Mablung
Everything posted by Mablung
Holster making literature
Mablung replied to JLopez38's topic in Gun Holsters, Rifle Slings and Knife Sheathes
@JLSleather, thanks for the pattern instructions. That simplifies the process for me greatly, which my non-spatial, non-mechanical mind needs. I’ll use this for making a couple pancake holsters and refining others I make. When adapting to more of a 80/20 molded holster, where do you generally place the stitch lines? I’m planning to remake an AIWB holster I made a while back, in part because I think it stretched around the stitch lines too much. Trying to figure out how to keep a snug fit without making it excessively tight (some of which will come from improving my boning technique, I acknowledge). One complicating factor is that I have a WML on this particular pistol. -
I do not, though I have been considering getting a machine. Not in the budget for a a bit yet, but it sure would make things easier.
Couple shots of the vertical edge stitching and finishing. At a couple points it’s truly atrocious. But the rest actually looks halfway decent on the exterior.
Yeah, hand stitched. I didn’t fully appreciate just how small the stitches are until I looked at the first major line on this thing. Good grief. I used a set of Craftool Pro Fine stitching chisels I have, I think the 3mm ones. I like the narrow holes because they close up well, compared to my regular Craftool chisels. But man do the holes make it difficult to pull a large-eye needle threaded with 0.8mm Ritza thread through. I learned the benefit of using a stitching awl to stretch the holes. (After I made a real pudding of my stitch lines along the long seams of the cover flaps, but that’s a different set of photos.) Anyway, because I’m a glutton for punishment, I’ll make another soon that will fit my larger notebook. I’ll post that one, too.
All but final trimming and edge work done. The stitching is atrocious, as I experimented with using my chisels as a pricking iron and finishing the holes in the cover flaps with my awl. My goodness the stitching process was tedious and time-consuming, absurdly so. But I learned a bunch of valuable lessons in making this thing. Looking forward to finishing it and putting it to use. Color is wrong in the photo, but I’m too tired to fiddle with the pic. It’s more of a medium brown and not nearly as yellow as it appears.
I like it. Good stuff, especially that portfolio and the handbag. I like that bag particularly; that shoulder strap really pops with that leather color and surface finish.
Plain gussets stitched either seam in or out seem pretty strong alike. I’ve made them both ways, although my inclination is to say the seam in is stronger. But that adds a couple complications to construction, although none that are insuperable. (I made a tote bag for my mom that is 5/6 oz S.B. Foote boot leather that I turned out; that thing is bombproof.)
Oh, I gotcha. I must have misunderstood what the real issue was. It looks almost as though the main panels are wider at the top, like trapezoids. You might try using some heavy cloth or craft foam of a similar thickness to develop the pattern from trial and error.
Re: dip dyeing technique, Chuck Dorsett, who does the Leather Element videos for Weaver Leathercraft, recommends punching stitching holes before dyeing so that the dye penetrates the holes, and then using a piece of small-gauge wire hooked into a stitch hole to draw the leather through the dye. I haven’t tried it personally, but that would eliminate the dark spots from your fingers. Mr. Dorsett also wears gloves to keep dye off his fingers, which I do sometimes. FWTW.
I’ll share some tomorrow or Saturday. I’ve decided, after a few weeks of using it, that I need to adjust the bevel at a couple points, as I was less consistent with the angle than I thought. But overall it’s in great shape now and extremely sharp. I’ve nearly skived my finger once or twice due to mild carelessness regarding hand placement.
Skive the edges well and you can probably keep the seam bulk to a minimum.
That’s not a bad design idea. I might borrow it for making a beater strap for my Tissot I bought a month and a half ago or so.
That’s going to depend significantly on what leather you use and what weight. That bag looks like pretty thin chrome tan, with a very shiny finish to it. Probably no more than 2/3 or 3/4 oz stuff. I’ll bet the leather is skived at the side cutouts to avoid creating bulk.
New to stamping, first project help need
Mablung replied to Mocivnik's topic in Floral and Sheridan Carving
Here ya go. This is one of the tutorials and the other can be accessed from the topic listing under the subforum. -
A lot of the Craftaid sheets will show you where to use what tool. There are also YouTube tutorials that show how to do it, including tool order. Others have done oak leaves and shown their tools, on here. In fact, I think one of the tutorials pinned in the carving forum is for an oak leaf. ETA: There are two tutorials in the Figure Carving forum. That would be the better one to look at than the Sheridan/Floral Carving material (this subforum) because it’s a different style. -
Definitely substantial stuff, although I wouldn't think suede would add appreciable weight or bulk. But that may also depend on the volume of bag you're making, so a microfiber or other fabric liner may make a noticeable difference. it is certainly true that fabric is thinner and lighter than suede, so that may answer your need. Something like a nice flannel might make a decent pairing with veg tan, depending on the style of bag and what all you've done to the outside.
Look about on here for posts about lining bags with fabric; folks use a wide variety of fabrics, and much can be learned from the preexisting posts about what people used and where to get it. But if you're looking to reduce the weight of the bag (as the wording of your post implies), while using fabric instead of another leather as a liner will help to an extent, you might need to consider using a lighter exterior leather or a leather of a different type to reduce the weight significantly. That will likely make the biggest difference, as suede is not heavy stuff, either in the sense of literal weight or the sense of bulk.
I think this was just a result of my not measuring generously enough and then taking it down too far when trimming before stitching. I think sometimes times do shrink just a bit after dying, but not enough to create quite this issue, at least in my experience.
Well, it is too bloody narrow for the notebook originally intended to go in it. 1/16” of an inch or so too narrow. I have another, smaller notebook that ought to fit and some margin around the edges that I could cut off to adjust for the smaller dimensions (and clean up my edging and stitching, which are a mess). I’ll probably have to do that for now.
Well, I dyed it light brown but didn’t dilute the dye enough and then ran out before I could get the dye job even. I used a dauber, since I don’t have a tub big enough or enough dye to dip-dye it. It’s a bit blotchy as a result and a coat of NFO didn’t even it out. I’ll probably have to make the overall dye job a bit darker before I resist and antique it.
Not a bad rule of thumb, as long as it’s used as such and not as a set rule. But it sounds like you’ve got that straight in your own head.
Has anyone attended Jim Linnell's classes at Tandy?
Mablung replied to SUP's topic in Leatherwork Conversation
Exactly! Though, people in my office would faint, if I walked in carrying some of my knives; they already look at me like I'm nuts, when I bring my regular pocket knives. -
@toxo is right about that. Stitch length, not edge length, is the more important measure (although the couple gusseted bags I have made were close enough on both measurements that I was able to cut my gussets the same edge length and then do only minimal trimming). I’ll add that the details of the construction make a difference as well. Whether the gusset is curved or straight, darted or flat, molded outward as is done with veg tan bags sometimes, or a soft oil tan makes a big difference. So does whether the bag will be turned out after construction (like I had to contend with when making a bottom gusset tote bag for my mom). Lots of measurements and geometry are one’s best friends here.
As the quip goes about men telling their wives how many guns they need: “Just one more.” Same applies to knives, lol. I have a whole variety of knives, leather and non-leather. One cannot have too many knives, even if only a few are carried regularly. -
I’ll ask for suggestions on this part: I’m trying to decide whether to dye this thing. On the one hand, I kinda like the natural look, but on the other hand, a nice brown sounds nice, with some antiquing. I’ll use dark brown Ritza 25 0.8 mm thread to stitch the notebook cover sleeve panels and the perimeter. Maybe that will contrast nicely with the natural veg tan conditioned with Obenauf’s Heavy LP, which will darken the leather a bit anyway.
