Everything posted by impulse
Anyone know where to find this stamp
impulse replied to Kolton45's topic in Leatherwork Conversation
Check out filigree punches on Ebay- various shapes available -
Refer to http://leatherworker.net/forum/topic/66403-coping-with-a-small-workshop/ Lots of good ideas shared here!
My latest belt
impulse replied to cradom's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I use an erasable silver pen for marking on leather - it just disappears with a damp cloth! -
I posted this recipe recently: I make my own "Bushmans Leather Dressing" by melting 1 part beeswax, 1 part parafin wax, 2 parts neatsfoot oil and 1tspn eucalyptus oil. The eucalyptus prevents mould. Because beeswax varies in hardness, sometimes I need to add pure gum turpentine to make the mix creamier. Use the dressing sparingly and after rubbing in well, leave for 30mins or so and it will leave the leather supple but can be buffed up to a satin shine which repells water. I never use straight oils on leather as too much oil can weaken the fibres and also makes it impossible to get a sheen. I have saddles and harness that are still good after 40yrs of service using this dressing.
Help and advice for a novice planning to recover seating!
impulse replied to Keyair's topic in How Do I Do That?
Use the existing fabric as patterns, but make sure you label which piece is from where. Calculate the sq footage needed, but because leather hides are an irregular shape, you need to allow 1/3 wastage. If the leather is of good quality there is no need to line with foam. I have successfully reupholstered 10-15 sofas and chairs using this method. Lois -
Work in progress Leather Waistcoat/Vest
impulse replied to Windrider30's topic in Clothing, Jackets, Vests and Chaps
Hi windrider If you have access to an ordinary home sewing machine, there are available leather point needles which will handle garment leather quite well. Should save you hours of hand stitching. Good job with the lacing!From a fellow Aussie, Lois -
Both! I do a lot of embossing where the leather hardens due to casing and this dressing restores the natural oils. Saddlery I like to be very supple, and this is easily controlled by the amount used. Before discovering this recipe, I used warm olive oil to break in my gear, but found it impossible then to get a shine. Over the years I have tried almost all the commercially produced leather cleaners and dressings - NOTHING is as good or versatile as the "Bushmans". I hope that you try this out. Lois
Hey Big Sioux I make my own "Bushmans Leather Dressing" by melting 1 part beeswax, 1 part parafin wax, 2 parts neatsfoot oil and 1tspn eucalyptus oil. The eucalyptus prevents mould. Because beeswax varies in hardness, sometimes I need to add pure gum turpentine to make the mix creamier. Use the dressing sparingly and after rubbing in well, leave for 30mins or so and it will leave the leather supple but can be buffed up to a satin shine which repells water. I never use straight oils on leather as too much oil can weaken the fibres and also makes it impossible to get a sheen. I have saddles and harness that are still good after 40yrs of service using this dressing. Cheers Lois
Thanks for your comments, AussieMade and northmount
I have recently been experimenting with using food coloring as a leather dye. It comes in 50ml bottles at any supermarket at a cost of around $1.25 ea. There are basic colors of pink, red, blue, green, yellow and black from which you can mix any color imaginable. It is water soluble and a few drops give strong color. I have found it to penetrate well and not rub off when dry. I advise prepping the leather with oxalic acid (1tspn in a cup of warm water) to give a clean start for an even finish. The dye can be painted on, rubbed on, dipped or sprayed. Strength of color is dependent on how many drops used.
Here is more detail of the greyhound collar. Because their heads are no wider than their necks the design is such that when the lead is clipped on the collar tightens around the neck. It is lined with sheepskin. The color was an interesting experiment - to get purple I mixed pink and blue food coloring. To my surprise, the leather not only absorbed it well, but when dry did not rub off at all and was not affected by water. Leaves the door open for a much wider range of colors without using acrylic paint!
Capron Carter Industrial Sewing Machines have a branch in Perth and have parts for some antique and vintage machines
I have recently re-homed a greyhound that was too slow on the race track. She is only 2yrs old and was otherwise destined to be euthanized. She has the sweetest temperament and lots to learn - didn't even know her name! I have made a martingale collar and matching dog coat.
By far the best surface for punches is lead. I have melted down scrap lead to form a 8" x 4" x 1" thick rectangle. this is firm enough to get a sharp punch thru thick leather with one hit, yet soft enough to protect the tool. It works much better than a poly cutting board. When one side is marked up I just flip it over. This is great for hole punches, slot punches, strap end punches etc. About every 2-3 months I refresh the surfaces with another melt down, using a blow torch. Caution! Do not use your kitchen stove to heat lead! I have a butane camp stove which I use in the open air only. "Them green mats" (self-healing) are also my choice for cutting, and granite slab for tooling. Cheers, Lois
Here is a custom halter made by a student of mine. It is made using 4mm harness leather (10oz). Always fold the leather when wet to avoid cracking and I always use stainless steel hardware. Make sure you use a quality leather dressing to restore the natural oils after the leather has dried from casing. Cheers, Lois
belts belts and more belts
impulse replied to Wedgetail's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Nice job, but I want to point out a common error when sewing on buckles and keepers. You have stitched across the width of the belts which results in weakened points - a bit like perforations for tearing off stamps or part of a document. It is much better (but more difficult) to have the stitching in 2 rows parallel with the length of the belt. A top brand, R.M.Williams, is guilty of this now that RM has passed; he would be turning in his grave! Regarding hole size, I agree with oldnslow. When choosing the right punch to use, find a size that will fit the tongue of the buckle, then use a size smaller as most punches have tapered profiles. Holes too big also endanger the strength of the leather. Cheers, Lois -
Good looking belts. One criticism is that the first hole is too close to the end of these belts - if the buckle tongue was in this last hole, the end would not reach the keeper! I always allow 4" to 5" (10 to 12cm). Cheers, Lois
It's a case of buyer beware! I was looking at handbags in a shop recently to gain inspiration for new designs. There were some "brand name" bags which looked great for $$$. They had tags on them stating "Genuine Leather" BUT on closer inspection the only real leather was the tags themselves!!!
Some chrome tanned leathers ca be burnished after wetting the edges with gum trag.
Sharpness of the blade is a key factor, but I have one more suggestion. Before feeding the leather into the gauge, manually cut the first inch or so. For a beginner it is sometimes useful to put the gauge in a vice and pull the leather through rather than pushing it. This enables you to use both hands in keeping the leather evenly against the fence of the gauge. For very heavy leather you may need pliers to get the cut started. Hope this helps Lois
Luv your bird design - is it your own? The way that you have used stamps to create the look of feathers is genius! Stitching does need practice and I think it would be a big improvement to finish the edges of both the bag and the strap. A sanding block can be used to buff the seams to even them out. It looks like a water stain (or something) has marred the front lower corner - this can be fixed with a mild solution of oxalic acid which is sold in hardware stores as a rust and stain remover. This is great for any type of discoloration on leather. Great first effort and I bet mum loves it. Cheers, Lois
I'll pass your comments on to my student with thanks. dfrensdorff - this was embossed on to un-oiled bridle leather.
I have a student that has leathercraft lessons with me each week. He has come a long way in 6 months and this is a halter that he has just finished. Bridle leather and stainless steel fittings, so it should last!
