Everything posted by Frodo
I thought. I was the only person who tossed stuff across the room or out the window
Stitched patchwork leather pieces for sale - Great for a project
Frodo replied to PaulineSul's topic in Old/Sold
We all started out not knowing how to sew 1st step, sit in front of the machine and turn it on the rest will follow -
I was asked by another reloaded WHY? Hdd rd said he saw no reason to have bling bling brass, that his dull brass was good enough my answer turned him into a wet tumbletiu Yes, You are 200% correct that dull brass tumbled in lizard litter or corn cob is clean enough and the primer pockets are also clean. My eyes are not what they were when I was younger and the price of new brass cases is high. I am not trying to compete with the bling bling crowd but a am competing with leaves on the ground My bling bling stands out, I can seee them and pick them up. Dry media tumbled gets lost and that costs me money56F760F3-44E1-49F1-9866-52C8D867AED0.webp F7ABDFA5-9739-4300-82DE-E5631227ECD4.webp
you first tumbler I made was an ice cream motor I use Ss pins instead of dry medium once you go wet you will never tumble dry again
Washing machine motors are fantastic so are printer motors if you are into DC. Find a hospital bed motor Tip on the washer motor when you salvage it from the washer get the cradle it sits in and the wire harness
I was digging in an old tote and found this wallet that I made back when I first startedI had no money for leather so I used an old 3” wide work belt laced together with paracord the rivets are live 22lr
I have when in a pinch made molds using wood. If you are skillfully with a jig saw and a sander you can make a mold in a coupe of hours find an image online of the firearm and make sure the scale is correct cut and paste onto the wood and cut out
I make the front of the holster 3/8” larger than the Back section sew them together wet the front section and not the back shove a mold into the holster and vacuum seal it. this, for me, leaves the back flat and only the front is molded little tip/trick place the holster on a 2x4 before vacuuming
Sorry guys, can not show you the finished product, The owner was here and it is gone
Under a flap, no buckle the buckle you see is just for show, a magnet is imbedded in the leather of the belt
I am being asked over and over to provide CCW/Cellphone holsters that hide the fact you have a gun the gusset is a 1 1/2” wide belt the closure is a a belt held closed using a magnet the inner bag has a simple flap that hides/protects the gun and the cell phone shares the bag I am working on this one
Searched? Having lead in your wallet is not a crime you can not be detained and searched for walking down the street
Lead WOOL. Spread it on on a cloth beat to a consistent thickness sew it between layers do not suck on your fingers while working with lead or chew on it
A 2 slice toaster with a crumb pan
Glued and sewn A tip for you apply glue to both pieces allow to dry apply a second coat Then sew
I stole that line fro an engineer in Texas the plan called for a floor sink to be installed at a location that had a 4’x2’section of duct work in the way I issued an RFI. And waited for an answer engineers answer was to forcefully with great care manipulate the top of the duct work to accommodate the p-trap (IE. Beat it) This work was taking place in a university kitchen that was in operation. I came down my ladder stole a stainless steel mixing bowl cut round hole in the duck and set the bowl in it with the p-trap nestled in the bowl like a baby bird The salad chef looked for his mixing bowl for an hour before he gave up side note, shout out to a plasma cutter called Drag-un awesome awesome tool
modified my arbor press removed the geared press arm using a 1/4 rod coupling forcefully with great care, drive the coupling into the tool recover hole in the. The presser arm grind the rod coupling so it fits OnTo the aluminum stamp using a drill bit, remove the threads inside the rod kkcoupling. Cut a 1/4” rod 1.5” long , grind one end to a dull point nowlets use the machine 1)…. Flip/invert the anvil that comes with the press. Use this tool to press large acrylic stamps, I have pressed stamps up to 6” diamieter 2). Press for stamps 3).. remove the selector wheel from a broken hand punch, remove one of its cutter dyes Ram will press down on the cutter dye to punch holes
I have a few different types of snap setters i have the one shown on your photo All of them are a pain to use , I bought a box of snaps in the sewing section of a big box they came with a short stubby set tool I have found that this little tool works better than any other I have It folds the metal over correctly and the snap does not have to be beaten with a hammer to close added bonus use this tool to set large snaps where the leather is not thick enough
True story [I came home one day an announced I was going to buy a rolling frame and build a shovel head in a jammer ridged frame. with a solo seat and a P pad wifey did not miss a beat, she stood up grabbed her purse and said COOl !!! Let’s go pick out my Piano wat? We are not getting a piano, they cost $5000.00. Hell no!! she said no piano no bike !!! ya’ll, We still have the piano in the living room and the bike has been long gone
well done!!!!
Large frame pistol case grey 6 oz chrome tan the liner is mustard goat skin Using Dwights blue gun as the model
