TomG
Everything posted by TomG
  1. There was also an almost identical pattern done some time back by Tony Laier and published by Tandy. Not sure if it was part of a kit, a Doodle Page, pattern kit or book. I've made a few and they are generally loved by folks I've given them to.
  2. Try a belt sander and angle the leather for the taper you want.
  3. Another one is... http://www.wawak.com/
  4. I have a Singer 111W155 That seems to be in good mechanical condition, but certainly isn't as "pretty" as a new machine. Our local commercial machine repair shop went over it last fall, replaced the hook assy and did all the adjustments. Everything seems to work well. I have been kind of thinking about selling this head and getting a Consew 206RB5... mainly for the reverse feature. What do you think a head like mine is worth and what is a fair price for a good used Consew head? Thanks
  5. I have the el cheapo Harbor Freight model and it's actually pretty good. Especially since it's less than 1/2 the price of some others.
  6. Probably the fact that they are real leather and hand crafted. A lot department store belts are made with ground up leather and cardboard. So, they can mark them as "genuine leather" but that's not the same as "real leather".
  7. ohiotravelbag.com. Page 140. But I didn't see 1-1/4". It may be on another page. They sometimes do that.
  8. Found these on Etsy: https://www.etsy.com/listing/62827059/make-from-copper-8mm-x-8mm-anti-brass?ref=related-4 They had a few sizes. You might also check eBay. I had quite a few Google hits but not enough time to check them all Good luck Tom
  9. Agree with Troy, except I almost always use a THIN piece of cloth folded a couple of times. a thick cloth holds more and I prefer to lay 2 - 5 very light coats allowing them to dry between. If you want to pray on a real budget, try a Preval unit. Tandy, SLC, eve Home Depot has them. Be sure to spry some cleaner -Alcohol - Watr through it when finished. If you like it, you can invest in an airbrush setup pretty cheaply from Harbor Freight
  10. I just bought the old model and it's good, but the blade needs to be sharpened or at least stropped. I also have the "High Tech" splitter and the new one does require a different method of splitting the leather. Still experimenting with the best way to use it. But, I did do a tapered skive on some Latigo yesterday and my first ttemptswere pretty impressive.. At least or me.
  11. Bwhahahahahahahahahahahahaaaaaaa So many one-liners -- so little space <g>
  12. No Prob. It's really not hard, just takes a little practice. Cut few pieces of scrap from the same piece of leather, maybe 8 oz. DIp them in water for 10 seconds, 30 seconds 1 minute, and until the bubbles stop. Let them dry to various colors, cut a few lines and bevel them You'll feel the differences and will see the difference in burnishing when they fully dry. Luck
  13. Hey Foamer.... Bob has the excellent tutorial at the first of this thread.. Go to the first message in the thread and click that hyperlink that says Casing Leather. Basically, no you don't soak it, you pass it under a faucet or dip in a tank of water - BRIEFLY. Then set it aside for a while, until the top ALMOST returns to its dry color and it feels cool if you touch it to your cheek. You can then tool it.. The time it takes depends on the weight of the leather and how wet you get it. If you want to case it the day before, let it dry until jus a little wetter than "tooling ready" as above and seal in ziplock bag overnight. When ready, take it out and let it finish drying to "tooling ready". Use the fridge if you need to store it longer than overnight. Good Luck
  14. Well, I think you are going to find that most folks would use a resist like Super Sheen or even better, Resolene, to block that tooled image. 2 to 3 coats, allowing to dry an hour or 3 between coats. Allow last coat to dry overnight. Dye the whole thing with oil or spirit dye using a sponge or dauber. Allow to dry overnight. Then you need to seal the top.. Some people use one of the Sheens, Some use Leather Balm with Atom Wax. The balm is what I prefer. Allow to dry an hour or 2 and buff. Apply the Antiquing gel with a dauber to get into the cracks and crevices of the design, and wipe off leaving it in the impressions. Let dry and seal with you top finish - Resolene seems to be the most popular. Good luck
  15. Has anyone used a rotary engraver like they use to make plastic signs for leather? I have an old one and can't seem to hit the proper cutter size/depth, etc. to make clean letters. Thanks
  16. Well, I hit a couple of small pieces with the steamer. Don't have photos, but the musty odor seems to be down and smells like leather now <g> Thanks for all the help. If anything changes as it airs out, I'll post about it.
  17. Ahhh.. I have a heavy duty clothes steamer. I'll cut a small piece off and steam the hell out of it as a test. Thanks
  18. Well, I think everyone is right on point. You have multiple factors against you at the same time. 1) Wobbly table - MUST be stable and sturdy 2) Thin leather- You can actually put a piece of 8oz scrap under it when you stamp and it will help it to hold a deeper impression 3) Probably not hitting the casing right for that leather - I've found that thinner leather needs to be SLIGHTLY wetter than the heavier pieces for stamps 4) That Poly mallet isn't gonna cut it for most 3D stamps. Get a 2 or 3 pound maul or a cheap Harbor Freight Dead Blow Hammer for the big stamps. 5 ) Last but not least - Some Tandy stamps - especially the new 3D ones are crap. Try all of this and I'll bet you get better results.
  19. I have some dyed splits that have developed a little moldy/mildew smell. I know I can use vinegar or Oxysilic acid on veg-tan to kill it, but I'm worried about ruining the nap on the splits. Any ideas or suggestions?
  20. That's interesting.... I had purchased the Tandy "economy" punch in 1" a number of years ago.. mainly because I needed it now and they were out of the "Pro" model. It was twice as sharp as the $40 version of my 5/8" punch. I dropped that economy punch and severely chipped the end so decided to buy the "Pro" model today. I almost broke my wrist when I hit it into a 10oz strap with a 3.5 lb maul. I gave it 2 quick, hard whacks and the damn thing actually bounced off the leather! I thought it was just me, but looks like it might be the product line. That sucks!
  21. Why not take a plastic/Pleather case, cut it open and use it to make a pattern. You can modify it to fit and look however you wish!
  22. And if you don't want to make then, look up Bear Man. He and his son make some nice ones from Cocobolo. I have a set and use them in a Foredom Flexshaft tool. Like a jumbo Dremel. Also, find a flex shaft for your Dremel and it will give you more control. My Foredom has foot pedal for speed control. The 4000 RPM Dwight mentioned is a good place to start. You may have to experiment a little. Depending on what you use to dampen the edge, you may need to speed it up or slow it down a tad. Be careful of too much speed. It will not always be better. You can burn the fibers before that mat down. Creates a dark edge with "hair".
  23. TomG
    Vintage Tools
    You need to post pictures and/or lists of what you have.
  24. Look for the Foredom flexshaft tool. They make some sort of chisel head for it, but have never used that one. I have the handpiece with a 1/4" chuck on it and mainly use it for edge burnishing/ Oh.. I think Harbor Freight has a version of it as well
  25. What's a hessian sack? Good job painting the cat
