Everything posted by Ferg
Your URL takes me to an ad for cleaning my MAC, please give a better rendition. ferg
Old Saddle With Swastikas
Ferg replied to medic0011's topic in Saddle Identification, Restoration & Repair
We love photos of leather work. Please do post some you may have. There are many Saddle people on here that I am sure will know what to tell you. ferg -
IF, you can get Leather needles for it you could sew 2-3 oz veg tanned. It is obviously a home machine that was never intended for leather. I have sewn with a leather needle on a home machine but it works them to death even on the thin leathers. This one will probably work you to death. ferg
One Note: Your needle is way to big for #69 thread. Try from a #18 or #20. Thread the needle in your hand, hold at an angle, if needle "waddles" down the thread easily, that is your sizing, thread and needle. ferg
I have seen someone sew across in a "V" pattern. Makes sense to me. ferg
This may not go over too big with you but anyhow Sew as close to the buckle as you can, up one side and down the other, Hand stitch across the strap at the buckle. If need be begin in the last machine stitch, hand sew to the buckle and across the strap even with your machine stitch and down that side to the last stitch. Tie off your hand stitching. Another way is to simply stitch across the strap at the buckle beginning with a "wrapped stitch" on the edge, stitch across strap to stitch line and do another "Wrapped Stitch" .This is strong and attractive even if it does take a little longer. This is a small photo but perhaps you can get the idea for the "Wrapped Stitch" from it. ferg
Running A Stylus Along A Cut Before Beveling - Do You?
Ferg replied to McJeep's topic in How Do I Do That?
Only problem I have with running the stylus or a modeling tool in the cut is, it seems to make the inner layer of the cut show more than I like. Appears as a lighter shade of leather. Might make it a little easier to bevel when first starting with leather work. ferg -
I have ordered a ball end mill that is .0625 diameter that is made for milling Stainless. It should do a lot better job than the Chinese Dremel tools. Thanks , ferg
I have no thoughts of making one or more of these tools that even come close to Bob Beard's expertise. I am an impatient individual and have a problem with waiting a year for a tool that I may be able to make. I used a half inch round piece of Stainless Steel. Filed the end perfectly flat and then put a radius on the edges of the flat so the abrupt edges would not make an imprint on the leather. First photo shows the radius and the flat on one side. The flat makes it possible to align with an edge line etc. Next photo shows the tool used along a border and into the field. I tried making the tool without rounding the face, Mr. Beard is absolutely correct, you cannot tool a background with a flat head on the backgrounder. I am sure you would like to see what the business end of the tool looks like. Be aware, I done this free hand and then put the dremel bit in the drill press, much easier. Made little effort to make this perfectly smooth after drilling the dimples. I will make more different sizes of dimples next time. The little Dremel tool diamond bits had a tough time with the Stainless Steel but they are almost perfect size. Didn't use cutting oil when drilling but did lubricate with machine oil. Extremely simple to make. Anyone with a little machining experience could do these very easily. Just thought you would like to see. ferg
I am confused by your post. I live 50 miles away from you and have no problem buying spirit or oil based dyes for leather. Visit Feibings site. Someone living in that other country called "California" cannot buy. LOL ferg
Cleaning Leather With Oxalic Acid Crystals Or Lemon Juice
Ferg replied to LNLeather's topic in Leatherwork Conversation
You are correct, simply washing an object with water does not completely neutralize the vinegar but it does indeed dilute it to the extent that it offers no detrimental effects. As I said in my previous post, "Allow the leather to dry completely before applying finishes or dyes." I can find a thousand things in everyday life that could hinder a person's health. Unfortunately today, folks are so immunized against so many things that we ate when I was a kid. They would probably kill half the population now. Use common sense folks. I like to think most Leather folks are at least a little smarter than the average Joe/Jerry. ferg -
You are doing a relatively good job. The beveling is much better in second photo than first so we can assume you are getting better Cut your finger nails very short. Use a modeling tool to rub out the scratches while the leather is still pliable. Practice, practice, practice. Words we bandy about constantly. ferg
Welcome to the forum. You will find thousands of help notes in the Archives, may take several hours to read them all but.... Better get started. ferg
As always, welcome to the best leather forum in the world. You will find this site has members that share their knowledge willingly. Also many of the most talented leather carvers etc. anywhere. ferg
Dilute 4 to 1, water to vinegar. Stubborn stains increase vinegar. Yes, it does need to be washed with clean water to neutralize the vinegar. Make sure your leather has dried thoroughly before applying finishes and/or dye. ferg -
Oxalic Acid has never been a problem for me. White vinegar diluted in water will obtain the same results as lemon juice. Vinegar seems to be a little stronger solution. ferg -
Nice job. Your design is clean and well done. The more I see of the lined, geometric work, as you have done on the back, the more I like it. ferg
Bob, That is excellent. I have done some but not as many words as yours. The Arbor Press will imprint the lettering also. ferg
You can buy tape measures, some are nylon, that begin with "0" in the middle. I am thinking of centering the "0" on the tool center. Pressure? That is a relative thing I believe. I simply hold the handle down firmly. Makes great impressions. Used it with Basket Weave. Takes a little practice but the impressions are very even. Largest pieces I have used to press an image is about 2 1/2" x 3 1/2" . That takes some pretty good pressure. ferg Tree, Nice thing about the "rig", I can get more distance from the tools simply by moving the table back and tighten the clamps. ferg
"Amazing Grace" was my first thought but "The Old Rugged Cross" was definitely my grandmother and her daughter, my mom, favorite of all hymns. I carved the music and words to "Stardust" into a wallet for a Band Leader years ago. ferg
One ton Arbor press from Harbor Freight, $45.00 Steel, aluminum, screws etc. $10 - $15. Fully adjustable and very accurate. Half inch hole drilled in arbor ram with thumb screw in front to hold tool in hole. Aluminum blocks are bolted to table, have thumb screws through them to anchor table to arbor base. Adjustable brackets on back of vertical are Bi-Fold Door hardware. Any questions, I will try to answer. ferg
Visit this web site to see what is possible with "Spirit Dyes" (alcohol based). This gentleman does some of the finest work on this planet, carving and coloring. Hope his gallery gives you inspiration, I did not intend it to be over powering.) http://petermain.com/ ferg
New Projects
Ferg replied to Helda Huginkiss's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Helda, Your work is excellent. You have the touch, I don't say that often. Your design is exquisite and fine in features and layout. I cannot think of any other adjectives that do it justice. Curious: Did you intend your stitching holes to be large with only a small amount of thread? -
I have been a fan of great Barber Shop Singing since the "Buffalo Bills". Not many that could match their expertise. This group, everyone will enjoy. ferg
I think that most of the machine dealers on here will agree with me, under certain conditions, every doggone sewing machine out there will make marks. IMHO that would not be a test for buying a certain machine, you need to look a lot closer at what the machine you are considering is capable of. ferg
