Mocivnik
Everything posted by Mocivnik
  1. So this is the machette and leather sheath I've made. It's 95% finished, I just have to rivet the handle on the blade and attach a strap (or somewhat other pattent) to hold the knife on the position. I know I can make a loop around the handle, which would be riveted to the back and use a snap buttons to open/close the strap, but I'd like to do it somehow different. Maybe half-strap, such as female part attached to the strap and male attached to the back of the sheath? What are (other) possibilities, what would You prefer?
  2. @matt s: Yeah. The motor will not be hurt anyhow. What the dimmer actually does, is this: The original voltage input is pure sine wave, but the dimmer is just chopping it at the end of it and the "average" voltage is lower. It's also the negative feedback to the electrical network. But, whoever you have been talking to, they didn't tell you about a better solution either, a variac. This is nothing but an adjustable transformer. Which means, you can regulate voltage linear, but the outcome on the motor RPMs might not be (100% will NOT be) proportional. But, it works perfectly, it's not a bad feedback to network, but it's not linear (seen from motor side). But it's usable. The price? Used you can get for 50-100$. Just buy it same (or a bit more for sure) like 500W or 1kW variac on ebay and you're good to go. It's like a potentiometer, nearly without loss (98% efficiency). I'm buying mine this month (for electrical stuff I need, as I'm electrical engineer by education). https://en.wikipedia.org/wiki/Autotransformer
  3. Actually, a very regular dimmer. The one which is for the light, but you have to be careful, that in the datasheet (or just on the packaging) it shows that its availible for R, L and RL loads. But sometimes, you have to change the original triac for a better one, as the m9tor at the start can draw up to10 times or more current than regulary does. I use the dimmera for ~5€ and switch a triac for another 1€ and e-voila Oh, and not to forget to mention, with dimmer, its not very accurate regulation, but its a cheap one. frequency regulators cost couple of hundreds of € each and its an overkill for this application. And yes, I agree 100% with dremel-bench grinder point of view.
  4. Yeah, same here. All I can get, has 2950 RPMs, but I will regulate it with a dimmer (as I regulate all my resistive and inductive burdens). I can get a benh grinder of 350W for around 45€ (40GBP or 50 usd), which I think it's reasonable price. So did I, but I really dislike the dremel to use for this. I don't find it steady enough in my hand, so I'm into something more rigid.
  5. @RockyAussie: umm..with the spike, you can get pretty close aswell...but the "cutting" speed is higher here aswell. @JLSleather: Jup.
  6. @JLSleather: Hah I did drawing in autocad of my own before I started this topic and here it is.
  7. @JLSleather: calculated for you, it's about 333mm/s cutting speed, which is around 33cm or 13inches. More tools than need? Who do you mean this goes to? For me, I want to have all the tools, I need most often and some, which I use seldomly. For example, I want to have better (more expensive) tools for rivets, which are most common in my workshop, but I don't care if I have chinese tools for rivets, which I use seldomly.
  8. @JLSleather Totally agree on that. But the thing is, if I get any of blueprint of the existing one, it might have details, which I wouldn't be aware of while turning my own. That's the only point. PS: Is there any required cutting speed for leather? (Calculated as circumference of the burnisher x turns per second?) Because I'm really struggling, what speed should I use. I can't find any numbers anywhere. But just "something" isn't something, I'd like to deal with. I might have too much or not enough and the edges won't be as they should. @JKHelms: 30$ for a single piece of wood, turned on a CNC lathe is about 20 times too much. I'm just not paying that much for it (not because I couldn't afford that). @JLSleather: Yeah, that's exactly what I got. I have 45mm (around 1 3/4 inches) of beech, lenght of about 40cm (about 15 inches). I'll just turn it out from this, but about 100mm (4 inches) long only.
  9. I need a motor operated burnisher, but now I have a "problem" with discovering the design. I know I can draw and turn one by myself, but does anyone has any blueprints already? I need something for standard sizes, from 2mm up to 15mm (knife sheaths, mostly). I'm talking something simmilar to this:
  10. Has anyone got any blueprints for a burnisher like this one?
  11. Sorry no. But it's mirror one side to another. On both sides bulges are the same. I can add 2 more photos, as I don't have the holster on me right now (but will at the end of the week).
