Constabulary
  1. I always wondered why these attachments are no longer made. @ Darren Brosowsky f you read this - how about reproducing these attachments in India? I guess you have contacts there, right? I think most are quite useful for leather workers. Aren´t they?
  2. You can´t? You have to! Sorry Gregg but I don´t have the patience to translate it.
  3. There you go - I hope you can deal with it Attachments Adler 4, 5, 104, 104, Singer45K, Claes
  4. Your machine is rather a "clone" of the Adler 5 (not 105). I can make a lot of words but instead I will post here or send you an extract from the original Adler 4 /5 manual where a lot of the attachments are pictured and described (in German language).
  5. would be a shame to scrap them - I hope they will find a new home!
  6. I´m not exactly sure what you mean. You of course have to guide the material no matter which foot is installed. What means "with the roller up" - have you installed roller foot + regular presser foot together?
  7. Maybe just a timing or thread tension problem. The Singer 111w series are one of the few older machines you still can get almost every single part for. I´m sure one of the LW member can help you to setup the machine again. $200 is not too bad but I´d try to get a better price -maybe $150 or so. How is the overall condition?
  8. Contact the LW member SINGERMANIA (Steve) - I´m sure he can help you.
  9. Hi Ron, so you are the only dealer who sells Techsew machines? I did not know that I assumed there are more dealers and you are a kind of wholesaler and dealer. Sorry - I don´t wanted to offend you in any kind! I´m sure that you will send your machines out well tested. Please apologize!
  10. Seems the machine has not been tested properly before shipping. Not sure where you put the shim but usually there is a disc with a small bar in the center and this small bar can be adjusted by tapping it a little bit to one or the other side to adjust the tension release. Most machines of this class (if not all) have about the same hook / needle bar / timing settings. So you had to go back to almost zero with the timing as it seems. Glad you solved it!
  11. I´d probably choose the 111w155 because of the safety clutch!!!
  12. These machines are pretty much the same class as the 2 above they just have post beds instead of flat bed or a cylinder arm. Take the thread you want to use and the material you want to use and try out the machines. Maybe you´ll find out that non of them is working for you - just try them. Thats the best way to find out if they are good or not. Sewing speed is one thing more important is if the machine can handle the thread and material you want to use. You can easily replace the clutch motor with a servo motor. I can recommend the Jack servos from College Sewing: https://www.college-sewing.co.uk/catalog/search.aspx?keywords=servo
  13. The clutch motor seems to be very fast. It probably runs at 2800 rpm and that is difficult to slow down. You probably have to swallow a bitter pill and replace the clutch motor with a new servo motor. So when the guy with the 167 is a difficult man I´d leave him alone with his machine! But I would still test sew the 69 when possible to check if it meets your requirements. Twinoaks is right, the 69 is not a heavy duty machine and has its limits. You probably have to look for a heavier machine when you want to sew with thicker thread.
  14. Holy Cow - what a fly wheel!!! I don´t see a stitch length adjuster and how do you put it in reverse? Or am I missing something?
  15. The 167 has a larger hook + bobbin and since you are planing to sew flat items mainly it´s a good choice. I´m not sure but is it possible that the 167-62s has a roller foot and no triple feed / compound feed? The 69 is a cylinder machine with compound feed and when you make your self a flat bed attachment the 69 is the more versatile machien I´d say. But I´d test sew both machines to see which one works best for you. If I had to choose Id take the 69 but it has the smaller hook + bobbin... 1985 - 1990 is relatively new - I have machine from 1932 in use
  16. The 133K´s are really nice machine, I recently have restored a 133K3. But keep in mind that it has no reverse. The EY prefix makes is a post 1965 made machine I´d say so it is relatively "new" (mine if from 1932 and still runs smooooth) http://www.singerco.com/support/machine-serial-numbers/double-letter Well, it depends in what part of the world you are. Sewing machines in Australia are by far more expansive than in the US or Europe. When you are buying form a private seller the price should be about 1/2 of the dealer price I´d say as you have no warranty, support and so forth. It also depends if the machine comes with useful accessories or even with some spare parts. In Great Britain some dealers ask 1000 GBP (approx. $1500) or more. The one in the picture seems to be a really nice one. I would say between $600 and $800 is a fair price when you are buying from a private seller. I have uploaded a user manual for the 133K8 - check the below linked post. Maybe its useful in advance. http://leatherworker.net/forum/index.php?showtopic=56667&p=383242
  17. I can´t give you an advise w/o having the machine in front of me. I also have a bit of slop when I jiggling the needle bar but thats about 1/2 mm or so and I think it is normal. Skipping stitches is usually a timing problem or your hook tip is worn. Do you know how to time the 29K71? You can download a manual here: http://leatherworker.net/forum/index.php?showtopic=57862&p=372012
  18. Picture is a bit small but it seems to be a Singer 133K8 with walking foot
  19. I recently figured that there is a very interesting "museum" in Bielefeld as well. It is an old factory for household linen and so forth. They have closed this factory in 1980 and EVERYTHING is still at its place just as it was on the day they have left the building. The oldest sewing machine is from 1914 and the newest from 1962. Nothing is put together this is entirely the original factory!!! http://www.museum-waeschefabrik.de/Museum.html Too bad I did not know of it earlier.
  20. I don´t know what they are producing in the new factory but I´m sure nowadays most Dürkopp-Adler Machines come form the Czech Republic (Minerva?) and / or from China. I was just interested in seeing the old buildings but since I was in Bielefeld anyway I just have checked out the new location. Sooner or later I want to visit Wittenberge (Germany) where Singer made sewing machines until 1945. I know the old watch tower is still present and they have a museum in it. http://www.schlingenfaenger.de/sfsite/index.php?id=188
  21. I know them, they have these "flip back and forth thing" for sharpening, right? Are you still using the Rolls razor? Off Topic - but a very cool razor also is the SCHICK Magazine repeating razor - I´m lucky to own one of them.
  22. Some more. The new plant is not very "representaive" I´d say - typical 1970´s style building. The Old plant is awesome - would benice to have a flat or shop in that building!!!
  23. Today I had a trip to the City of Bielefeld - the Home of Dürkopp-Adler sewing machines - but this time not for purchasing old sewing machines. I took the chance and took some pictures of the former Dürkopp Werke plant. And I checked where the new Dürkopp-Adler plant is located. Unfortunately I forgot to take the slip with the address of the former Kochs-Adler Werke plant with me. Damn - maybe next time! So here are some pictures:
  24. Payment received - SOLD
  25. Pending Payment...
