Members Tugadude Posted March 11, 2022 Members Report Posted March 11, 2022 Holy cow! (pun intended) All this talk about holes. I don't know that it's been mentioned, but some makers pre-punch holes and some use lasers to make holes. And I'm sure many use drills. There is no doubt the best way is a small hole that will close up and that is best accomplished with an awl or a very thin stitching iron. But I've seen nice work where the holes were drilled or burned. To me, the important thing to bear in mind is the fact many of us aren't doing saddles and/or tack. We build wallets and bags and key fobs and notebook covers and such and they don't have to withstand the rigors of use that saddles and tack get. So you can "get away with" most anything when it comes to making holes if the only stress is putting something in your pocket and maybe opening it now and then. Quote
Members Tequila Posted March 11, 2022 Members Report Posted March 11, 2022 I tried the “drill method” on a knife sheath, I used a 1/16 inch bit in a drill press. I started by using stitching irons to mark the holes then drilled at the marks. Like others said you’re removing leather, what I found that using the regular hand stitching thread I had didn’t fill the holes. Quote
CFM chuck123wapati Posted March 11, 2022 CFM Report Posted March 11, 2022 31 minutes ago, kgg said: I would definitely use my drill press not as a drill but just as a press. I would simply install a hole chisel in the head. For me it would be easier on the arms and with a simple alignment fence on the bed of the drill press the holes would always be aligned with the outside edge of the leather. Since you can set the downward travel of the head and the height of the bed you would get consistent chisel penetration. The only thing is going around corners you may have to change to a single or double tooth chisel. You could also use a press similar to the: i) Amazon at $169 CA which I don't think would give constant alignment of your holes as the head can swivel around the support arm and it would be only a single purpose machine. ( www.amazon.ca/dp/B07TBKGFBW/ref=sspa_dk_detail_2?pd_rd_i=B07TBKGFBW&pd_rd_w=ov56M&pf_rd_p=8e308614-8b7b-45e9-9526-75d8e163854c&pd_rd_wg=vxfZ1&pf_rd_r=RZBGPHJ7K41F0NFTQT3C&pd_rd_r=a1ccbbd1-5dbd-4acb-9e8c-e50e934d47a5&s=kitchen&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExVEhZNzlUWElUMUlOJmVuY3J5cHRlZElkPUEwNDUyMTMzM0tKWDNVNVBOTDdXNyZlbmNyeXB0ZWRBZElkPUEwNzgyNDM2M05IOUlCMEtINVoxUSZ3aWRnZXROYW1lPXNwX2RldGFpbCZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1 ) ii) Tandy's Craftool pro hand press ( www.youtube.com/watch?v=SKWkyJg510g ) My attitude would be use whatever works best, gives constant results with equipment that hopefully has more then just one function. kgg good idea! a guy could use it to set rivets, hole punches for belts and maybe a makers mark or some such stamp also. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
kgg Posted March 11, 2022 Report Posted March 11, 2022 47 minutes ago, chuck123wapati said: good idea! a guy could use it to set rivets, hole punches for belts and maybe a makers mark or some such stamp also. I like my tools to be multi functional, it's cheaper on the pocket book and takes up less space which leaves more room for other things. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members suzelle Posted March 11, 2022 Members Report Posted March 11, 2022 11 minutes ago, kgg said: I like my tools to be multi functional, it's cheaper on the pocket book and takes up less space which leaves more room for other things. kgg Multi-functional - Yes! I try to do the most with what I got. LOL. Let's not call that cheap kgg. That's just smart. Quote
MtlBiker Posted March 11, 2022 Author Report Posted March 11, 2022 @Hags and @tsunkasapa - The tutorial video where I saw this is by Weaver Leather. Supposedly folks with lots of experience. I'd never seen that done before and I was surprised. But with such a thick assembly it might be worth considering I thought. I'm still learning hand stitching and while my awl sharpening is getting better, I'm concerned that I might not be able to make proper holes using my awl. And for something like an axe sheath, the aesthetic of nice (what do you call it?) slanted stitches might not really be required. 6 hours ago, Danne said: I have no experience doing the products you do. But just a thought, can't you make your stitching holes with your sewing machine without thread so you can hand stitch it? Probably I could, as I could also complete the stitching by machine. But I'm trying to learn technique here. And I think that using a drill press, slowly and carefully, after the hole positions have been marked, might be easier to control than if I did this by machine. But I'm a novice, just looking for best ways. 5 hours ago, Spyros said: I'd use whatever works, a drill press, a sewing machine without thread, an oil derrick, whatever LOL Unfortunately, I don't have access to an oil derrick. When I tried using an awl on my last practice project with 3 layers of 6oz veg tan, I found it impossible to punch through all layers properly in position and straight. Also my glued gusset was twisted out of position by my pushing with the awl. My awl probably wasn't adequately sharpened at that point and maybe now with a much sharper awl it wouldn't be so tough. Maybe I should give it a try, especially since it's a practice project. But still, I wouldn't want to mess it up. @Handstitched The problem I see