I use resolene mix 50/50 with water. I had to use 3 good coats to get a good seal, and I allowed 24 hours drying between coats. I would do a test piece with the Super Sheen before I tried to cover the actual piece.
I have covered a leather patch with clear resin in the past. The piece must be thouroughly sealed or the resin will seep in and discolor the leather. I sealed and glued a leather patch to a plastic, recessed cover. I used super glue for the bond, leveled the piece and poured the resin over it. It works as long as the leather is completely sealed.
The skewers have been holding up well on the items I have made. I have not had any complaints in the three years i have been using them. Bamboo is a very strong and flexible, even in small diameters.
Try shiskabob skewers from the grocery store. They are bamboo, can be dyed with leather dye, and a 220 grit sanding is all you need. Best of all, they are cheap.
I have one of these and tried some of my tools in it. I found with the recess area of the handle, the box will not close with tools in it, which severely limits the number of tools you can put in it. I also found that you have to modify the tray by cutting the bottom out of the bullet tray.
Quickbooks Priemer will allow you to build items in inventory to cover what you need. You need to set up as a manufacturing business to get this part of inventory to work.
I made a canteen strap from 4 oz veg tan leather. I used vinegroon to turn it black and gave it two really heavy coats of mink oil. It softened up a good bit. Now considering this was a strap, I do not know how soft oiling would make a piece as large as a jacket. I am sure there would be a rather long break in period to keep it from being stiff.
I use the Tandy Deluxe Awl Haft with the diamond and the straigt round blade. This is the adjustable haft they sell. I have been using it for over three years and do not have any complaints about it. I really like that it will not roll around if I set it down on the bench.
One and the same (floor wax), just make sure it is plain, no perfumes or such in it. Soldiers have been using it on their boots for years, and many leather workers use it to seal their projects because it is much more cost effective.
I can save you some money, Mop N Glo is the same as resolene. You can cut it the same. I spray resolene with an air brush most of the time. Usually two light coats about 15 minutes apart and let dry for at least 24 hours. You can buff it after that with a soft cloth, like sheeps wool or a cloth baby diaper. My bracer has seen downpours of rain and the autographs were not affected.
You can mix resolene 50/50 with water and use a trigger spray bottle that can be adjusted to a mist. I have a leather bracer signed by a couple of bands. I used the resolene and it works great.
My snake leggings are made from two layers of 1000 Denier Nylon. Armor grade leather is in the 12-14 oz range. I would think it would take an awful big snake to get through a piece of that.
