Gregg From Keystone Sewing
  • Content Count
    1,212
Everything posted by Gregg From Keystone Sewing
  1. Very interesting, I didn't know that Singer was first with that type of spring/weight upper arm oil reservoir on some 211/212 subclass machies. I thought it first appeared on Seiko machines such as 255RB, 333RB, or 339RB type machines. This most commonly called 'centralized lubrication', meaning that it's not automatic, but that it will help spread oil as the machine operates by lubricating one point that will carry oil through usually oil wicks.
  2. Sold in the USA by Consew, this was sold as a model 206RB-3, the -4s were white. This model -3 was one of the very best Consew 206RB models in the series. Foot lift at the knee lifter is 9/16", same for all 206RB-3, 4 and 5s. All Consew 206RB subclasses and Seiko STH-8BL subclasses use the same hook, bobbin, and bobbin case.
  3. Wiz, Check the parts books, this machine in question here is not a top bottom feed machine; it's a true compound walking foot, four motion, with top, bottom, and needle feed with alternating presser feet. Uses common Singer 111W walking foot type presser feet.
  4. It's a Consew model 28, Seiko Copy of the Singer 78-3. I've got a few on the shelf here. Consew model 28 Owners Manual: CLICK HERE Consew model 28 Parts Book: CLICK HERE
  5. Nice, I enjoy seeing people helping out people around here, that's what it's all about.
  6. Didn't think I could make somebodies day with this one, but I scanned and uploaded, click the link below; Pfaff 1245 Old Case Owners
  7. Not so technically, if you really want OEM parts, they should be from Seiko, Japan, who clearly manufactured this machine and is and was sold under Seiko model number LSC-8BV-1. It's still a new, current Seiko model. Parts from Consew will work great as well, and some of the names of people already mentioned on this thread are aware of this as well and are more than capable of helping.
  8. What's the model number of the control box, this may help us locate an owners manual for you. See attached image.
  9. No idea if they are the same folks doing the work, Mitsubishi has some good people too. I usually inform our customers who is doing what where, but not 100% in every case, especially if we are using them as a cog in the repair spectrum; the fact is some really don't care at all, and just want us to fix it for them through us.
  10. Ha, really, because I really like these guys, AS WELL...They do a great job, fast, good prices, I'm sure Dunlap does a great job as well. Electronic Services, Inc PO Box 732 268 Hwy. 121/264 Alt. Farmville, NC 27828 Tel. 252-753-4433
  11. It's none of my business, but Efka America has great service and support, for sure. What was the motor issue, if you don't mind me asking?
  12. People have to see this machine to believe it; Machine head is 300LBS, throw of needle is 1" to each side of center. Check out the parts charts, the hook saddle, that's huge, shifts side to side as the machine operates. It's really interesting.
  13. It's funny, after reading I was looking up information about a Singer 122-1, an absolute beast zig zag from Singer mfg. and flat out forgot that I posted about it on a thread here on Leatherworker.net
  14. Reconditioned Jentschmann Adler 98-2-8 made in Germany, stretched to 30" of workspace, light to medium heavy single throw (Two step, one stitch) and triple throw (four step, three stitch) by means of a switch, New Efka DC1550AB321 220V single phase motor with V820 Control Panel, upper limit of speed control dial, Jentsmann GTR-1 belt drive puller. Puller, presser foot lift & backtack are actuated by solenoid controlled pneumatic valves, includes air gauges, filter, regulators, oiler, push to connect tube fittings. Price is $5,850 USD, store pick and machine demo is available, buyer pays for shipping, within US machine ships via commercial van line from our shop in Philadelphia, PA USA, usually about $300 range for shipping a machine like this.
  15. Mixmkr, Check out a machine I have, not inexpensive, but certainly an upgrade over the 107W1, but the same sewing capacity, check out the correct location for this machine, I'll post it on this MB under the for Sale, Machinery -- Sewing and Stitching, New and Refurbished to Like New
  16. This is what I would look for 1st, feeder is bumping something.
  17. Are you winding your own metal bobbins, or are you using a pre wound bobbin? I've seen some pre wound bobbins that were so inconsistent that they would do this. Wind a metal bobbin and see how it goes, if that's the case.
  18. I've been able to read a bit of this, and only now clearly understand the issue. Usually, I don't move on anything until someone brings the issue to my attention. I don't recall many of the 206RBs, 3s and 4s, that have this issue, but I can see where this would be a problem as in this case. Great fix, this is not easy at all to do, or to get correct without cutting, welding, and grinding many times until we get it correct.
  19. That was my 1st impression as well! I have to come back and study this when I have more time, seems interesting to say the least.
  20. We use what we have available to us as well! My dad has stuff all over the house fixed up with sewing machine parts, like the base of lamp is a Singer 68 class steel cam, common stand parts to fix things around the house, all kinds of stuff, the possibilities are endless!
  21. Really interesting thread. Gottaknow, what are you doing with that brass tube junk; One answer for that is Loc-Line. Easy to install, lots of options such as inline flow controls, various nozzles, and relatively inexpensive to use.
  22. Glad to hear it, thanks so much. Keep on me with the DNU-1541S and turning the work while in seam, I want to get to the bottom of this. Again, not the 1st time I've had this brought to my attention.
  23. Thanks for the input, Eric put a lot of information down there. I'm really surprised about using lube on denim chainstitch machines. I wouldn't think this would help at all, but I don't really know production equipment for denim that well, it's really specialized equipment when you really get into it. Not everyone wanted to work on feed off the arm Union Specials, they were a specialty.
  24. I'll look into it as well, I'll try what Russ said. This is not the 1st time I've seen this issue before.
