Everything posted by Dwight
I really don't have any idea whatsoever, . . . but my guess would be, . . . as loose wound as he was, . . . it was probably open. Ol' Teddy was one of my heroes growing up. Always loved the fact that he was HIS man, . . . no matter what the opposition had to say. And that is really good looking from this end. Make sure you throw up a bunch of pics as you go along, . . . and of course when it's done. May God bless, Dwight
First leather project 1911 holster.
Dwight replied to 3248tm's topic in Gun Holsters, Rifle Slings and Knife Sheathes
NOW, . . . if that is your first holster, . . . you are off to a fine start, . . . and you got some good advice up above this post. If you take the flat end of a modeling tool, . . . a sponge that is just damp, . . . most of the time you can re-dampen areas you "messed up" in tooling, . . . not too damp, . . . you will have to practice to get that just right feeling, . . . then take the modeling tool and flatten that whole area, . . . for example down at the bottom of the holster. Sometimes when it dries it will kind of spring back up a little by re-dampening it, . . . smoothing it all to the same height. Even if it doesn't spring back up, . . . at least it will all be the same height. Another pointer, . . . forget the rivets. Generally speaking, when I see a rivet on a holster, my first inclination is that this is a new person to holster making. There really is no reason to put a rivet there if the lacing or stitching is done properly, . . . unless you are using it for decorative purposes. It will not enhance the strength or overall life of the holster. AND, . . . welcome to the fun and exciting world of holster making. Somebody said one time there is estimated to be some 300 million firearms in the USA. That gives us 300 million opportunities to be different, exciting, creative, and make the economy grow by $5.50 a square foot, . . . plus dye, . . . plus finish, . . . plus postage. Seriously, . . . glad to have you aboard. May God bless, Dwight -
Newbie with questions
Dwight replied to Tigdim's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Actually, Aaron, . . . a full fledged drill press would not be needed if you have a good 1/4 inch drill (or a busted one for that matter). Every spring when my buddy and I start out on our yard sale escapades, . . . invariably we will see one or two of these (or very similar) units out there for $5, . . . $2, . . . or something similar. They cinch down on the neck of the of the hand drill and make it a kinda sorta drill press, . . . but would be perfect for your use. Too bad you can't tie a rope to your garage and drag it down here, . . . we could wire that puppy up in a Saturday morning, . . . and you would be "on your way" so to speak. I've got to do the same to mine, . . . but it ain't happening until the outside temperature is equal to or above my age, . . . and I was born in 1944. Take a look at this: https://www.ebay.com/itm/Bench-Drill-Press-Stand-Single-Clamp-Base-Frame-Electric-Hand-Drill-Holder/382301724943?hash=item5902f5610f:g:8AoAAOSwb9BaohvL May God bless, Dwight -
Yessir, . . . good job, . . . May God bless, Dwight
Now this is going to rankle some feathers , . . . and it is just too bad. I'm just plain lazy, . . . do not like to do any extra work that I can figure a way around or to get out of. That is why I have a Tippmann Boss sewing machine, . . . "Hands are for hamburgers, . . . sewing machines are for stitching". But if you don't have the machine yet, . . . this is a down and dirty way to save yourself some grief. If you have a small drill press, . . . or one of those $20 things that hold a hand drill and work like a drill press, . . . drill a 3/8 inch hole in a piece of plywood about a foot square, . . . tape it down so the hole is where the drill would be, . . . chuck up your awl blade in the press, . . . run your stitch wheel so you know where they need to be punched, . . . use the drill press to punch the holes. Take a piece of duct tape and tape your chuck so it does not turn on you, . . . or just eyeball it every time you get ready to drop it through. # 1: it is a super whole bunch easier # 2: it is easier to see where you are punching because your hand is not in the way # 3: the holes are absolutely 100% straight up and down (otherwise the back looks somewhere between "not perfect" and "downright shabby") # 4: you can punch all the holes for a project, . . . take your awl, your needle and thread and go over to the couch, . . . turn on your favorite TV show, . . . sew and watch the boob tube at the same time. AND, . . . it is so much easier on the hands. Also, . . . if you want a bit of a fancy stitch, . . . turn the awl blade about 30 degrees, . . . and it gives a bit of a rope looking effect to your stitching. May God bless, Dwight -
