Cowboy Outlaw question on accessory compatibility
Constabulary replied to bigsig11010's topic in Leather Sewing Machines
or you make a flat bed attachment where you can screw on an edge guide or modify yours. I once made this FBA for my Singer 45D91 but on mine I cannot use the 441 roller edge guide but the OEM Singer 45K edge guide that mounts on the flat bed steel plate insert. Note the 3 holes in line. Thats where I can mount guides and accessories. -
The guide appears to be for the JUKI 441 + clones. So w/o knowing the CB Outlaw but knowing Singer 45K´s, Adler 5 / 105 and so forth I´d say either flat bed or edge guide. A suspended flip up edge guide probably is the better option when working with a flat bed. maybe something like this https://de.aliexpress.com/item/1005008728390412 or check this thread: -
How to ease when sewing leather on a 1341?
Constabulary replied to joetroba's topic in Leather Sewing Machines
machine seems to be a Singer 17 or Seiko TE-6 and they have supper small bobbin. Surprises me that they sew with fairly think thread this fairly thick leather with a machine like this > not much thread on the bobbin. When I look at the stitch length lever the it seems to me just a screw w/o reverse - or not? However - IIRC there was a reverse device of the Singer Class 7 that did not come with reverse ex factory... Maybe they tinkered something similar. Well.... lots of guessing here. No matter what they do a great job there - I´m quite impressed. EDIT: weeeeell - I´m not sure - new TE-6 have reverse AFAIK but not sure what I see there. EDIT II: Looks like this one - which looks like a non reverse machine -
Domestic sewing machines
Constabulary replied to Curious Observer's topic in Leather Sewing Machines
thread is coming of the spool a bit the odd way. Maybe one of these thingies may be helpful. However if it works for you then don´t mind. 😉 -
Singer Industrial Sewing Machine Screws
Constabulary replied to shoepatcher's topic in Leather Sewing Machines
okay, may depend on the machine 😉 -
I´m updating here cause I have an Astor M5 on my bench for restoration - the inner thread is metric M10x1.5 (at least on mine). So the information MikeRock got from the distributor is correct. So if you need a cheap tool adapter for M6 or M8 tools / dies then this could be an option: https://www.ebay.de/itm/402466257921 Hope this helps
not sure what you mean... Is it that your last stitch is probably to long and not hitting the 1st needle hole where the seam began? If so then you can shorten the stitch with the reverse lever and hand crank the last stitch - if you know what I mean. -
not sure where how you figured that but I have different experience (I´m living in a metric country). Maybe someone overcut the original threads on your machines. Nothing really metric I´d say: https://www.singersewinginfo.co.uk/technical/parts/screw_threads/ -
Or NTB in the City where the Adlers came from: https://naehtechnik.eu/
Check with Liersch: https://liersch.com/online-shop/ersatzteile/ or Zieger: https://www.np-z.com/ or Busche: https://busche-online.de/ If they don´t have it in the Shop send them an Email - Answers may take longer due to Christmas season.
I never did that drop test, the manuals show how to set the tension right. That works for decades, just follow it. But as always - many roads lead to Rome - or each to his own. 😉
BTW - I put one off these in a plastic box and wired it to the motor. https://www.ebay.de/itm/396873227544 But I´m using it for my electric bobbin winder which run with domestic sewing machine motors. Not sure if this is a solution for you. They are available everywhere and I think even cheaper. This was my project back in 2017 -
servo motor and speed reducer come to my mind but depends on your sewing machine table and if the machines have a hand wheel with pulley and no built in motor. -
these original manuals pop up every now and then. i just recently bought two from a guy in France he still has some: https://www.ebay.de/sch/i.html?ssPageName=&_ssn=zougoulouba
Cowboy 3500 Running when Powered On
Constabulary replied to KYCat's topic in Leather Sewing Machines
Guessing - most likely a motor problem. I guess the machine has a servo motor so I would guess the lever of the accelerator unit or the hall sensor is loose / has moved and is probably stuck in the "run" position. Please post some pictures of your motor and the accelerator unit and lever where the it man rod is attached and maybe a video showing the issue (please not just 5 second video or so" upload it to YT and post a link here. -
yeah - keep that old cast iron alive - I seldom went wrong with that! 😉 I love my 51w but the 2nd type as yours would be even more preferred but I love mine too. Singer crazy me is. 😁
often Ebay is a bit cheaper than Amazon - even from the same seller. Just saying...
Singer 107 W1 Stitch Length not changing
Constabulary replied to ohLyssa's topic in Leather Sewing Machines
make sure the whole machine incl rod and coarse threading is well oiled and the stitch length mechanism parts are not gummed with old oil. -
basically that's it but I would check the needle hook timing too - that never can be wrong.
are all the parts as shown in your diagram present (See text / parts list)? The tip on your adjustment rod is damaged as you already noticed, tip should be very sharp (see picture below). Not sure how much this affects the stitch length regulation. Is the small stud inside the adjustment knurled knob present? Is the coarse threading at end of the top shaft in good order? Please post some pictures. edit: Quick picture of the stud from my 107w1 rod and the top shaft threading. Stud slides inside the coarse threading. -
Check with Fuchs Elektronik in Germany they have the Quick Rotan Service: http://www.fuchselektronik.de/index.php?vid=302&mid=1&lid=2 However - not sure if they are still in business - looks like an early 2000´s website
7x23 are slightly longer IIRC. Minor needle bar height adjustment could be necessary but they may work even w/o adjustment.
sure: https://www.ebay.com/itm/234079435236 this is with what the 31K48 came ex factory but roller size may vary. however we have not seen your machine and how it is set up. Could be this type as well https://www.ebay.com/itm/143603133032
happened to me quite often. Waiting for a better price... for money to come in... lack of time... just being toooo lazy... looking for too long for information... When you see one you want grab it before someone else takes the 1st shot.
gear for 29k machine metal workers please read
Constabulary replied to catskin's topic in Leather Sewing Machines
I think I mentioned somewhere that I may have one.... Will check later.... heading to work now...
