radar67
Content Count
165 -
Calendar
Everything posted by radar67
I use resolene mix 50/50 with water. I had to use 3 good coats to get a good seal, and I allowed 24 hours drying between coats. I would do a test piece with the Super Sheen before I tried to cover the actual piece.
I have covered a leather patch with clear resin in the past. The piece must be thouroughly sealed or the resin will seep in and discolor the leather. I sealed and glued a leather patch to a plastic, recessed cover. I used super glue for the bond, leveled the piece and poured the resin over it. It works as long as the leather is completely sealed.
You are not going to get a good solution of vinegroon in a few days. It usually takes a couple of weeks to work through the process.
What part of MS are you from? I am south central, near Hattiesburg.
Western Style Hat
radar67 replied to rfkoen's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
You did well on this hat, it looks good. Not sure about the number of notches you would need to cut, maybe one every inch. -
The skewers have been holding up well on the items I have made. I have not had any complaints in the three years i have been using them. Bamboo is a very strong and flexible, even in small diameters.
Try shiskabob skewers from the grocery store. They are bamboo, can be dyed with leather dye, and a 220 grit sanding is all you need. Best of all, they are cheap.
I have the exact same one you linked to. The nobbies are what I had to cut out.
I have one of these and tried some of my tools in it. I found with the recess area of the handle, the box will not close with tools in it, which severely limits the number of tools you can put in it. I also found that you have to modify the tray by cutting the bottom out of the bullet tray.
Quickbooks Priemer will allow you to build items in inventory to cover what you need. You need to set up as a manufacturing business to get this part of inventory to work.
Can 3-4 Oz Veg Tanned Leather Be Oiled And Softened
radar67 replied to andyb's topic in How Do I Do That?
I made a canteen strap from 4 oz veg tan leather. I used vinegroon to turn it black and gave it two really heavy coats of mink oil. It softened up a good bit. Now considering this was a strap, I do not know how soft oiling would make a piece as large as a jacket. I am sure there would be a rather long break in period to keep it from being stiff. -
I use the Tandy Deluxe Awl Haft with the diamond and the straigt round blade. This is the adjustable haft they sell. I have been using it for over three years and do not have any complaints about it. I really like that it will not roll around if I set it down on the bench.
Looking For Tips On Cutting Perfectly Square
radar67 replied to jenkins's topic in How Do I Do That?
Dwight's answer is right on the money. Stand up to get the most pressure on the ruler, sharp blades, and practice. -
Look up the technique called Repose.
Looking For Jim Simmons 1863 Cavalry Holster Pattern #6000-62
radar67 replied to RoughRider's topic in Patterns and Templates
Care to share? -
Searching For Old Purse Pattern Called Town Pak
radar67 replied to albertacountrygirl's topic in Patterns and Templates
Have you checked the leather library on Tandy's website? -
I can save you some money, Mop N Glo is the same as resolene. You can cut it the same. I spray resolene with an air brush most of the time. Usually two light coats about 15 minutes apart and let dry for at least 24 hours. You can buff it after that with a soft cloth, like sheeps wool or a cloth baby diaper. My bracer has seen downpours of rain and the autographs were not affected.
My snake leggings are made from two layers of 1000 Denier Nylon. Armor grade leather is in the 12-14 oz range. I would think it would take an awful big snake to get through a piece of that.
Most use a granite slab to do their stamping and carving on, then place the cutting mat on the slab to make your cuts.
My formula for selling an item is cost of materials times 5 is the retail cost. Of course I buy my material at wholesale.
How Do I Properly Organize My Stamping Tools?
radar67 replied to MMLeathercraft's topic in How Do I Do That?
I have friends who do the same, but it is to identify who the tool belongs to.
