Dwight
Everything posted by Dwight
  1. I set my cutting gauge and cut both pieces exactly the same size. Also try to get them both next to each other out of the same hide if I can. Do the ends of the liner and the belt blank. Apply cement and let dry. I then fold over my buckle end so I know exactly where I want my liner to start, . . . and with the liner doubled over backwards above and over my left hand, . . . I slowly feed the liner down onto the belt and use my thumb and forefinger of the left hand to line them up and make em fit right. I then go over the belt with special emphasis on the edges, . . . with a wallpaper seam roller. I then sand both edges flush, . . . stitch gouge both sides, . . . sew, . . . bevel, . . . and finish. It is the fastest and easiest system I've developed so far, . . . turns out belts that don't get complaints, . . . that makes me happy. May God bless, Dwight
  2. Depending on he finish, . . . you may have little to do. BUT, . . . I would take it to a sander anyway, . . . makes it a better bonding surface for the contact cement. AND, . . . I have seen belts that would not come apart once contact cemented together, . . . even without the stitching. You are experimenting, . . . go for it, . . . and report back here and let us know your findings. May God bless, Dwight
  3. FWIW, . . . yes, . . . Resolene is my preferred belt finish. Yes, . . . the liner and blank on that particular brown belt are both 5/6, . . . all stitching of the tongue and buckle keeper done, . . . then the inside and outside are stitched together. My belt keeper folds back between the two layers, . . . and is held by the Chicago screw that is visible in the buckle end of the pictures. I do that mostly so that if something happens to the buckle or if it needs changed, . . . it's a simple and easy job. All I did was take apart a ranger belt I had worn for 20 or so years, . . . make patterns from the pieces, . . . and make my new one. There are many different ways to do them, . . . that's just my way. May God bless, Dwight
  4. Don't forget, . . . it is the placement and design of both the buckle end and the tongue that will ultimately make or break that belt. Make all the parts and pieces, . . . then lay them down on each other in their respective places, . . . do a measurement fit check before you start the sewing routine. Otherwise you can start out with the right pieces for say a 40 inch belt, . . . wind up with a 36 or a 44, . . . just by putting them in the wrong place. Have fun though, . . . and don't get too serious about this leather stuff, . . . keep it fun and it is a whole lot more exciting. May God bless, Dwight
  5. OK, . . . sorry for the confusion, . . . I just couldn't wrap my head around the question. I did a 5 hour drive today, . . . too many white lines, . . . grey matter gets confused easily. My 38 inch ranger belt has a back side of 43 inches long. Look at the pictures and you'll see how I do it. Not everyone does it this way, . . . but not everyone makes pie crust like I do, and I like both my belts and my pie crusts. The back picture is just that, . . . the back of the belt. The same for the front picture, . . . The buckle end you can see it overlaps the end of the belt just the width of the leading edge of the buckle, . . . and the billet also overlaps the leading edge of the main belt piece. But from inside of the edge of the buckle to that center hole, . . . is 37 1/2 inches (God only knows what happened to the other 1/2 inch), . . . and that is where my target is for all my belts. You can also see that I give my customers 7 holes instead of 5, . . . gives em a bit of pizza room if they need it, . . . or CCW space if they need that. That back piece I measured to be sure, . . . it is 43 inches long. Hope this helps. May God bless, Dwight
  6. OK, . . . I'll get in here, . . . A 38 inch belt goes around a 38 inch waist if it is a gun belt, . . . a web belt, . . . a garter belt, . . . or a ranger belt. I must have missed something in the question, . . . and I've made all but the garter belt, . . . May God bless, Dwight
  7. Let me answer the second question first: I use a Tippmann Boss sewing machine, . . . and the presser foot is just tightened enough to work, . . . but not put deep marks on my work. It will in certain holster work I do, . . . but I just rub them out with my finger or a bone tool. But the sewing pattern is another question. In the first picture you see my pattern making tools and a short piece of belt blank. In the second picture the pattern is placed over the belt blank. It is purposely under sized by about 1/16th of an inch so I can visually see it is in the center of the blank. This one pattern can make both the fish tail pattern I put on the black belt, . . . and the lazy stitch pattern I used for the brown one. The third picture shows me marking the points on the belt blank. The last picture shows that I have used the wooden pattern and the gouging tool to make the pattern on the leather. This is simply then stitched onto the blank, . . . and I don't tie off the ends, . . . I lay them out flat in the contact cement (about an inch long), . . . and when the belt is put together, . . . the stitches are not going to move. Hope this helps, may God bless, Dwight
