Everything posted by AlZilla
Thanks, guys. Here's the operator side. The tag is apparently obliterated but it and the 2 pins above it look suspiciously like something Singer would have done. It does bear a strong resemblance to the W&W 12 but I think it's probably post buyout of W&W by Singer and based on their #12.
Can anyone id this old industrial machine? I have another picture from the operator side I'll upload later, much too big for now. https://maine.craigslist.org/atq/d/dresden-antique-sewing-machine/7674315127.html There is no kind of identifying anything on the machine. There's a brass tag on the column but not a thing remains to be read. Thanks
I never see anyone recommend Leather-N-Rich but it works fine for me. The hat in my profile pic has been rained on quite a few times and always dries like it never even happened. I've used the aforementioned Mink Oil with similar results but it doesn't have as bright a sheen. I did see a respected leather worker (Red Nichols, maybe?) criticize it once upon a time but can't remember exactly why.
I love that! Could we see the seam where you joined the cover together? I don't quite understand "The strap on top is to hold the bottom in the rolled up state."
Well, I'm practically stunned it wasn't a bearing. How about putting the belt onto the naked shaft and pulling some tension against the shaft as it rotates to isolate the noise to the motor or pulley/belt?
The backs of those snaps come in different lengths for different thicknesses. It appears that your back is too long for your project.
- 7 replies
- tandy leather
- hand press
(and 1 more)
It doesn't make it with the belt off but does with the belt on. It's got to be a bearing. Take their 70 euros, replace the bearings and never buy another vevor product.
Well, he was. Now the nice witness protection people will be moving him ... again.
So, would something like a billfold suffer from this problem, too? What would be the best part of the hide to use for applications that are going to have 180 degree folds? Maybe something other than cow hide?
I've always assumed that when we say the strength is in the flesh side, it means abrasion/cut resistance, too. It looks like they were stretching the test straps to 1.25 times the original length. Too bad they didn't go until they broke.
The wide nylon web strap makes a nice bag look cheap.
Singer 111W155 Cleaning and adjustment
AlZilla replied to DerekWeaver's topic in Leather Sewing Machines
Here's part 1 of 2 for going through a Consew 206, close enough for your Singer: -
First things first, it's better than anything I've done and I like it. But, you did ask ... I think if the beveling around the figures (and really all the carving), were sharper, it would all pop more. Some of the guys and girls around here doing leaves and acorn themed stuff really get their stuff to pop. I think they almost undercut the carving. I admire the deft hand at symmetry in your stamping. Very nicely planned and executed. Does that buckle not require holes in the belt?
This pic is part of my desktop and what got me thinking about it. It's a wild bunch 1911 holster. I'm machine sewing but I could stagger the seams a bit.
So, the usual rule around here is to use 277 thread for duty holsters or anything that's going to see heavy use. The formula for seam strength for the lock stitch is: Stitches per inch x thread strength x 1.5 = seam strength. 277 thread has a breaking strength of 45 pounds. 138 is rated at 22 pounds. The question I have is, why couldn't I use 2 seams, closely spaced side by side on the outside edge of a piece using 138 thread? Purely an aesthetic question.
I use one of these things from Amazon to set domestic bobbins to around 25 grams of pull. Not fancy but it works.
Don't even know what a tally book is, but maybe I should start making them. Your stitching is getting steadily better.
I've done that sort of thing a few times. I'd concur, toss it. Consider the cost tuition in your leather crafting education and buy something else. Or, maybe you just like fixing things, which I understand. It's not always about the cost. Is that brand something special?
I ran into a listing for a "Racing Sewing Puller". After I figured out that "Racing" is a brand and not some new sport, I dug into what kind of thing it was. I see where "It is useful for sewing large and heavy workpieces like leather upholstery, tents, and car covers." I could see where it might be useful. But it appears to be used behind any old sewing machine and I'm wondering how the feed rate is coordinated with the sewing machine. It seems like you could overrun or run behind your sewing rate and either pile up material between the two or pull faster than the sewing machine wants to feed. There's a real dearth of information to be found. Anyone know how they work? Just curious, really.
Very nice. Did you record the rest of the work? It'd be interesting to see it through. Thanks!
An overnighter in Evaporust might help.
Don't forget dye and a way to apply it (dauber, dip or airbrush). I'd argue you don't need the tokonole or edge paint, but that's just me. Also, I'd add beeswax. And probably other stuff if I really sat down and thought about it... How about a swivel knife? And a stitch groover? Oh, and you'll need a slicker to do those edges ... What a person needs to get started is one of those questions that could break the internet. Here's a selection I found on Amazon: https://www.amazon.com/Jupean-Leather-Supplies-Instructions-Stamping/dp/B07THQ8QM4/ https://www.amazon.com/Leather-Supplies-Stamping-Stitching-Punching/dp/B07QY7CP72/ https://www.amazon.com/Realeather-Leathercraft-Instructions-Materials-Projects/dp/B01AMX0KWC/ I started with the 3rd one for $50. 20/20 hindsight says either of the other 2 would have saved me money in the long run. But that's for the things that I want to make. And a couple of those things from the higher priced kits are in my amazon cart right now to the tune of about $30. I got involved in this because I thought $150 was too much for a new leather hat. $500 and many hours later, I had my $150 hat. (and let's not talk about several thousand $$$ for the sewing machines that followed ..) Good luck with it, it's a rewarding skill to have. And a rabbit hole.
- 24 replies
- handbag
- watch strap
(and 3 more)
If it's a snub nose 38, a J frame holster should work, assuming it's a 2" barrel. After that, there are hundreds of variations on 38 caliber revolvers, up to 8 3/8" barrels. I've got a generic holster pattern made out of plexiglass that can be modified to fit most anything. If you get desperate, I can trace it onto paper and scan it in.
I haven't regretted starting with a beginners set of leather crafting tools. I've accumulated a lot more since then, but it got me a base of things to start with. My kit included a couple of projects to do, a sheath, wallet, etc.
- 24 replies
- handbag
- watch strap
(and 3 more)
