Everything posted by mlapaglia
I believe I got it on eBay. This is a similar style . I was wrong its not a bead blade it is a double blade. Makes 2 parallel cuts. It is ceramic not plastic. For size reference that is a 1.75" wide strap.
+ 1 on the bush beader. I have a plastic swivel knife blade that does the same thing. Makes a nice bead.
Honestly, whatever makes the stitch you like is the right way. You will find people that say one way and those that say the other way. Do what looks good to you. They are both a good stitch.
There is no set answer. You have to consider the following. You can have a flat rate custom charge or you can decide what your time is worth and bill by the hour for the extra time it takes you or you can pick a number out of the air because you feel guilty charging what it should cost. Example. Pancake holster. you charge $75.00 Custom pancake holster, Customer wants a retention strap added and pull the Dot snaps instead of belt slots. Your flat rate charge is $100 so your charge $175.00 You time per hour is $35.00. It takes 5 hours to change the pattern and make the holster. So $75 base + 5 hrs X $35.00 = $250.00 You feel guilty because the cost is seems so high that you decide to charge the guy $125.00. This job takes you 5 hours. Normal holster takes 2 hours. The price of the materials and parts are not considered in this concept and should be added in to the price. Time is figured actual time you spend on project. All numbers are made up for these examples. You have to decide what your market will bear. Chances are if its a good customer you would pick the third option or even no increase because this guy brings you a lot of business. Did I help or just confuse you?
Yep, I have seen that. I keep LL LR and S needles for the look depending on the project. Thanks Thanks Dwight. Ill do that.
Resolene As Top Coat Over Lexol Leather Conditioner?
mlapaglia replied to Tallbald's topic in How Do I Do That?
I use HO leather too. I always oil after dyeing too. I have lexol and NFO in the house and like the NFO better. Its just a matter of finding what you like and using it. Its all good. Michael -
Art, The thread is just to hold the seam together. I do not have any thread below 207 at this time so I am unable to run test stitches and Id rather not buy several bunches of thread. (Im cheap ). I do like the fact that I might be able to use a V-33 or V-46 in the wifes machine. I am not looking forward to changing the tension on the BOSS for a smaller thread. Forgetting which machine I use what would you recommend. Its a pouch that will hold 3-4 magazines and hang off her craft cart. Think function over art. Thanks Michael
I have a Tippman Boss and love it. I have to make a pattern pouch for my wife and have no idea on which size thread to use. I normally sew 277 with a 25/200 needle. The leather I am going to use is 3 oz and VERY flexible. You can lay it over a finger and it just drapes all around. Any ideas would be appreciated. Im thinking on 8-10 SPI.The Boss can sew from size 69 to 415. Thanks Michael.
I love when a vendor promotes another vendor. It shows class.
ok Thats a feature of the leather being hydrated a little by the oil or conditioner so its no longer dry. Its dry leather that cracks. Leather that is not dry will not crack. You might try Neetsfoot oil or Olive Oil. Both are cheaper than Lexol. Buying a better leather will help to. But hey, if this is working and you feel no need to change then go for it. There are many ways to obtain the same effect in leather working. Michael. FYI hydrated is not the correct word as it implies water but I could not think of a better one. Im old and its late -
How does Lexol toughen a belt? -
Hal would be proud.
It should be fine as long as you wait at least 24 hours between the Lexol and the resolene. -
Spend some time on this site. They have a lot of plastic and metal suspender clips. Google is your friend but you have to know how to speak to your friend. It's not always easy Michael
Yet Another Few Questions On Vinegaroon
mlapaglia replied to Windrider30's topic in How Do I Do That?
A: I have never seen a difference with heating the vinegar or not. B: I use 1 TBL baking soda to 1 quart water. I wait about 5 minutes after dipping the vinegaroon then dip the leather in the Baking Soda water for about 10 second. Let it sit 3 minutes and then rinse it well under running water. I am sure you will get other ways to do it. This works for me. C: Yes Olive oil, Extra Virgin Olive Oil(EVOO) or Neats foot oil will all work. I find that it really improves the color. I dont use the EVOO as I get the same results with regular olive oil and its cheaper. Normally I use Neats Foot oil. D: Hard to say on this one. Stored temp makes a difference. the gauge of your steel wool, and the acidity of your vinegar all affect the time it takes. Its done when it stops eating the steel wool. In Denver it takes about 2 weeks and then I let it settle for a few days and pour off the liquid through a filter. YMMV Michael -
Tandy Leather Company. They are known for crappy leather. You will find what you need there.
Same here. File folders.
Where do you live? Someone here may have an idea on where to get leather that wont cost so much with shipping. But perhaps not. It all depends on where you are. For leather like that where the back side will show I apply gum tragacanth to the back and then use a flat edge to smooth the back side. It works well unless your back side of the leather looks like a shag carpet. Then you might consider sanding the back side first.
Tippmann Boss Tension Advanced Question
mlapaglia replied to DHauser's topic in Leather Sewing Machines
Glad to hear you fixed it. Thanks for the link.- 2 replies
- tippmann boss thread tension
- tippmann boss
- (and 1 more)
You can also buy more expensive leather from Herman Oak or one of the other high quality leather tanneries. What you have looks like a standard piece of grade c Tandy leather. Very normal in inexpensive leather.
Problem When Antiquing With Wool
mlapaglia replied to Oceanstreetleatherco's topic in How Do I Do That?
If the RTC is still tacky it needs to dry more. It should dry 12 hours before a second coat or the antique is applied. If you put on a second coat let it dry over night also. I know there are people here that do not let it dry anywhere close to 12 hours and it works for them but since you are having problems its best to let it really dry first. After you get the hang of it than you can try letting it dry for less time. Michael -
The Fiskar 45mm is my goto knife. I want to get a 60mm to see if its any better.
My Version Of A Sneaky Pete Holster.
mlapaglia replied to jstar61's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Make a tunnel for the barrel. Sew a piece of leather behind the barrel so it holds it firmly. This will keep the pistol from tilting in the compartment. Chances are its an unneeded piece but it could not hurt and give would you peace of mind. I always wanted to see one of these but after seeing it to scale on a hip it is too large for anything I might want to use. But I do not wear OWB so all I am used to showing is the grip and back of the slide. It is great workmanship but I cant see anyone thinking its a cell phone case. A tablet case I could see. Anyway jstar61 Well done. Ya done good. -
How To Cut Straight On A Scribe Line/pen Mark?
mlapaglia replied to DavidL's topic in How Do I Do That?
LONG straight edge, clamped to table and leather. Roller Knife 45mm. This works for me.
