Everything posted by Dwight
When u design a new holster pattern
Dwight replied to rccolt45's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I use either marine grade vinyl ( about 25 bucks for a piece that is 36 x 48 . . . OR . . . I use yellow manila folder stock. The vinyl gives me a really good shot at what I need . . . and is best for some unique do dad . . . but in the end I use the cut piece of leather to mark out and cut the pattern on manila folder stock for future reference. I always make the first cut 1/2 inch wide in all directions . . . and trim as needed. It is very seldom that 1/2 inch margin doesn't do the trick. May God bless, Dwight -
putting a belt in the fridge?
Dwight replied to LakeOtter's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I've never done that . . . and it would take a bunch of convincing to get me to do that. Stuff dries out in the fridge almost as fast as laying on the counter. For what stamping I do . . . if I have to shagnasty for a while . . . I leave it and hit it with the sponge when I get back. Works fine for me May God bless, Dwight -
mountain man moccasins pattern #3 By Gene Noland
Dwight replied to chuck123wapati's topic in Patterns and Templates
Good looking . . . wonder how long the soles will last . . . I'm gonna make myself a pair some day . . . using the 3 layer approach the Romans used on their sandals. Bottom layer is sole . . . thick . . . and they had kinda likd hob nails that gave them traction whenever they were worn. Middle layer actually is all one piece . . . toes and tongue would sew in like yours . . . sides and ends are all one piece Top piece is the inner layer that touches the wearer's foot. All three layers were sewn together . . . and if I recall correctly . . . may have been some rivets. That is what I'll do Plan on making mine to stop just below the knee . . . will put zippers in the inside for quick on and off May God bless, Dwight -
Thanks pal . . . beautiful wallet . . . I won't even think about doing something like that . . . never been that steady at cutting & stamping. May God bless, Dwight
I think it looks fine . . . you definitely put a lot of time into it for sure Sometimes it is the time spent that helps the maker say to himself "Good Job" when he can look at it knowing it is done. What is the bag for? May God bless, Dwight
How do I paint or draw on leather (waterproofed leather)
Dwight replied to c.c.1315's topic in How Do I Do That?
If you have someone who has a laser burner . . . the mittens could have a flat board pressed into them (to create a flat surface) . . . and if you could get it flat enough . . . and IF the person using the burner is good enough . . . he could just burn off enough of the waterproofing that you would have a rough surface for the paint to adhere to. The acrylic paint itself is waterproof . . . so you should work out good there. But the whole thing hinges on how good your laser burner buddy is . . . May God bless, Dwight -
A couple of months back . . . had a fellow need a new belt . . . his older one had seen better days. Simple project . . . grabbed a Script font from MSWord . . . wrote his name out . . . on the computer . . . did a screen shot . . . turned it into a *.jpg . . . picked it up with Laser GRBL . . . plotted in on my little 50 dollar laser engraver . . . did a "guesstament" as to the settings . . . darned if it didn't turn out just hunky dory. Laid his belt onto my engraver's table . . . did a couple of test runs for position . . . turned my little laser loose . . . and about 6 or 8 minutes later . . . took the finished project off the table . . . wiped it down with a paper towel . . . dyed and finished the belt. He was happier than a broke out jailbird . . . May God bless, Dwight
Tape Measure Carrier
Dwight replied to Hildebrand's topic in Gun Holsters, Rifle Slings and Knife Sheathes
If you saw the right front pocket of most of my work britches . . . you would not wonder why I don't have one. May God bless, Dwight -
Interesting Holster Project
Dwight replied to MarlinDave's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I like the patch idea . . . but I'd rather just make the holster out of two pieces of 6/7 leather and be done with it. It'll make a really good sturdy holster . . . it'll outlive your friend unless he is come kind of hard on holsters . . . I've made some ungodly number like that . . . only ever had one that would not pass my quality control . . . I did some experimentation on it for rigidity . . . and you could probably get arrested for hitting someone in the head with this one . . . it would knock him out . . . leave a concussion . . . and he might bleed to death from it. May God bless, Dwight -
It ain't HO . . . but I've never had much more than a small quibble about the sides I've purchased thru Tandy. Granted . . . I don't order them on line . . . I go in . . . start pulling and inspecting sides with my dial caliper and my two good eyes. It has taken a good half hour in the past . . . but that side of leather I walk out with tucked under my arm . . . it does the job and then some. May God bless, Dwight
1: don't use glue . . . use contact cement . . . put it on with a plumber's brush . . . (cheap metal handled / size of a pencil / buy at Harbor Freight in a bag) 2: it goes on both surfaces that are to be put together . . . let it get 95% dry . . . then put them together. 3: a minimum amount of care will keep it off where you don't want it. May God bless, Dwight
