kgg
Contributing Member
Everything posted by kgg
  1. It looks like they are holes to allow the thread to come straight up off the spools. kgg
  2. Looks good should be able to remove the odour and fine over spray. I am going to assume it's vented outside where I would suggest putting a thin filter to catch the fine over spray so it doesn't stain your exterior (siding/brick/wood). kgg
  3. I do agree that the Juki 1541S would be a lot better machine and choice if the budget allows. kgg
  4. I think you are on the right track with looking into the Juki however if you only want / need a walking foot I would suggest that you look at a new Juki DU-1118n for about $1200 US with a servo motor set-up. I think the Juki LU-563 is getting a little long in the tooth and is way over priced. If you bought the new Juki DU-1118n you would still be less then the Sailrite Fabricator and have similar capabilities. kgg
  5. I would recommend you install a metal roof, it will be a little more expense but faster to install. The rain will run off easier and with such a low roof profile any snow will have an easier time sliding or snow raking it off. You will find that it will be warmer in the winter and cooler in the summer particularly with the air gap of the 2x4 strapping. Here your 25 year (haha) shingles last about 6 to 8 years with serious deterioration starting around year 3 to 4. A lot or all of the shingles have become ECO friendly, less or no real tar, and wind up in the landfill quicker. kgg
  6. Maybe you can get the local wildlife / animal control or trapper to live trap and relocate him. kgg
  7. Nice to know what is lurking around on the property when the lights go down particularly if you have animals. I have had problems with bobcats and fishers in the past, I think the fishers were nastier. Now since the government has released cougar in the area some of the neighbours / farmers are having problems. I think it if it was on my property it would have a terrible reaction to lead and do the 3 S's (shoot, shovel, shut-up). kgg
  8. Try Landis International ( http://landisinternational.ca ) for parts, their phone number is Toll-free: 1-800-634-0806. kgg
  9. The only thing I can add is to upgrade whatever machine you decide on by getting it with a servo motor for more accurate speed control. The speed control learning curve of a servo motor will be so much easier, less intimidating and thus provide better results. I am going to assume you are using a serger to do the edges, if so you my want to look into using a folder and/or a binding attachment to accomplish similar results but stronger rather then investing in another machine. kgg
  10. I agree whole heartily with Wiz on this one. I have been tinkering with the idea of getting a patcher for sometime as an addition to my flatbed Juki and find the Chinese patcher discussion very interesting. I would not be expecting the Chinese patcher to do exceptional work, have a smooth operation profile or look pretty. It just needs to be able to do limited basic sewing that would be easier done with a patcher machine. The cost saving for me over some of the brand names (new and used) is substantial particularly considering the amount of use I will give it. kgg
  11. Have you contacted the dealer / supplier? They maybe able to offer some suggestions. If you got it from Amazon you maybe able to return it, if from Ebay you maybe out of luck. kgg
  12. Since it is just trying to warn the foolish / stupid so I think it should have had a couple of more tags on it. Big red arrow on the blade with the words "Maybe Sharp." "Operator must be trained in the proper use of a deadly weapon and stored in a locked weapon safe at all times." "Keep body parts away from sharp end, not recommended for picking ones nose or a** scratching." kgg
  13. The needles according to the Sailrite site for the Fabricator comes with System 135 X 17 needles up to size #24 which would be for v207. Those needles are made for material (cloth / canvas), for leather and vinyl you need to use System 135 X 16 and for a thread size of V92 you could use a # 18 on the low end or a #20 on the upper end. I would use the #20 needles with V92, as it would provide a slightly larger hole for the thread to slip through. kgg
  14. From your bio you mention your speciality is holsters for that I think you are going to need something in the class of a Juki 441 machine probably like the Cobra class 3 or 4 class, Cowboy 3200 or 4500. Since you are in Alberta you may want to checkout Leightons Mach line ( http://www.leightons.ca ) in Red Deer or Longeview Leather ( http://www.longviewleather.com ) Cobra dealer in Longview. See what they recommend and have used capable of sewing your stuff. Another alternative maybe a hand lever machine similar to the Tippmann Boss or the Cowboy Outlaw. Which ever way you decide to go it is not going to be cheap. kgg
  15. Have you checked out the following video, it my offer so help in setting the servo motor even through it is for a Juki 8700. kgg
  16. I agree that general instructions when dealing with dog owners generally is to give basic instructions. Like the dogs and forget about being to specific. Hell, we see it all the time that an owner buys a collar, puts it on the dog and forgets about it. The only time it is removed and hopefully cleaned is when the dog gets groomed. I have even had to cut collars off, particularly the metal choke chains. Drives me nuts. Just getting them to remove the collar everyday is a step in the right direction of keeping the dog healthy and the collar maintained. Personally I like the Martingale style collars leather or nylon because it is always worn slackish around the neck until you need it too slightly tighten. kgg
  17. Do as Constabulary suggested, check for a label. The thread spool should usually be marked with a label on the inside of the bottom of the spool. With newer sewing thread it should be marked as V ##, T## or Tkt ## plus the manufacturer and type as well as other info. I have seen some of the less expense Chinese bonded nylon with just the Tkt size on the label. The difference between V69 and V92 is same, only .0018" or .0045mm difference which can make it hard to distinguish at times so sorting them out is a good idea. kgg
  18. The forum started to work correctly for me sometime yesterday. Thanks again, kgg
  19. Nice informative pdf. I would suggest adding a couple of things: 1. Before purchasing any firearm ask yourself is this the right calibre, barrel length and what you would like to do with it (target shooting, hunting, protection, etc.). 2. Have the owner pass the revolver to you with the cylinder open so you can determine it is unloaded and safe before handling it. See if the gun fits comfortably and is balanced in your hand. 3. Since appearance is important in helping to determine how the gun was cared for check visually that there are no major flaws like deep scratches or dents with the finish, modified sights, stripped screws, frame cracked, buckled/split/bent/bulged barrel, cracked / modified grips or any major modifications attempted. Does the finish look different on the barrel, cylinder versus the frame indicating parts replaced. 3. When checking the barrel look for excessive wear to the internal rifling of the barrel. The sharper looking the edges are the less wear on that barrel. 4. If the gun checks out arrange to go to a range and test fire to make sure it suits your needs / comfort level. Maybe a nice well cared for XX calibre but can you properly handle / control it or is going to sit you on your butt every time you squeeze that trigger. My thoughts, kgg
  20. I pity you Johanna, there is also hiccups when software or hardware is upgraded or changed. Some things don't like to play nice with other things. Best of luck, kgg
  21. That is great news, I'm sure Johanna will straighten it out shortly. Thanks for the update. kgg
  22. So I not any crazier today then I was yesterday. That means it is happening in Canada and Britain. kgg
  23. Not sure if I have this in the right place. Has any had the problem of not being properly redirected to the Forum page? I am being sent to the index page even through the location is suppose to be ( leatherworker.net/forum) have had to go through the index page and then click on Forums. It started to happen last night for me about 10pm. kgg
  24. I think you maybe better off with a steel bodied portable walking foot to multiple layers. Reliable Barracuda (~$500 US at Homedepot), Sailrite LS series(~$900 US), Techsew 611(~$500 US) come to mind. kgg
  25. Harry just buy it and tuck it amongst the rest, she'll never even notice. kgg