FWIW, my holsters and belts are all done on a Tippmann Boss, . . . with the longest stitch length I can get on the machine, . . . which averages something in the 5 1/2 SPI. Thread, . . . 346 bought at Tandy store. I believe it is a poly thread, . . . the nice thing about it is when it is cut, . . . I can hit the end with a BIC lighter, . . . it melts and disappears, but creates a little ball like on the end of it, . . . keeps it from getting pulled through. Tandy used to sell a waxed thread that I truly enjoyed using, . . . if I had known they were going to abandon it, . . . I would have bought 10 spools, . . . It somehow did a better job, . . . I'm not all into how it did it, . . . it just did. Wish I could get some more of it, . . . but all they have now is dry and while it works, it sometimes just wants to be a pain, . . . and it IS a pain when it wants to be. EDIT: forgot to mention, you said you were doing a 50/50 pancake. Some day when you feel like experimenting, go for a flat backed pancake. I personally choose flat backed holsters for CCW over any of the others. Most of my holster making technique I borrowed from looking at Milt Sparks holsters, . . . I would not make a copy of one of their designs, . . . but I have let their ideas influence what I do, . . . and so far it has worked really well. Most of their CCW holsters are also flat backed. May God bless, Dwight -
There used to be a fellow on here, . . . have not seen him in a couple of years, . . . was in really bad health last time we corresponded, . . . his persona was Katsass. He hand sewed all of his holsters from veggie tan, then dyed them or sat them out in the desert sun to tan to the color he wanted. Here is a post showing a holster I made very similar to JLSLeather's above: http://leatherworker.net/forum/topic/69512-designed-by-katsass-executed-by-dwight/?tab=comments#comment-454607 (Katsass made some really good looking stuff, . . . take a half hour and use the search function for him, . . . you'll see some neat work.) For that particular holster, . . . I gave it a good coat of Resolene when I made it, . . . and it is one tough, hard, holster. It is 4 layers of leather bonded flesh side to flesh side. May God bless, Dwight -
Thanks electrathon, . . . It looks more like this is the way to go with this. Just the old soles being shot. May God bless, Dwight
One of these days, . . . I'm going to make a pair of saddle bags, . . . just to hang up in the shop, . . . and to say I've got em. All the old westerns we used to watch, . . . they always intrigued me as the cowboy would pull them off the horse, . . . throw them across his shoulder and head off to the local hotel or saloon. I know it sounds corny, . . . but I always thought that looked super cool to tote your stuff around in just those two saddle bags. May God bless, Dwight
- 10 replies
Lining for Shotgun Case
Dwight replied to rktaylor's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I do know of one military group, . . . a veterans "Honor Guard" organization that used to use canvas ones what had a wool like lining. I don't know if it was real wool or synthetic, . . . but the main reason they used them was for the "bump" factor, . . . you could throw 10 of em in the back of the pickup truck, . . . drive 50 miles on back gravel roads, . . . and they wouldn't bump together and scratch each other up. They went into the bags . . . . to the ceremony, . . . out of the bags for performance, . . . back in the bags for the trip home, . . . and out of the bags ASAP once arrival back at the Amvets post. NEVER were left in the bags even overnight. The wool would be good for the bump protection, . . . May God bless, Dwight -
Thanks, RockyAussie, . . . This is one of those "pro-bono" jobs we sometimes do for folks. No great salary to be had here. But it would be good to get the experience in case I needed it later on for something else. I'll clean one of em up early next week and see where we have to go from there. May God bless, Dwight
If I used sheepskin, . . . I would make sure never to leave the gun in there. It would be for travel only, . . . and even then, . . . not across country. Any moisture at all in there is not going away, . . . except after it turns to rust on your gun. May God bless, Dwight -
Thanks, appreciate the info. He said he had another pair done some time back, . . . barge was used there, . . . but I think that was the shoe guy who passed away last year. Mr. Martin was a fixture in the community as far back as I can recall, . . . and I'm 73. I miss him. Is there any special prep needed on the insole before "barging" the soles on??? Thanks, may God bless, Dwight