  8. Thanks for the good words, guys, . . . this was a fun project. Even got another buddy to react in a fake conversation where we got the new owner of the belts, . . . to take off his belt so I could measure it. We agreed that just because a guy wore 36 jeans didn't mean his belt was a 36. Proved it when the pidgeon's belt turned out to be a 39 while he's wearing 36 jeans. Anyway, . . . we pulled one over on him, . . . but once he gets the belts, . . . he'll put it all together. Those are my favorite belts to make as well, . . . and of course all stitched on the "Boss". May God bless, Dwight
  9. Had a friend who wanted 2 new belts for her hubby, . . . anniversary gift. Here is what she got. Just a couple new additions to the "finished" leather work of this world. May God bless, Dwight
  10. Thank you, . . . I appreciate the vote of confidence, . . . (so does the Boss) May God bless, Dwight
  11. Davidhebert, . . . did you ever send me your email address? I looked and could not find where I sent you a pattern, . . . suspecting I never got your email address. If you never got the pattern, . . . email me at ciminodw@gmail.com May God bless, Dwight
  12. Thanks, Lizardo, for the good words. As for the money, I just made it all the basic size of modern currency. I know that there were other sizes in the past, . . . some even ridiculous, . . . but most modernistas would look at it with a frown on their face, . . . so I just bent to peer pressure, . . . it works. May God bless, Dwight
  13. Not odd at all, . . . I had the same question, . . . couldn't find decent answers, . . . so I googled up images of the stuff, . . . printed my own. Since it will never be used in commerce, . . . and is not "official" government currency, . . . it worked out. Bump up above in this thread and you can see some of the stuff I had. May God bless, Dwight
  14. Good looking work, . . . but then again, . . . if the Duke is in it, . . . it's gonna be good. You did a real good job, . . . May God bless, Dwight
  15. Do what TSes said, . . . and you will no doubt like that holster. One of the old timers we haven't heard from on here for some time, . . . Katsass, . . . that is pretty much how he made all of his. They were works of art. Search for threads under his name that he started, . . . sit back and enjoy. May God bless, Dwight
  16. This subject was always in the back of my mind until we decided to build a car port. I went on the other end of the car port, . . . built a 10 by 22 room, . . . 9 foot ceilings, . . . with only one window. That window is for two purposes: security, . . . I can watch the window from the house AND I can look out the window and see anyone delivering or stopping by while in the shop. I put in a small vent free propane heater, . . . and a 6000 btu window A/C unit. Heater hangs on the wall inside, . . . A/C unit is in a small hole cut out in the wall up at about 7 ft off the floor. I don't notice any measurable difference in either the propane bill or the electric bill, . . . A/C stays on 24/7 during the summer, . . . heat is on 24/7 during the winter. The key is the insulation. The building has a minimum of 4 inches of styrofoam insulation in the walls and 6 inches in the ceiling and the floors. Outside is 3/4 plywood sheathing and interior is 3/4 OSB, . . . drywall ceiling. Yeah, . . . love my little shop. This will not solve the dilemma of the OP, . . . unless he spent the money to build a shop, . . . within the shop. It could be made of pre-fabbed wall panels, say 8 ft by 10 ft, . . . with pockets in the walls to bolt them together. Home made trusses could hold up the ceiling, . . . provide a place for the insulation. If you ever decide to move, . . . it's portable because it's pre-fabbed, . . . knock it down and incorporate it into the next place. Long and short, . . . the heating and cooling needed to not have problems with rust and mold in the type of shop outlined by the OP, . . . it would scare me enough to not even think about moving there. May God bless, Dwight
  17. The only thing to consider is that the higher it rides, . . . the less "swing" you get of the lower portion, . . . which on some knives I've seen, they almost want a leather thong to tie it to the leg to keep it from flapping in the breeze. On the other hand, . . . if you bring up the knife so it rides higher, . . . the grip has a tendency to get caught on stuff you might bump into in the house, garage, or out in the field. But generally, . . . it simply boils down to the question: "What does the customer want??" THAT, . . . is the best answer. May God bless, Dwight
