Members Constabulary Posted April 13, 2020 Members Report Posted April 13, 2020 (edited) I took sooooo many pictures while puzzling together this setup but most pics turned out to dark. Tried to brighten them but they were just too dark. So here are just a few of the done setup. Now this is my setup for the 51wSV2 post bed machine I have restored and I also want to use my 107w1 and 143w in this table. Wanted to have a smaller foot print stand with folding extension. So I cut down the center bars by 5" and glued them together with JB Weld and some thread rods and dowel pins (can post pictures if someone is interested). The new table top is beech wood oiled with boiled linseed oil - that makes a nice warm vintage look (looks much better in real life). I added a DIY 1:3 speed reducer and the motor is a 1975 made Italian OCEL / Moretti step motor (I think it is called step motor - we say "Anlassermotor" - its not a servo motor). Works very well so far but I´m not sure if I will keep this motor but I will test it for a while. Some pictures... When I was done and insert the 3 machines one by one I figured I had to make a small correction in the cut out... and then... the router guide moved Have to fill it with some wood filler Edited April 13, 2020 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
CowboyBob Posted April 13, 2020 Report Posted April 13, 2020 WOW, That came out real nice,those older models always seemed to work better than the newer ones with the timing belt! Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Moderator Wizcrafts Posted April 13, 2020 Moderator Report Posted April 13, 2020 This setup made my heart skip a beat! Well done Folker! Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Gregg From Keystone Sewing Posted April 13, 2020 Members Report Posted April 13, 2020 Very nice work, love the attention to detail. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members Scoutmom103 Posted April 13, 2020 Members Report Posted April 13, 2020 That looks beautiful. The boiled linseed oil really warmed up the beach wood. Would be interested in the 3 hours ago, Constabulary said: Wanted to have a smaller foot print stand with folding extension. So I cut down the center bars by 5" and glued them together with JB Weld and some thread rods and dowel pins (can post pictures if someone is interested). Quote
Members jimi Posted April 13, 2020 Members Report Posted April 13, 2020 Great job as usual Folker, Nice BLACK machine there and great job on the table also, when you open your OLD IRON shop i will maybe pass by and buy a machine from you Lol...Interesting little sliding drawer there. Quote
Members dikman Posted April 13, 2020 Members Report Posted April 13, 2020 Very nice job! I did something similar but couldn't bring myself to cut the metal frame!! Interesting solution to placing the drawer, I had to leave mine off. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Constabulary Posted April 14, 2020 Author Members Report Posted April 14, 2020 (edited) Thanks a lot folks Jimi, the machines are not for sale but I indeed ha have to "rethink" the space for my machines maybe I can cut my bed in half or I can put one in the bathroom - who needs a shower when you have a rain barrel or lawn sprinklers @ scoutmom I cut out 5" in the middle of the 2 bars, drilled some 2" deep hole in either half (3x 8mm on the rear bar and a few more 6mm holes on the bottom bar) filled the holes on either side with JB Weld and insert 6mm thread rods (rear) and 4 / 5mm dowel pins (bottom). Why dowel pins and thread rods - well I just used what I had - no special reason. Make sure the holes in either half line up as good as possible but since the holes ware wider than the diameter of the rods / pins you still can adjust them a bit. Join the 2 halfs, line them up with a water level or what ever you have and clamp them to a table, let JB cure for a day - done... Its for sure not as strong as the old cast iron but it works. Edited April 14, 2020 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Constabulary Posted April 14, 2020 Author Members Report Posted April 14, 2020 few more... Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
toxo Posted April 14, 2020 Report Posted April 14, 2020 You're far too good at this Folker. Really like the roll top drawer. I'm thinking you're gonna have to move into a warehouse eventually. Well done. Quote
