Everything posted by gottaknow
Bartack machine not completing the back stich
gottaknow replied to Cleggy's topic in Leather Sewing Machines
The 1850’s are workhorses and I’ve never worked on a clone. This issue is often caused by worn or glazed cork surfaces which causes slipping during the final barring stitches which is basically the stitch that secures the entire bartack. The other cause can be the push plate needs to be tightened. This can also cause the underbed thread trimmer to not cut clean. To test, cycle the machine with normal thickness under the clamp. I use the handle end of a large screwdriver to press on the push plate during the entire run cycle. If machine cycles normally and produces a quality tack, there’s your issue. As a side note, don’t over tighten the drive belts which can prevent the drive pulley from moving easily in and out. Have fun! Regards, Eric -
Unfortunately no, the arm is just wide enough for an inline folder since it has to run inside sleeves. Also, any folder used on these machines should be spring loaded on the top half to allow a previously sewn lapped seam to pass through. Oh, and howdy Wiz. Regards, Eric
On the curves, the fabric will want to walk out of the folder. Shove more fabric than you think you need into to folder. Lining up your seams takes practice as well. The bottom will want to continue to feed while the top will hesitate. Make sure your presser foot is moving high enough to allow the thickness of the stacked seams. Hold back the bottom ply and don’t pull on the top ply. Lastly, experiment with sliding your folder back just before crossing the seam and with the needles down, lift the presser foot slightly and push the top ply into alignment. It takes practice. Regards, Eric
Looking for an Engineer's Manual for a Juki DLN-9010A
gottaknow replied to JJN's topic in Leather Sewing Machines
The little bit of tail thread stuff is normal. You can use smaller needles without doing much. Size 16 should be fine. The difference between the SH machine and lighter weight machines is the feed dogs and throat plate. That direct drive is a great motor. The hook oiler adjustment is common. After the machine is well broken in, you’ll probably need to dial it back a bit. Regards, Eric -
That’s a great machine, we have 50 of them in our LA factory. I’ll find a link for the manual you’re looking for. The length of the tail thread is controlled by the pre-tension. It should be 30-40mm long depending on thread and tension. It will vary. Regards, Eric -
Need supplier of needles for vintage Singer 111W113
gottaknow replied to jjs111w's topic in Leather Sewing Machines
I would drop the needle bar down and use the 135x17 needles. Easiest way to do this is to rotate the hook point into the scarf of the longer needle, remove the long needle and make sure you don’t turn the handwheel. Insert a 135x17 needle, then loosen the needle bar clamp. Tap the needle bar down until the scarf of the 135x17 is centered at the hook point (which hasn’t moved), tighten the needle bar clamp screw and you’re done. Regards, Eric -
The tube that runs from the oil pump to the top shaft can end up against the shaft that actually drives the pump. In time, it will cut through the tube. If you keep an eye on the sight glass, the oil should bubble up indicating the tube is intact. For a visual inspection, you can remove the back cover and actually inspect the small, clear tube. Regards, Eric
If the hooks are sharp and set correctly, no need for right twist thread on the left needle. Regards, Eric
This machine will be a lot happier with top thread being T135. Regards, Eric
Bonded nylon is specified for the vast majority of tactical items for the DOD. A company I used to work for had a contract for suede welding jackets. Chrome tanned leather with Kevlar thread. The Kevlar thread isn’t bonded and it’s like sewing with dental floss. Your hooks have to be sharp and set very precise or it will fray while sewing. A buddy of mine that has been making hot air balloons since the 70’s uses UV rated bonded polyester which is about the nicest thread I’ve ever used. Strong like bonded nylon, but with a much softer hand. Sews like a dream. Regards, Eric
Buying Keestar Sewing Machine 441 Directly From China..
gottaknow replied to korokan's topic in Leather Sewing Machines
The company I work for is a DoD contractor. Everything we produce for them has to be Berry Compliant. This assures US made textiles, including all the raw materials. I began working in a sewing factory in 1980, even then companies were exploring overseas options. The price of industrial machines has little affect on our bottom line as the ROI is very quick, long before the typical depreciation period. We also bypass the US dealers at a substantial savings. For the home hobbyist, a much bigger impact. We do import the vast majority of our non tactical items in order to compete in a very competitive market. NAFTA hurt the US textile businesses but it was the low overseas labor costs that really sank our ship. Regards, Eric -
Love the ZeroMax. When run continuously, additional cooling is a must since they are entirely enclosed. Their endless configurations make them very usefull in a factory. They are however no joy to take apart to change a bent shaft (pretty common). Regards, Eric
Not that I’m aware of. A properly adjusted old school clutch motor is an excellent variable speed motor. Regards, Eric
Lubrication on newer "dry head" machines
gottaknow replied to R8R's topic in Leather Sewing Machines
Juki’s come out of many different factories. Some are still made in Japan, most in China. Garment machines require lube that can be cleaned out of fabrics with an atomizer gun and solvent. Most lubes don’t meet this requirement so you end up with a bunch of oddball stuff nobody recognizes. The dry head system was developed because the machining tolerances are poor on the Chinese units, they couldn’t keep oil in the heads and it was costing factories a lot of money for cleaning sewn goods. They sold the catch phrase dry head when it should be called “we can’t keep the oil in”. The different lubes are likely a result of regional factory locations. Juki A is your best bet, it’s the most common over all their many classes. Regards, Eric -
A decent alternative lube is TriFlo grease. It’s a touch thinner than white lithium, but soooo slippery. I like it for used machines because it will loosen up a dry head making it quieter and smoother. It also doesn’t get pushed out with rotating components like thicker lubes do. Regards, Eric -
The 1900 series has morphed over the years. Decent machine heads and inexpensive parts. Brother has however left them in the dust when it comes to their software. I have a highly modified 1900 for webbing applications and it never misses a beat. Regards, Eric
That clang at the end was the stop motion on Singer 269 class. Music to a mechanics ear.