No . . . you absolutely DO cement the lining to the kydex . . . just don't glue the outside holster cover to the kydex. May God bless, Dwight
No . . . you mold it to the weapon . . . and if you buy it from Tandy . . . get their thicker batch. There should be a shiny side and a dull side. The dull side goes inside like it would lay on and touch the gun . . . the shiny side faces out. Put a row or two of masking tape over the top of the weapon . . . gets rid of the need for a sight channel . . . take it up to just before it gets to the rear sight (that's how I do it) . . . if you've got a piece of thin suede . . . wrap the gun it it . . . it helps with the spacing. Put the grip in a leather padded vice and lay the kydex piece on top of the gun . . . heat that center piece until each side falls down . . . pull the edges together and rub the top with a wet wash cloth . . . it will set the kydex from any bending right now. Lay the gun on one side . . . heat the top side of it . . . and wearing a pair of leather gloves . . . mold the kydex to the weapon . . . over top of the suede. Again . . . once you get it molded good . . . hit it with the wash cloth to stop it from moving. Flip it over . . . do the above steps again on the other side. BE CAREFUL WITH MAGAZINE DISCONNECTS . . . and other levers / buttons / or whatevers . . . don't get them involved deeply in the molding process. Then comes the fun part . . . with the kydex all molded . . . nice and cold . . . put the bottom of it in that leather padded vice . . . so the top of the mold where the sight track of the gun is . . . that part is up on top . . . and level. You should notice a definite "spring" sensation as you try to close the bottoms of the pieces together . . . and what you will do now . . . is reverse the spring. As it is now . . . it will want to spring apart when you squeeze the bottoms together. What you do is apply just enough heat across the top to relax that springiness. Hit it with the wash cloth . . . and when you take it out of the vice . . . the bottoms will want to touch or come within 1/16 of an inch in doing so. When you pull the bottoms apart . . . it will want to spring back together. Trim the kydex only enough to get it inside the leather stitching. Double check the springiness . . . you may have trimmed enough off the edges that you may want to repeat that last heat / mold you did. You then mold the inside . . . leather lining of your holster . . . I like 5/6 oz for this job. Mold the leather as tight to the weapon as you can . . . maintain a sight track . . . be mindful of those buttons and levers on the side of it . . . BE CAREFUL WITH MAGAZINE DISCONNECTS . . . STEER CLEAR OF THEM. I have actually cut totally around them for 1911's . . . just a hole there where the leather and kydex used to be. Here you check and see if you have a decent grip on the gun using the kydex as the spring. It has to at least keep the gun in the leather and kydex if you hold it so the gun conceivably could fall down and out. CONTACT CEMENT THE KYDEX TO THE INNER LINING. Next . . . finish the holster with the outside layer of leather . . . belt loops . . . snaps . . . whatever . . . and sew her up. If you use any glue or contact cement . . . steer clear of the kydex. Wet the holster once it is finished the construction . . . and put it in a hot box to dry . . . 140 degrees F . . . Doing that twice will harden up the whole process like you would not believe. Be careful not to go over 140. You now should have a fairly springy holster. May God bless, Dwight
Kydex . . . properly molded with a hair dryer . . . can double for the steel spring . . . You can sew it into the holster . . . works great . . . my derringer holsters use it quite effectively (and I hate to make em) May God bless, Dwight
Thanks for the video . . . cool presentation May God bless, Dwight
Handstitched ^^^^^ gave you the best advice. Talk to people . . . you either have to become a good salesman . . . or you need to wear your wares. Show off a gorgeous belt . . . wallet . . . maybe a hatband . . . key fob . . . vest . . . AND . . . carry a pocket full of business cards . . . When you strike up a conversation with a new person . . . make sure you let them know that their new belt of wallet . . . etc . . . does not have to come from China or Pakistan. Create a website . . . get on facebook . . . and put some stuff on Etsy or Facebook marketplace. Get your face and examples of your wares in front of people is how it starts. And don't be discouraged if it takes 2 years to get the "groove" you wanted. Took me several different tries . . . and I'm still adding newer products. May God bless, Dwight
If you do many belts . . . like me . . . you'll find you are changing that 30 inch rascal all too often. I still use both of the two I've got . . . but just as soon as I can get some of the junk work out of my hair . . . I'm going for a 2 x 72 inch knife grinder . . . with a bit less than 5 times the belt surface . . . I'm looking to get 5 times the use out of it . . . plus the 2 inches wide will do better than the 1 inch I'm now using. But I do like your rig . . . and if I did any real serious wood working . . . I'd be very much interested in one of those May God bless, Dwight
Leather Weight for Lined Holsters.
