w/o having it in front of me to me the needle holder looks good. Are you probably using the wrong needle system with a too small shank diameter ?
Pfaff once has changed their parts numbers so with the old number its hard to find something. The only one I have found is this: http://www.wdn.de/artinfo.php?artnr=A%20%2014852 Its a needle holder for the Pfaff 34 - the smaller version of the Pfaff 134. I´m not 100% sure if it is the same but I think so. But as always it is quite expensive like all Pfaff parts This could also be an option - it is for the zig zag version of the 134 http://planetecouture.com/en/needle-clamps/8055-serre-aiguille-pfaff-138.html
You will have a hard time finding parts for old Pfaff machiens but anyway sometimes parts from other machine may fit. Please post some pictures and numbers of the parts please.
Thats much better You just have to remove 2 screws - don´t lose em - better take a magnetic screw driver
I´m on the run - just a few fast hints.... You first have to remove the bobbin case and remove all the jammed thread from the hook era and reinstall it. Do you have a manual for your machine? Have you threaded the machine correctly and insert the bobbin correctly thread should come off the bobbin from the left side. Have you checked the needle bar hight and timing of your machine? Your needle bar has timing marks (hopefully). Upper mark is for needle bar at BDC and the lower mark for the point where the hook tip should meet the needle scarf and grab the loop of the upper thread. For a quick aid download the manual for a Consew 227 - this is a different machine but the technical instructions are very good and are almost the same as for your Singer 111w155 have to run - sorry
TSC 441 is the original nomenclature from JUKI. TSC has nothing to do with additional equipment. Did you get my PM message?
I have three harder to find presser feet for the heavy duty Adler Class 20 Leather sewing machine. These are original ADLER parts. 1x fork type foot 1x left toe foot 1x piping foot As far as I know these feet will work for some sub classes of the Singer Class 7 as well but not for the walking foot / top feed type machines.The grove that goes onto the presser foot bar is 12.5mm wide. So please check your Singer 7. Price is $35 each Worldwide registered Airmail is $7 10% discount when buying at least 2 feet - or all 3 feet together $95 including fully insured registered worldwide Airmail.
10% discount when buying at least 2 parts - or all together $115 including worldwide registered and fully insured shipping
Shuttle Hook - Parts # 81993 in sued condition without tension spring (screw present) and without the screw for the bobbin spring (spring present) - including 3 used random bobbins for free - $25
Needle plate - Parts # 82201 - used but holes are still round see underside pic - $20 Shuttle Hook - Parts # 81993 with all springs and screws including 3 used random bobbins for free - $35
I have a few original SIMANCO 29K72 parts for sale. Paypal is welcome. Single parts can be shipped worldwide by registered Airmail for $7. Oil / wax Cup - Parts # 8670, fits all 29K models guess $25 Needle plate - Parts # 82201 - seems to be unused but has some signs of long time storage on the uderside $25
Original Singer Edge Guide Parts No. 86135 for 45K, 132K, 133K and others - original SIMANCO mfg. in good used condition $25 + $7 worldwide registered Airmail. Paypal is is welcome.
Presser Feet + Needle Guides For Busmc 6 Hm / Pearson #6
Constabulary replied to Constabulary's topic in Old/Sold
And an original shuttle box cover (left side, has IVI Metallics mark) in very good used condition $50 -
Maybe you can take parts from the standard tension unit you find on most sewing machines - like this one: http://www.ebay.com/itm/SINGER-111W-SEWING-MACHINE-THREAD-TENSION-COMPLETE-CONSEW-206-PART-240446-/110914591225?pt=LH_DefaultDomain_0&hash=item19d30659f9
Table Attachment For Pfaff 335 Class Machines
Constabulary replied to Uwe's topic in Leather Sewing Machines
that really looks nice - so when will you start mass production? -
I have the JACK JK363A-1 with needle positioner with 40mm custom pulley (original wa 75mm). This one runs on a 111G156 triple feed upholstery type machine with safety clutch and the 3:1 SR as mentioned above. I have disconnected the synchronizer for the NPS because it seems not to work in combination of with speed reducer. I don´t care because I have enough slow speed control. I figured I just don`t need the NPS - dead topic for me. Manual says it has 2.5 N.m torque. But the manual over all is a pain in T.A.. I once have written a review: http://leatherworker.net/forum/index.php?showtopic=56445&hl=%20jack%20%20servo&page=1 The other JACK servo I have is the 750 Watt JK361A w/o NPS with 75mm standard pulley (I had the 550 Watts motor with 40mm custom pulley earlier but have updated the entire motor and speed reducer setup recently - I will add a 40mm pulley again one day.) This one runs on Singer 133K3 heavy sewing machine and also has a 3:1 speed reducer. All I can say that the 750Watts Jack Motor in combination with a 3-1 reducer meets my requirements and I can work with this setup. I never did any math regarding torque or so. Usually the seller of servo motors don´t even provide this information. The only dealer I know who provides these informations is Universal Sewing for their ENDURO SERVOS. The the orientation for the end consumer is the number of Watt.
My preference is the 750 Watt JACK Servo that College Sewing in the UK sells but I use it in combination with a 3:1 speed reducer. The lowest motor speed is 200 rpm but the SR slows it down very well. For my purposes they work very well. AFAIK they are also magnet controlled. I have 2 of them and I´m quite pleased. But I admit - the instructions manuals are a pain!!!
12976,33 USD for a JUKI TSC-441? Just the head or complete with table and motor? Sounds like a good deal but I guess for the price it is a used machine, right? Anyway - still a good deal I´d say. EDIT: wait - seems I got the price wrong - sorry! Now thats price really HURTS!!!!
I always wondered what the difference is between the open and closed frame shuttles, beside the obvious difference, but technically I don´t see a difference. The Adler 104 I once worked with came with both types and either one worked well.
Thanks and don´t forget about the freakin APPLE stuff
Well, most of the new industrial machines nowadays come from China and are not made in the US, Europe or Japan. Even the "old name" brands like Adler or Pfaff (just to name a few) come from China nowadays. Most Chinese made machines are very similar they just have different brand name tags or sticker. But thats not unusual nowadays.
has nothing to do with the belt but I´d chose a different photo background. I don´t think this table is very representative - I guess you know what I mean when you look at the last 4 pictures.
Do I Have A "complete" Busm / Pearson #6 - Or What?
Constabulary replied to Constabulary's topic in Leather Sewing Machines
I was able to locate some parts. Shuttle cover even seems to be NOS. My original shuttle cover had no spring so I bougt the complete unit. Hope the needle plate screws will fit... -
www.Sieck.de has a wider range of sewing machine but the prices on their website are w/o VAT, you have to add 19%
