . allow to dry, . . . then do the glue/cut/sand/gouge/edge/sew trick with the holster basically molded and boned. I'll sometimes touch up the boning or molding, . . . but only if it needs it. AND, . . . those are holsters made from one layer of 6 to 9 oz leather, . . . uhh, . . . mostly. My cowboy holsters and large revolver holsters all get pretty much sewed up then molded, . . . just the way I do it. May God bless, Dwight
  17. Being a pastor, . . . the one on the far right would be my choice. My only comment would be if I were doing them, . . . I would have changed the overall outline, shape, etc. a bit more than you did. Not that what you did was bad, but it looks like you only have one pattern and one barrel length. Trade out the loop around the holster for a belt and a buckle on one, . . . make one for an 8 inch barrel, . . . make one left handed, . . . make one that is definitely only for cross draw, . . . make the skirt square on one, . . . sink the whole weapon down in one, . . . and have the trigger guard fully exposed on another. Cowboys of old, . . . and today's cowboys are both a discriminating bunch, . . . and a particular bunch, . . . that from my point of observation, . . . want to be different. They don't all have to be John Wayne the hero, . . . but Billy don't want to look like Bobbie Joe, . . . who don't want to look like Chester, . . . etc. Give them some real differenciation, . . . they'll reward you for it. May God bless, Dwight
  18. Well, actually, Harley, . . . the pictures you saw are of the completed holster, . . . needing only the final assembly of the parts after the final finish goes on. Construction wise, . . . it is done. The walls were made of two layers of.109 thick (7oz) leather, . . . and the bottom seam including the welt, . . . came out at .550 inches thick. That seam had 5 layers of leather there, . . . 4 coats of Weldwood contact cement holding it all together while I stitched it. Molding, i do after I dye the holster and let it dry. I then soak it good again, . . . and go to town on the molding, . . . boning a holster of that type is just simply out of the question. I've laughed and kidded Mike about this process as it just about makes another weapon out of the holster itself, . . . it becomes so hard. As far as sewing, . . . all the stitches you see there are done on my Tippmann Boss, . . . including the .550 seam. That seam took me all of probably 2 minutes to gouge and sew with waxed 346 thread. The only part of the whole holster that was hand sewn was the outside portion of the thumb break. This holster is for a pretty good sized man, . . . and he has an old fashioned (40 year old) stainless steel Colt .357 with a 6 inch barrel he'll be toting in it. He also got a matching belt with 24 cartridge loops. The thumb break is for his horseback riding jaunts, . . . If I didn't have my machine, . . . I'd probably find some other use for my leather shop. May God bless, Dwight
  19. Here is a couple of examples of Katsass technique (curing overnight with a weight) and my way of doing it (lightly skiving the inside piece for about an inch or so at the bend). The flap area and the barrel area at the sight plane were both skived, . . . Weldwooded, . . . put together, . . . laid under a marble weight for about 12 hours, . . . then magically turned into a big brown holster for a big stainless .357. I'm usually in too much of a hurry to wait, . . . but this time, I had the time, . . . so I added the "grumpy" effect, . . . and as it is plainly evident, . . . grumpy or not, . . . it works. AND, . . . it ain't got no wrankels, . . . rinkels, . . . or wrinkles. May God bless, Dwight
  20. Like pickles on a cheeseburger, . . . some like em, . . . some don't. With a big revolver like that, . . . my preference would be to have one on there in case I decided to use it. For a 1911 or smaller, . . . I don't use them, . . . but then again, . . . I've seen and made them both ways. May God bless, Dwight
  21. I had to paint black letters on a white background, . . . and just could not get the paint to run only to the edge of the stamp, . . . it always wanted to run a "little bit more" (I stamped the letters, . . . then painted the inside of them). I wound up outlining it in black (using a very fine point Sharpie) and then painting up to the inside of the line formed by the Sharpie. I didn't realize I could paint so beautifully when I got done,..................... May God bless, Dwight
  22. Finishing the interior of a holster is kinda like pickles on a cheeseburger, . . . some do, . . . some don't. It's all personal choice of the maker (or end user). I personally only use pro oil stains, . . . and generally finish with Resolene, . . . but there are at least a dozen other ways. Unless a customer is adamant about not doing anything to the inside, . . . the whole thing gets the same treatment, . . . inside and out. My resolene finish protects the leather from the oils and stuff that accumulate on guns, . . . along with the unburned powder, residue, carbon, etc. All that junk if it gets into a holster which has soaked up some oil, . . . will become just like rubbing compound, . . . and WILL mess up the finish on a fine gun. OTOH, . . . most folks today are buying the plastic fantastics, . . . no stainless or blued steel, . . . so the finish is a moot point. May God bless, Dwight
  23. First off, . . . I don't do many shows, . . . and not a lot on Ebay or Gunbroker or other sites. But when I do, . . . I keep it simple both for me and for my customers. Internet sales always have the statement in there: Free Shipping or Shipping, Handling, & Insurance included in price. I like to buy that way, . . . others do too, . . . so I use it as an inducement to buy my product as opposed to the other guy's where those are additional charges. At shows, . . . it is an "all inclusive" price, . . . high enough that I can go home and figure out how much to set aside for sales tax and still make a profit, . . . as well as high enough to also offer the free shipping for mail order customers who want to order something at the show, . . . and yet I keep my prices at even dollar amounts. Why do I do this? I'm lazy, . . . admittedly, . . . and I'm not carrying a bunch of change and making change for tax, shipping, etc. My customers are intelligent discriminating adults, . . . I treat them that way. May God bless, Dwight
  24. Exceptional.....!!! May God bless, Dwight
  25. The suggestion to use a torch on the conduit is a VERY bad idea, . . . conduit (galvanized metal) has a zinc type coating, . . . heating it very hot will expel nasty fumes, . . . you will gag, choke, puke, and mention some otherwise "not nice" words if you happen to get a lung full of those fumes. Secondarily, . . . there is not much temper in conduit, . . . but there is some, . . . so when sanding it sharp, . . . take your time, . . . don't get it very hot. This picture shows some of the punches I've made for various things I do, . . . the belt slot punch is the one on the far right hand side. Plus, . . . none of them have anything on their tops, . . . except the sanded and smoothed end of the conduit. If you keep it fairly sharp with a round file and/or sandpaper, . . . you will not hurt your maul or mallet. May God bless, Dwight
