Members dikman Posted June 3, 2022 Members Report Posted June 3, 2022 14 hours ago, voidsurfer said: This looks like it could solve my problem with my cb4500. I’m so impressed! How can I get hold of a set - I’m in the UK? PM RockyAussie, he'll be able to get one to you. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members voidsurfer Posted June 4, 2022 Members Report Posted June 4, 2022 6 hours ago, dikman said: PM RockyAussie, he'll be able to get one to you. Thanks, will do. Quote
Gulrok Posted June 4, 2022 Report Posted June 4, 2022 On 5/19/2022 at 5:38 AM, RockyAussie said: Good thing is generally most sewing machine oil does not leave any marks on leather after it dries out absorbs or whatever. To skip a good oiling practice is not a good idea especially if you think that 6 years between is alright . I do agree but I will add that to the best of my knowledge here in Australia the machines are checked and adjusted if need be before they go out to the customers. The shim for aiding in getting the back stitch length correct is more of a recent addition on these machines and I believe it is provided so as to make it easier for the customer to do it them selves if things move out of place over time. It is a fairly difficult procedure to explain and show all the steps involved to the average person and they can end up creating more of a problem if they do it wrongly. I do believe it would be a good idea to add into the dealers manuals and or video library an explanation on how to use the shim if ever needed so I think I will try and put something together for the dealers to use if they want. The dealers look after me pretty good over here so it will help me pay back some. (They sent me a new drop down guide and stainless steel flat table top attachment today for the CB4500 to test and try) I'm likely in the group that doesn't do oiling enough. I wonder if there's a way to develop a little device that puts a light on when you need to oil. (So many hours of power to the motor) ... doesn't seem like it would be that hard so I'm going to take a quick look if its possible. My staff members for certain don't oil as often as needed, I know that for certain. Its likely going to be cheaper for us over the years to look into a 100$ or less than to deal with maintenance. Quote
RockyAussie Posted June 5, 2022 Author Report Posted June 5, 2022 11 hours ago, Gulrok said: I'm likely in the group that doesn't do oiling enough. I wonder if there's a way to develop a little device that puts a light on when you need to oil. (So many hours of power to the motor) ... doesn't seem like it would be that hard so I'm going to take a quick look if its possible. My staff members for certain don't oil as often as needed, I know that for certain. Its likely going to be cheaper for us over the years to look into a 100$ or less than to deal with maintenance. Sounds like a great idea if you can find out how. One of my tecky staff purchased a phone that can pick up and show heat differences on things and I would have to guess that any bush or bearing surface would likely show up more if it was needing to be oiled more urgently. I an sorry to add that in my opinion that as far as I have seen in most manuals and videos a great many points that should be lubricated do not get shown. For instance why do you think that most presser bar adjustment screws have a funnel shape at the top? Seems to me that it acts as a bush for the presser bar to go up and down in and the engineers thought some oil should go down there. Maybe a bit hard to put red paint there so some of the manual writers though lets skip that one. Same with the needle bar on these machines which often has a rubber cover over the hole. How dose oil lubricate that shaft if you don't put some there? Take some time out to look for every moving surface on your machine and know that in most cases it will need to have lubrication at some time or other. Some parts rarely and some like the 2 I just mentioned a lot. How long and how well a machine operates is in YOUR hands at the end of the day. (2 to 3 drops minimum per hour in the shuttle race). It will sound quieter and smoother. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
RockyAussie Posted June 5, 2022 Author Report Posted June 5, 2022 For any of you that may be reading this and have bought a set please check this post out if you have not already done so which shows some adjustments you may like to know about - Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members chrisash Posted June 5, 2022 Members Report Posted June 5, 2022 14 hours ago, Gulrok said: I'm likely in the group that doesn't do oiling enough. I wonder if there's a way to develop a little device that puts a light on when you need to oil. (So many hours of power to the motor) ... doesn't seem like it would be that hard so I'm going to take a quick look if its possible. My staff members for certain don't oil as often as needed, I know that for certain. Its likely going to be cheaper for us over the years to look into a 100$ or less than to deal with maintenance. My question is who is in charge Staff like doing funny things with company vans, like seeing how fast they can go in reverse, test out their drifting skills, see how far they can go with the red warning lights for oil and water burning and so on Quote Mi omputer is ot ood at speeling , it's not me
alpha2 Posted June 5, 2022 Report Posted June 5, 2022 (edited) No means to light an alarm at a given hour reached, but it can be located in a visible location to check daily. The price on this piece is suspiciously low. The brand we used in trainer aircraft and rentals was Hobbs, and it was commonly called...the Hobbs meter. Edited June 5, 2022 by alpha2 Quote So much leather...so little time.
Gulrok Posted June 6, 2022 Report Posted June 6, 2022 On 6/5/2022 at 2:54 AM, chrisash said: My question is who is in charge Staff like doing funny things with company vans, like seeing how fast they can go in reverse, test out their drifting skills, see how far they can go with the red warning lights for oil and water burning and so on I guarantee that's not an issue for us. Its just remembering when you switch between machines and around. Quote
Doc Reaper Posted June 6, 2022 Report Posted June 6, 2022 On 10/31/2021 at 12:34 AM, dikman said: aware hey Aussie, thanks for the educational videos, I never knew what was under that plate until this vid, makes me wonder what else I’m missing! again thanks much for your help and the education Quote Doc Reaper
RockyAussie Posted June 6, 2022 Author Report Posted June 6, 2022 On 6/6/2022 at 1:10 AM, alpha2 said: No means to light an alarm at a given hour reached, but it can be located in a visible location to check daily. The price on this piece is suspiciously low. The brand we used in trainer aircraft and rentals was Hobbs, and it was commonly called...the Hobbs meter. Does this Hobbs meter thing tick up the hours when the power is on? If so that may be partly a good idea so long as people remember to turn the power off. Sometimes with these new servo motors its hard to remember that they are still on. I tried a cheap rev counter thing once and it was a dismal failure at keeping up with the machine. 5 hours ago, Doc Reaper said: hey Aussie, thanks for the educational videos, I never knew what was under that plate until this vid, makes me wonder what else I’m missing! again thanks much for your help and the education Your welcome. Hope I get time to do some more soon. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
