shoepatcher
Everything posted by shoepatcher
  1. I agree with Trox. This was an early 30 class Adler that was originally black. To me, it does not look that good. I would want to see sewn samples. Plus, this has the old style balance wheel on it. Withowu sewn samples, I would not buy it. shoepatcher
  2. Custom Doug, I would want to see pics of the machine as well as being able to sew some samples which is not always possible. What color is the machine? Black, green or grey. The color is one sign of the age of the machine. Contrary to some of the postings on this board, some parts are no longer available for these early models of the 30 class machine Adler. To answer yoru question, $350.00 may be a good price fo rthe machine once I have seen pics of it. Also, what do you intend to sew with this machine? shoepatcher
  3. As a member of this Forum and a long time sewer and sewing machine person, I was wondering if anyone out there has a list or book on the old Singer screws. I have later edtitions of the Singer screw books as well as the spec book on all the SS singer screws, nuts and rollers. I even have book containing the early Singer screws starting with Screw #1. What I am looking for is the book or books that have the specs on the screws, i.e. the pitch and diameter of a particular screw. Singer's numbers from #1-1500 were for screws, #1501-1800 was for nuts and #1801-2000 was for the rollers. Some selected screws which are still made are available in different sewing machine parts catalogues. Singer in Tennessee cannot even help me with this problem even though i knew they had these reference books available some 15 years ago when I needed the specs on a few screws. I got to believe someone has a copy of the early Singer screw specs book somewhere and i am very interested in getting a copy if at all possible. shoepatcher
  4. Trox, The Adler 5-27 you have is an early version of the Adler 105. Both the 105 and 104 class shuttles used the following screws: Tension screw part #992 00 560 0. Locking screw for locking the tension screw once set is part # 992 00 812 0. If neither of these work, Singer manufactured a number of screws with 3/32 dia. They made ones with a 56 pitch and onces with 64 pitch. Which do you need? Once you know, we can find a screw for you. shoepatcher
  5. Vaquero1, The Adler class 4 machine was the forrunner to the 104 class. The 4-4 was for sewing leather covers, traveling bags, coach works, etc. It has a moveable presser foot. It might be similar to the 104-2, 104-25, 104-6 0r 104-8. I am not certain which one. That would help in trying to find a operations and parts manual. We need pictures of the feet and feeding system to better know what machine is was the early version of. Hope that helps.
  6. You could email your telephone number to me if you do not want to disclose it. My email is Shoepatcher@yahoo.com. Thanks. glenn miller
  7. Gun Nut Is there a telephone number I can call you at? I wanted to ask you a question on one of the machines. shoepatcher
  8. Weaver Leather in Mt. Hope , Ohio carries the machine and they can put a needle positioning motor on it for you. Ask for Allen.
  9. Could we get pictures of the machines especially the Adler 5?
  10. Thank you. Let me know when you have the scan ready.
  11. Bayard, I would love to get a copy of the original manual if you can scan it. I have most of the manuals for the singer shoe patchers. What does the title page of your maual say on it? shoepatcher
  12. Ann, It could be a couple of things. What size needle are you using? If the needle is small, it could be that the needle is being pushed into the hook so that there is no loop for the hook to pick up. I would try and turn the machine slowly by hand to see what the needle and hook are doing. Watch to see if the needle is being deflected by the hook. Too much tension on the top thread will also warp the needle so that the hook will not pick up the top thread. That may be the clicking sound you are hearing. Are you using a sytem 332 needle, same size as the 29x3, 4 or longer needle 332lg which is the same needle as the 30-7? I will have to check to see which needle system your machine is supposed to use. glenn
  13. Hawgman, I have original Adler bobbin winders for $99.00 plus shipping. what color is your machine? shoepatcher <br /><br /><br />
  14. [ Rickybobby. I believe what you have is a Claes Model 30 large bobbin shoe patcher. Pilgrim Shoe brought them in the US under the name Tuffy starting in the 1970's. If so, it uses a needle system #88. You can also use the same needle as in an Adler 30-70 high lift shoe patcher. That system is #332lg or #332llg for leather. The only difference is the Adler needle has a little large shank on it. It may fit in your needle hole or not. Depends on how much wear is in the needle hole. I have enlarged them to accommodate these needles but you must be very careful not to make the hole too large. You only need to enlarge it about 2-3 thousands. Gateway Shoe carries the needles as doe Pilgrim Shoe. I also have a few depending on the size you are looking for. Hope that helps. quote name=rickybobby' date='29 September 2009 - 06:02 PM' timestamp='1254261766' post='125498]<br />Hi,<br /><br />Can someone steer me to a supplier for these needles? We have a Tuffy 88 long arm patcher. The people we used to buy from no longer can/will get them.<br /><br />It is a great machine and I don't want to run out while doing a job.<br /><br /><br />Thanks in advance,<br /><br />Rick J.<br /><br /><br /><br />
  15. Joyshop, I have searched for and finally found a parts manual for the 545 pfaff. It shows the complete illustration for the knee lift assembly on page 96. I can fax it to you so you can determine which parts you are missing since this shows all the pfaff part numbers. It took me some time to find it and I hope it will help you. The parts manual is 117 pages long!!! glenn miller
  16. JoysShop, I have a Pfaff 1245 which replaced the 545. I believe pfaff upgraded the knee lift for the type you have just like Adler did on their 267-373. I do not have a parts list for the 545 but I know someone does. That said, you could then find out what parts you need for the foot lift. I will check and see if I can get you a parts breakdown on that set up. glenn miller
  17. UNC101 I ams still waiting for you to email me. I think I have a way to put a roller guide on your machine so you can sew close to the edge, shoepatcher
  18. Gavingear, The Pfaff 545 and 1245 will sew a maximum thread size of #207. Will not sew #277 unless a lot of machineing is done on the hook and bobbin area. Let me know what parts you are missing . I can put so on to a place that has some generic pfaff parts. shoepatcher
  19. UNC101, I rebuild shoe patchers so let me know what you are sewing and maybe we can come up with something for you. I have a few ideas. shoepatcher
  20. China, To me, it looks like an old Singer 45K that was repainted from black to Silver and they painted over the Singer logo's and removed the Singer brass model number and or the brass Si nger plate. This happened to a lot of Singers when they were rebuilt and repainted. machine looks in goods shape. Let me see a close up of the needle and throat plate and we may be able to indentify the model number to determine what 45 K it is. shoepatcher
  21. The Adler 30-7 is from their older class of shoe patchers. It is long arm, big bobbin, hi lift shoe patcher. It uses a longer system of needle than the 30-1. That system is 332lg Some parts are still available for the machine but Adler quit making alot of the parts for the machine after they came out with the new versions-30-10, 30-50 and the 30-70 which replaced the 30-7. I have a lot of parts for those earlier machines that are no longer available including early manuals and parts list. Let me know if i can help you.
  22. I work and rebuild these machines. You can contact me with yoru questions.shoepatcher