A friend has a pair of Rocky boots that are in wonderful shape except that the soles are junk, . . . falling apart like the white hard insulation that just breaks off in little white balls. Only thing is this is black rubber, . . . and they are wasted. He wants me to clean off the old rubber soles, . . . and put new ones on, . . . Somebody out there give me a real good shot at how to clean the bottom of the boots, . . . the insole, . . . what do I use to get it where the contact cement will work???? And should I use weldwood or Barges, . . . is there an appreciable difference for shoes??? Thanks, may God bless, Dwight
Rear Pocket Holster
Dwight replied to Stewart's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Looks good, . . . you have a talent I've never been able to acquire, . . . doing a basket weave and making it look right. Mine usually resembles a shredded radial tire after a blowout. Gave up trying, . . . long time ago. May God bless, Dwight -
"Carving" on Western Style Holsters
Dwight replied to PAMuzzle's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Cannot say about holsters, . . . But I've got a "Jumbo" saddle I bought out of a pawn shop in Denver, . . . looks like some old cowboy bought or made some stamps, . . . and attempted to "dress up" his saddle, and I really like the thing. None of the stampings are very deep at all, . . . Bought it as a decoration for my leather shop, . . . but will be putting it back out to pasture later this summer, . . . a friend in Az wants it, . . . so it's going back on the trail. I just wish I could get it to talk to me for a couple hours before it leaves, . . . just know it could tell some stories I'd love to hear. May God bless, Dwight -
Go for it my friend, . . . I don't have anything copyrighted except a book I wrote some 15 years ago. Everything else is fair game........... May God bless, Dwight
Benchmade Activator custom sheath
Dwight replied to zenhas's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Looking good, . . . I'm thinking I could enjoy having a knife like that, . . . May God bless, Dwight -
You're right, . . . it didn't. May God bless, Dwight
Don't know that I've ever eaten fresh trout, . . . I'm gun shy of fish to a certain extent for all the junk we have in our waterways here in Ohio. Hope you all enjoyed it though. The best we have here are bluegill and crappie. But I digress, . . . if you give me an email address, . . . I'll send you a pattern for the pieces. That holster is easy to put together, . . . and is pretty comfortable. When I put it on, . . . I sometimes forget to take it off until I go to bed at night, . . . then it's "ohhh, . . . ". May God bless, Dwight
You need an awl to make the hole, . . . then a blunt leather sewing needle will work fine. May God bless, Dwight
Need help on shoulder holster
Dwight replied to akguy59's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I like 4/5 for my shoulder straps. If you are going to do many belts, . . . straps, . . . etc. might want to think about a leather splitter. Sides, shoulders, all of em run differently, . . . sometimes one end of the hide or side will be thicker than the other end. I got sick of messing with it, . . . got a splitter, . . . now I don't have to try to keep so many different weights of leather. Don't have a 54 inch piece of 4/5 but do have a piece in 8/9, . . . ??? The splitter will handle that right quickly. AND, . . . if you do much in knife sheaths, . . . the cast off can be used as a welt. Milled vegetable tan makes really soft and "easy on the body" shoulder straps, . . . make em a bit wider to spread the weight on the shoulders. All of mine are kinda "long pear" shaped, . . . and are comfortable. Sold two in the last couple months, . . . both customers super happy so far. May God bless, Dwight -
Hey, Seabee, . . . the loops on the holster are actually all one piece of leather. The two loops make it so it will not rock back and forth seriously on you while you wear it, . . . and if somehow one does become unsnapped, . . . there is no probability that you will lose holster and gun. Again it is a cabbage from Sparks gun leather, . . . first place I saw that arrangement, . . . liked it. Tell me more about the type holster you want to make, . . . maybe some kind of sketch, . . . I just may have your pattern here, . . . May God bless, Dwight
Hmmm, . . . weldwood contact cement has never let me down. I even used it to make my vacuum bag. May God bless, Dwight
