Everything posted by Tree Reaper
Re post that here http://leatherworker.net/forum/index.php?showforum=50 for better results.
- 2 replies
- edge binder
- right angle edge binder
(and 3 more)
See edit above, you could also use a nut inside the chuck if you don't have any tubing.
- 9 replies
- #leatherworking
- #leatherhardware
(and 2 more)
Can you drill out the snap? If not, you can put the threaded portion inside something like a small rubber fuel line, place inside a drill chuck and hold a file to the head as the bolt spins in the chuck.
- 9 replies
- #leatherworking
- #leatherhardware
(and 2 more)
Allen screws don't have heads.
- 9 replies
- #leatherworking
- #leatherhardware
(and 2 more)
How Do I Sew Loops Onto A Leather Strap?
Tree Reaper replied to jlanning215's topic in How Do I Do That?
Box X stitch. -
Here's another design that is vented only on one side.
- 11 replies
A bag that can breathe will be better for keeping the game longer.
- 11 replies
I like the looks of this burlap bag. http://i23.photobucket.com/albums/b363/gcromwell/IMG_6083_zps9fa465f2.jpg
- 11 replies
These look longer https://goldstartool.com/grommet-size-chart.html
Cross Stitching An Edge With Lace - Pictures And Techniques
Tree Reaper replied to Vikefan's topic in How Do I Do That?
I learned how to stitch the Mexican Round Braid from this video. Chief has other excellent video's on lacing but I'm partial to the MRB. -
Edge Splitting - Skin Wrinkling; Looking For Solutions!
Tree Reaper replied to taobao's topic in How Do I Do That?
Belly leather is prone to that. I also pre treat with neatsfoot oil and don't use belly leather.- 2 replies
- edge finishing
- leather cracking
(and 1 more)
Karina; I was commenting on using the tool for sharpening. " can throw on a polishing wheel (or grinder) on the other side "
I don't think you will want a polishing wheel in close proximity (at least a few feet) to where you are working with leather, they throw a lot of compound and debris. A variable speed drill press might be another option for you, I use a small bench mounted drill press for burnishing and sanding. I keep metal sharpening and polishing separate.
Leather Glasses/sunglasses Case Leaving Scratches?
Tree Reaper replied to zaynexpetty's topic in How Do I Do That?
I made a case and lined it with suede, it marks the lens.- 13 replies
- glasses
- sunglasses
- (and 8 more)
From the album: Tree Reaper
Seeking Donations And Teaching Tips
Tree Reaper replied to Pounder's topic in Leatherwork Conversation
An oak or other hardwood branch would make several mallets, and the scouts could make them easily. Different diameters and they could choose their own. -
I bought one of those as well from Tandy ,it's well made but I wouldn't buy the same one again because you can't get all the dies you need.
I buy rivets from Ohio Travel.
For a wood grain finish you can wet a piece of plywood to raise the grain, let it dry and then press it into cased leather and the pattern will transfer.
You could use a varnish or urethane.
There's a product that I've used called petrifier and it will harden leather. On pouches I soak the inside and a light coat on the outside. http://www.homedepot.com/p/PC-Products-16-oz-PC-Petrifier-Wood-Hardener-164440/100649629
Your backer plate could even be plastic.
You can buy brass footman loops and make your own plates from brass flat stock .
Try Lee Valley Tools. http://www.leevalley.com/en/wood/page.aspx?c=&cat=1,41504&p=30021
I always wax items that will see wet weather.