Dwight replied to Latigo Smith's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Actually I should add a couple of "tips" to help with holsters . . . especially western / cowboy types. 1: Once the contact cement is applied . . . I like doing the liner first . . . allow the whole shebang to "almost" dry to a DRY state. The piece that makes the outside of holster and the inside of the belt flap is my dryness tester. I let all of it dry until this piece is still just a tad bit still sticky. It won't glob off on your finger . . . but you can still feel a tiny little bit of sticky there. That will allow you to take it apart if something didn't quite line up right. AND . . . yes . . . that's the voice of experience talking. 2: Go to a hardware store . . . buy a hammer handle for a typical old style 16 oz carpenter's hammer. Cut the end off of it where it would go thru the hammer head . . . sand it real smooth . . . and put some poly finish on it. You will use this tool once the two pieces are put together . . . force it down thru the holster . . . keeping the stitch edges together. It opens that sight track very well and will give you room for the ejection handle as well. Latigo Smith wrote: "Alrighty, it sounds like pre-bending is the way to go. Do you find that simply applying pressure with your hands when cementing the layers results in a strong enough bond? This was the only reason I had planned on gluing flat, that I have more confidence in the hold of the contact cement when it's had a little time with some weight applied to it while curing. You use the gun to wet mold the individual layers to the correct curve radius before glue up? That sounds like an excellent way of doing it. Do you leave the gun in the leather while it's drying like when doing final molding or do you just mold it to the proper curve, take the gun out and let it dry? " Yes . . . hand pressure is usually enough . . . have never had a problem with it. And actually . . . once it is sewn . . . it ain't gonna go no where. I only use the gun for wet molding the interior liner . . . everything else is molded over top the liner piece. The gun is in a plastic bag while doing that bit of molding . . . and once I have that mold (about 3 minutes) the gun is not needed in the rest of the process. Have fun . . . may God bless, Dwight -
I'd wear it proudly if I were a lady May God bless, Dwight
That would be made by me using two molds. Both are 2 piece molds . . . one big enough for the pen body . . . the other one big enough to hold the total pen body. You might try making one big enough to put both pieces in there . . . that would alleviate any match-up problems later on. I'd then find out the dimensions of his pens . . . taking a decent picture of them . . . you can fairly accurately predict the size for each hole . . . and I would add a 1/16 to 1/8 inch to each hold just to make sure. Wooden dowels can be substituted for the real thing. And don't worry about the expense . . . if you do that right . . . I'm betting for more orders based on word of mouth . May God bless, Dwight
Yes . . . I totally pre bend my holsters that are lined. AND . . . you isolated the big reason . . . wrinkles. If you glue them flat . . . you have a 999 out of 1000 chance that the inside will wrinkle like the 98 yr old witch living down the road. I moisten and wet mold the inside piece . . . as it touches the weapon . . . so it needs it's positioning settled up front and wet molding it does that trick. I then let it dry . . . completely . . . At the same time . . . I will also wet mold the outer layer so that the sight track portion knows it is not laying flat the rest of it's life. It's only a so-so molding . . . just enough to set the curve for the final bonding. I do the same for the back flap of the holster . . . bending the inside piece before bonding with the outer piece. It makes for a much better curve for the flap. Concerning the weight . . . generally speaking the thicker the leather . . . the stiffer the final product. But that can also be achieved by cheating. Putting the two pieces together . . . and either slipping it thru the Mexican loops or adding the front buckle loop . . . you then wet the whole thing . . . and hang it in a 140 degree farenhite "hot box" . . . take it out after a couple hours . . . if it was made out of 5/6 or 7/8 . . . the holster itself is a weapon . . . you could knock someone out . . . banging them on the head with that holster. May God bless, Dwight -
I am going to give this man or the scribe who wrote this . . . a get out of jail card. The last sentence is totally . . . completely . . . dumber than a cracked rock . . . WRONG !! The get out of jail card says they simply made an editing mistake . . . or were talking without thinking . . . the statement is totally wrong. A holster made for example out of one single piece of 12 oz veg tanned leather will be a stiff holster. . . . no doubt. But if you take two pieces of 6 oz . . . (piece # 1) one with the exact design and dimensions of the original 12 oz . . . and a (piece # 2) second piece that is about 3/8 inch longer and wider than the first one . . . and you make a holster out of this . . . it will be MUCH stronger . . . MUCH more durable . . . and will retain it's strength for years . . . after the first is a flat plie of trash leather . . . looking for a scrap heap to jump into. You make the first piece so that it is cut from the original pattern . . . but cut with the flesh side facing up and the pattern laying on it. The second is cut with the hair side facing up and the added 3/8 inch added to the original pattern. Take this first piece . . . dampen it substantially . . . and roll it into the general shape the holster body would need . . . let it dry. Add contact cement to the flesh sides of each piece . . . let it get dry enough that there is only a very slight tacky feeling to the touch. lay the second piece on the table . . . hair side down . . . and using the edge of the barrel that houses the sight track . . . gently put the sight track of the first piece down onto the second piece . . . get a good contact . . . and roll it a bit from side to side. Keep working until you have the stitch edge in your left hand . . . the holster basically squeezed together. This is the process that makes the strongest and most durable holster out there . . . made entirely of leather. Some folks add a metal lining between the two pieces of leather or a piece of kydex. I've never found a need for it. And again . . . that is in full defiance of the last sentence I highlighted for your understanding. As printed, that statement is not worth a pothole in the middle of an airport runway. May God bless, Dwight
