Mablung
Everything posted by Mablung
What tool as far as you know doesn't exist but you wish it did?
Mablung replied to x546JP's topic in Leather Tools
A turbo encabulator. -
Ah, I gotcha. I bought a prefinished blade blank. What sort of equipment do you use to cut the billets? I assume you're getting it already heat-treated, since you didn't mention heat-treating in your process of work.
What do you think of the edge and grind? The one I have didn't have a final edge, which the guy who sold it to me at a craft fair told me was purposeful so that the end user could sharpen it as he liked. I did notice the primary bevel grind and secondary bevel grind both were a little off-center and the secondary bevel is thicker at the base of the blade than at the tip, which has made sharpening the secondary bevel a touch challenging.
That is fantastic! I’ve got a small Alabama Damascus Steel knife, and I love it. No nice grips on it, but one day I’ll make a good set. That sheath is beautiful.
Lovely work. Your work brings some different things to the table on this forum, as not many people play around with paints or pictures in the way you do. I always enjoy looking at it, and this stuff is no exception. Great work.
What are your preferred bevelers, given your emphasis on ease of sharpening?
Is your question how to skive, or how to edge bevel? Not to sound at all condescending, but it sounds like you're not clear on which is which. An edge beveler is used to take the sharp, 90* corner off the edge of a cut, making for a nicer, rounded edge once slicked and burnished. Skiving refers to reducing the thickness of the leather, usually along the flesh side, by tapering from the thicker center out toward the edge, where it gets thinner. If your trouble is getting a consistent edge bevel, look at your beveler to make sure it's sufficiently sharp. Also make sure the size of beveler you use matches the thickness of the leather (although it doesn't sound like that's your main issue). Critically important as well is orienting the beveler at the correct angle to the leather, then using consistent pressure and angle of attack to cut the corner off. Personally, I find my beveling suffers the most when I don't keep my beveler angle and pressure consistent.
First off, what tool are you using for skiving? There are a couple of hand-use skivers that help provide consistent edges, using replaceable blades. Regardless of the tool used, practice practice practice is a major part of the answer. I'm not very good at skiving just yet, but that's partly because I use my round knife and am still working at keeping the blade angle of attack consistent.
I've used a sponge to apply small amounts at a time to accomplish the same end. Easier to control the application that way. One can do the same sort of thing with a spray bottle, like the mister bottles Tandy sells.
Hmm. I don’t know a ton about copyright law, but I know a little bit. I’m wondering if he could actually enforce that “10 items per year” limitation. Selling the pattern as one’s own, without any change to it or with only minimal changes that aren’t enough to make it a derivative work, yeah, that’s a violation of the copyright. It seems a closer call with regard to the items one makes using the patterns, however.
Help -how can I stitch?
Mablung replied to rastanley's topic in Saddle Identification, Restoration & Repair
One can also attempt to force a size 4 needle through a previous stitch in a tight hole and bend it to curve that way. Results not guaranteed. -
I’m not usually huge on basketweave, but I REALLY like the pattern you did on the wallet back. Very nice.
Lol, I gotcha. I was confused by the "flat round" series of adjectives and thought, "I think I know what he means, but I'll clarify anyway to be sure..."
- 19 replies
By “flat round bar of wood,” I assume you mean one that is smooth, without additional grooves cut in its perimeter?
- 19 replies
I like those, as well as the OP’s. My sister would like something like this (my mom not as much, but maybe).
How long have you hung it? And are you trying to eliminate all signs of wrinkling, or just the main fold lines?
Beautiful work! The tooling is great; looking at your shading especially, as I'm just learning to do that and trying to get it down. Your daughter's paint work is great as well. Two thumbs up.
What sort of carving? A ornate floral, simple figure, something in between? And how much detail do you put into the wet molding? Every line of the implement, or more of just a general shaping? The detail and whether you want the front piece to be more decorative or to supply more retention make a difference in what you carve and on what sorts of pieces.
Seriously. I didn't realize how difficult it is to pear shade smoothly until I was trying on this thing. Thanks. Hopefully I'll get it at least stained tonight, though I probably won't finish the rest of the construction until either later this week or sometime next week.
Thank you. I’m looking forward to staining it and finishing the construction. I’m going to experiment with some Angelus Gel Antique to stain and antique it; we’ll see how it goes. The sheath needs a little revamping in terms of construction design, so it’ll probably get redone, but I’m looking forward to finishing this version.
Definitely not finished yet and very much in progress and very much flawed. But I rather enjoyed doing the leaf on this thing. I got carried away with the cuts on the acorns, but I can change that on the next iteration. I’m proud of my tooling progress, which is why this one is in the “Show Off” forum, but I’m always looking for suggestions on how to improve, so critique away. (Ignore the bevel line on the right side—that was me practicing with a new beveled, and that’ll get stitched through on the back. This sheath is much more a practice piece.)
Wow, what a concept…I mean, if that’s how you turn animal hides into shoes, where do the leather ones in the stores come from?
