Exactly. I have no idea where that came from, but the old guys at the saddle shop I used to hang out at as a kid did it R to L, and 'near to far' so to speak.
I cover EVERYTHING. The antique will only stay in the impressions. And I let it sit for maybe 10 minutes. Here is a Christmas card I did, and then antiqued. This was Sheridan brown. But I do oil the leather before the resist. This will darken the leather a little, or a lot, depending on how heavy you do it. After several hours, preferably overnight, THEN I do the resist and then the antique.
Never underestimate the damage that a crew of teenage boys can do to even the best of tools. I came in the door just as one of them was hammering a scratch awl through his leather on a marble slab. He "Didn't want to scar the table top".
Very nice for a first go. And I would second Don Gonzales. He usually has a free pattern you can download, and then a series of videos taking you through all the steps. One tip, when Backgrounding, twist the tool slightly as you cover the area to avoid a 'pattern'. This will give you a smoother background. Here are a couple videos on it.
using the background tool in leatherworking - YouTube
Basic Leather Working Pt. 8 - How To Use The Backgrounder Tool - YouTube
There were two pairs of those at the Scout camp I worked at. They had the same issue. I always assumed it was due to the abuse that a couple hundred 11-18 year old gave them.
Almost all of my work is either holsters, sheaths or saddle/tack build or repair. The only belts I've done in 15 years were for me. Wallets? Did one for the grandson.
Perhaps, but I have never had the antique color the resist. I know that the resist is supposed to be stirred, perhaps it wasn't stirred enough? I just shake it up good.
Just 85% of everything that has been said. Try using them on a holster for a large pistol that is 1/2"-5/8" in the trigger guard area. I'll pass on chisels.
Punching the front, then the back. Using a block of wood to hold it down. Using an array of tools for tight curves, gentle curves, straight lines. Yeah, seems WAY faster than gluing, stabbing, stitching.
The first thing that comes to mind is that the leather used in saddles is far too thick for projects such as wallets. And second, most of us would refurbish a saddle rather than cannibalize it.
A truly sad thing. And becoming more common daily. Over here in Ellensburg, Central Paving had a truck and tool trailer stolen right out of their yard. The company I work for had a large trailer mounted generator stolen from a jobsite. They used to hang horse thieves. I think they were onto something.
The antique won't color the leather if you used the resist. All it does is stay in the deeper impressions. If you want it to color the leather you need to apply it without the resist.
I use the wooden mallet that came in the 'starter kit' I bought for the grandkids. I sanded it smooth and stained it. I use it sideways to 'press' pieces that have been cemented, and use the faces to tap stitching and lacing.
Your own dye will accentuate them the same way. If you can see it in undyed leather, you will see it when it's dyed. And while it IS a natural thing, it is NOT in/on all sides.