  18. I usually make a plug out of 3 or 4 pieces of leather glued together like plywood. I then sand the edges on a 45, but not out to a real fine feather edge, . . . I then hand sew it, . . . in and out all around it, . . . then the second pass, it is sewn in where I came out, . . . and comes out where I went in on the first pass. That makes it look like saddle stitching, . . . but is a whole lot quicker for me (I hate hand sewing). And, . . . no, . . . no hole in the bottom, . . . May God bless, Dwight
  19. About all you can do for those things, . . . make a bucket it drops in. What I mean is, . . . make a holster, . . . but do not form fit the thing, . . . don't mold it, . . . just wrap it around the basic weapon, . . . stitch in a toe piece for it to bottom out on, . . . and either put a suicide strap on it or a thumb break so he/she don't lose it. I've had to make a couple of these, . . . that's the way I decided to do them. May God bless, Dwight
  20. Tom, . . . forget the sprayer for belts, . . . Go to Harbor Freight, . . . buy some of their little 1 inch wide bristle brushes, . . . they're about $.50 apiece, . . . mix the resolene 1 to 1 with tap water, . . . brush it on with the little hog hair brush, . . . brush it on in a swirling and back and forth motion, . . . working up a bit of a lather, . . . then brush out the bubbles. It makes for a really nice finish, . . . not too thick, . . . protects the dye, the wearer, and the leather from sweat. I use that process for all my resolene applications. May God bless, Dwight
  21. That's my recipe as well. May God bless, Dwight
  22. My $.02, . . . I make both, . . . flat backed and 50/50. I charge the same price, . . . because I have a different process for each, . . . and basically each uses the same amount of leather, dye, finish, etc. All flat back holsters are run through my vacuum process which basically makes the front. When that dries, . . . it is glued, trimmed, and sewn. I cannot justify charging my customer more for something that does not cost me any more to produce than another product. It gives my customer a choice that HE chooses based on preference without having to go thru the hassle in his mind about is the extra price worth it. In the long run, I believe this makes for a happier and more well pleased customer base. Happy customers always will be your best sales people. Unhappy customers, no matter what makes them unhappy, will never help your business. May God bless, Dwight
  23. Thanks, RockyAussie, . . . really enjoyed the tutorial. I have a piece of veg tan that is simulated alligator, . . . never had a real use for it, . . . and THAT may be a way to use us some of it and get something really useful out of it at the same time. May God bless, Dwight
  24. I really don't have any idea whatsoever, . . . but my guess would be, . . . as loose wound as he was, . . . it was probably open. Ol' Teddy was one of my heroes growing up. Always loved the fact that he was HIS man, . . . no matter what the opposition had to say. And that is really good looking from this end. Make sure you throw up a bunch of pics as you go along, . . . and of course when it's done. May God bless, Dwight
  25. NOW, . . . if that is your first holster, . . . you are off to a fine start, . . . and you got some good advice up above this post. If you take the flat end of a modeling tool, . . . a sponge that is just damp, . . . most of the time you can re-dampen areas you "messed up" in tooling, . . . not too damp, . . . you will have to practice to get that just right feeling, . . . then take the modeling tool and flatten that whole area, . . . for example down at the bottom of the holster. Sometimes when it dries it will kind of spring back up a little by re-dampening it, . . . smoothing it all to the same height. Even if it doesn't spring back up, . . . at least it will all be the same height. Another pointer, . . . forget the rivets. Generally speaking, when I see a rivet on a holster, my first inclination is that this is a new person to holster making. There really is no reason to put a rivet there if the lacing or stitching is done properly, . . . unless you are using it for decorative purposes. It will not enhance the strength or overall life of the holster. AND, . . . welcome to the fun and exciting world of holster making. Somebody said one time there is estimated to be some 300 million firearms in the USA. That gives us 300 million opportunities to be different, exciting, creative, and make the economy grow by $5.50 a square foot, . . . plus dye, . . . plus finish, . . . plus postage. Seriously, . . . glad to have you aboard. May God bless, Dwight