with both using a drill press or the sewing machine without thread to punch the holes is that the holes are round instead of diamond shaped. So, while both those methods would work probably the most attractive result would be with proper diamond shaped holes. Also considering using a drill press vs the machine to make the holes, it might be very difficult for me (at this stage in my learning) to keep the machine stitching holes exactly where needed, very close to the edge of the assembly. I'd say that would be particularly tough if the item was also wet molded (but this project isn't). A drill press with pre-marked hole positions probably would be better. @chuck123wapati - My awl is MUCH sharper now than earlier. I've been practicing and practicing with the sharpening. I guess I'll just have to give it a try, because I do agree that proper diamond shaped stitching holes make it look much better. Although the axe sheath that Weaver Leather made using the drill press looked really good. 1 hour ago, billybopp said: Drilling holes will certainly work, but keep in mind when you do that you are actually removing leather at the holes. They will not close up around the thread the way that they would if using an awl. I wouldn't go that route. However, I wouldn't hesitate to use an awl in the drill chuck with it secured so that it does not turn. That has the advantage of being easier on hands and makes it easier to keep your awl aligned straight, and since you aren't removing material the holes will "heal" better. I think that's a terrific idea! I just need to figure out a way to hold the awl securely in the chuck. I do agree that round holes are not ideal. @kgg - That's a great idea! Plus if my awl is not quite as sharp as it should be (I'm still learning how to sharpen it properly) the drill press would give me better leverage to push through multiple layers and keep the hole properly perpendicular. I just have to find some way to hold the awl in the chuck and then of course make sure it stays in the correct orientation so that the diamond shaped holes are all (awl) proper. Quote Current machines: Janome HD3000 and Skyline S5, Consew 206RB-5, Singer Profinish serger, Techsew 2750 PRO, Sailrite LSZ-1 Premium, Consew DCS-S4 Skiver
Members battlemunky Posted March 11, 2022 Members Report Posted March 11, 2022 I started off using my Dremel drill press and drilling holes but found that my Dremel vibrated a bit much and the holes were always a bit sloppier than I liked not to mention you may need jigs or other leveling methods to keep your holes the same distance from the edge in the event the piece isn't flat. I just got used to using punches and awls. As others have mentioned, a light saber of an awl will get you through most everything and skill with it will land you close to the same place you went into on the other side. Quote
Contributing Member fredk Posted March 11, 2022 Contributing Member Report Posted March 11, 2022 For keeping the holes on your work piece equidistant from the edge whilst cutting or drilling or punching the holes you can use a magnetic thingy, like this one : I use one (a large one, top picture) on my sewing machines. It sticks to the metal bed and you just run one edge of your work piece along it so that your stitching, or holes in this case, are equidistant from the edge. These magnet thingies come in different shapes and sizes and cost just a few $$ (try the sewing section of Hobby Lobby, or on ebay or Amazon) PS. I'm working on an idea for a holder for my Tandy Press to hold regular type diamond awl blades Quote Al speling misteaks aer all mi own werk..
Members Spyros Posted March 11, 2022 Members Report Posted March 11, 2022 (edited) 1 hour ago, MtlBiker said: @Handstitched The problem I see with both using a drill press or the sewing machine without thread to punch the holes is that the holes are round instead of diamond shaped. So, while both those methods would work probably the most attractive result would be with proper diamond shaped holes. Only thing that matters is if it's more attractive to you. It is to me, but don't assume that everybody likes it or it is the proper or better way, there's a tonne of people out there who prefer completely straight stitches and view the slanted ones coming out of diamond/french/slanted chisels as wrong, someone on this board even said "girly". It's just a preference, it's entirely up to you. If you have a drill press another option is to stick your diamond chisels in there and just pull down without turning the press on. Fred's solution with a magnet would help keep the holes in a straight line, although most drill presses already have some sort of a built-in guide that you could use. Edited March 11, 2022 by Spyros Quote
Members OldCanuck Posted March 11, 2022 Members Report Posted March 11, 2022 Novice here. Still learning the stitching art myself. But if Weaver Leather posts a "how to" video, I'd be willing to follow them on the trail. I mean, I've seen projects that tell you to punch the stitching holes with a #0 or #00 punch. That's a round hole, and it's leather removed. Those projects also use pretty hefty thread/string. About drills: there's a whole science to drill bits, drill speeds, and so on, and I know nothing about it, but if you were to go to the right forum and ask "what kind of drill bit to use on leather", I'll bet you'd get some useful replies. Finally: please keep us updated on your progress. It lets us learn from your, um, experience. Quote