  12. So, I've made this first holster, from the pattern of the JLS leather. I think it came out OKAY-ish, but not the best as I'd like to. I've got this "Problem", where I stitched the holster together, then damped it in warm water (not hot!) and moulded it by the gun. The real problem here is, that I had to mold both sides instead of just one, as now the holster is convex on both sides, but I'd like to be only on the outter side (and flat on the side, that is touching your hip). Does anyone knows, how to re-do the template, so I will dampen only the outter side and it will be enough space for the gun? Thanks for all the help!
  13. Certanly! I'm following him on ETSY, facebook, youtube..everywhere. I really like his style, although I haven't bought any of his paterns yet. Maybe one day...
  14. Customer asked me for possible options for a holster for Sig P229. Has anyone ever made one and has a pattern maybe? thanks.
  15. So I came across this fancy tool, which I'd like to purchase, because my arbor press just isn't for all the possible angles to rivet or punch holes. Anyone knows, where could I find a hand press like on photo below (or link at at 15:00)? It has to have a thread 1/4" and pitch 24 turns per inch on the one side and 1/2" straight hole on the other side?
  16. nr. 2 still availible? how much for shipping to europe?
  17. Mocivnik
    3d stamps
    how much is shipping to Europe for Meyers lacing awl = $7
  18. Since it's nearly impossible for me to get a bottle of Fiebing's PRO DYE in color of DARK BROWN, but I have a project, where I ran out of dye only for a small part left, I'm searching for someone, who is willing to sell some leftovers of mentioned dye (in case you don't need any more) or who could dye a small veg tan belt dimensions of 60 cm x 20mm. It's a small leather belt for around leg for a machette sheath, but I ran out of dye and cannot get it anywhere for now :S Preferably from Europe.
  19. hmm. The thing is, that I cannot get another bottle of PRO dye, as there is not seller selling the small (112ml) bottle under 30$. I already got other dyes, simmilar brown colors, but explicitly for this case, I need the same shade of the Fiebing's PRO DYE DARK BROWN.
  20. Since I cannot get another bottle Fiebgin's PRO DYE DARK BROWN in near future, but I have to dye some piece in near future, I need to know the difference in Fiebing's Leather dye and Fiebing's PRO dye. My first part of the project is painted with Fiebing's PRO dye DARK BROWN then I ran out of dye. I can order now only Fiebing's Leather dye in DARK BROWN color. Will be there any difference in the colors of both things? (there is 1 layer of leather attached to the other).
  21. @DrmCa: Ofcourse. I'm more than satisfied with it. At first, I had a regular arbor press, just like this one, got it for 69€ new one. Then I saw, that I cannot do anything with it, because it's too light and has too short lever, so I proceeded to next press, for which I don't even know, what's it's name. I got used one (but in good condition) for 100€, but it ranges about 160-180€ regulary. Why is this one better? It has better transfer of power. It reaches max. power just 1mm before finish. In calculations, you have infinity power :D The way it works, will be better seen on pictures from this link: http://www.universalgripco.com/arbor-press It has adjustable for 180mm height + it has somewhere about 60mm of pressing. PS: I've been punching out holes with this press only 2 days ago. I could punch out a round hole of 36mm in diameter with only 2 fingers! It was super easy and I highly reccomend it to any leatherworker.
  22. @Northmount: Yeah, I've noticed that. Always, when I use new batch of leather, I "sacrifice" a rivet/snap/whatever and try it, how it will hold. @drmca: Yup. But I've managed to use the first ones on 7/8 oz. veg tan..but I will most likely change them.
  23. @alisdair: thanks! That's just the information I was searching for! Really appriciate the reply!
  24. Are there any snap buttons, that are prefered for leatherworK? I've came across for only these two (different pictures), where one has the "male" part with the hole (second picture), for which I think, that they are meant for thicker leather, while the top picture one's are meant for thinner leather. Am I right or is this user's preference only?
  25. Are there any "rules" about which colors goes with which dye? I'm usually using black leather with silver rivets and brown leather with antique brass rivets, whenever the customer leaves it to my oppinion. Are there any other "restrictions or regulations"? What color of the leather goes best with polished brass rivets? I'm talking about veg tan, mostly belts, knife shaths and pouches.