What model singer is this? Will it do thick veg tan leather?
gottaknow replied to myjtp's topic in Leather Sewing Machines
Singer 269 class bartack with a Camatron modification. One of the series of machine that taught me patience in the early years of my career. It was good clean fun until the stop motion got out of whack. My preference for old bartacks is the Juki 980 class. Regards, Eric -
We buy Brother and Juki direct from China. The savings enormous. That being said, Wiz is right about the support and warranty issues. For us it’s a non issue since we’re a factory with 3 full time mechanics. We’ll get the occasional bad control box, but just order another. We always check the settings, and trust me they sometimes don’t sew a stitch right out of the box. I always advise folks to use dealers, it just makes sense. Regards, Eric
Actually we’ve had digital automation for more than a decade in sewing factories. Brother has led the way. We make gloves which lend themselves to automation with lots of little components. It’s expensive up front, but the ROI is usually less than a year, often much faster. Most hobby sewers can’t drop 24k on a single machine though. Regards, Eric
Filson Factory Auction Dozens of 211W151 Starting at $20
I went yesterday to the factory where I spent almost 8 years of my career. I bought 3 pieces of equipment that will be a reminder of my time there. It was weird seeing the building so empty. I ended up with the Utica Mills combo slitter. I had rebuilt this machine 3 years ago, so I knew it was in good shape, and we needed another one. I bought a small heat press while I’ll rebuild, and a 5hp vacuum motor. It had been factory rebuilt a number of years ago. Factories use vacuum systems for various things. I obviously had a huge advantage in this auction since I knew all of the machines. Some people didn’t have a clue what they bought or what the machine actually did. I took a final look around and then walked away, making the long drive back to Seattle. I’ve had a long career and am currently working for the 6th apparel manufacturer during a 38 year span. Not bad I guess for an industry that has been devastated by importing. Regards, Eric -
The vast majority of the Singer and Union Special machines were all originally owned by Pacific Trail Sportswear. At it’s height of production in the late 70’s and early 80’s there were over 600 machines. These are the machines I built my career with beginning in 1980. This factory shut down a year ago. I was the head mechanic there. I have fond (and not so fond) memories of the machines. I worked for Filson for 3 years, but over the course of my career I was the head mechanic for these machines for a total of about 13 years. There were other mechanics in charge during the years I worked in other factories. I worked in this particular factory for 7 years. At its peak in the mid 80’s while it was a contract factory we had 300 operators. So for me, this is the end of an era, I’m happy with my new company, so no looking back. The 211 151’s are the best deal. Needle feed, bullet proof. They have been in storage for 20 years or so. Our main machines were Juki 9010’s and 3578’s double needles. Before those we used the Judi 5410’s which meant the retirement of the 211’s. I didn’t look through the entire auction, but there are a few 211W157’s. They actually have reverse and are set to use 135x17’s. Still needle feeds. The Singer 300w’s are my favorite chain stitch machines and we’re still in use to the end. The Juki LU562 was rebuilt a few years ago by me and sews like a dream with T135 thread. A few of the Singer 153’s are well loved, but decent. I debated whether or not to comment on this thread, but I at least wanted to share some history. Hopefully my PM box won’t blowup with questions, as I likely won’t respond. I simply don’t have time. Regards, Eric -
I’ve always used white lithium on cork clutch surfaces after deglazing them with some 220 emery cloth.
Remove both tension discs and degrease them. Then take the flat side of each and polish them on a piece of 800 grit paper. Put it back together and readjust your tension. Take Floyd’s advice and rotate the last thread guide 90 degrees CW. Lastly, see if you can use less needle thread tension by loosening your bobbin tension first, then adjust top tension to balance. Thread that is old or is of low quality get dry and will crawl right out of the tension discs. Have fun! Regards, Eric
Hey Greg, Think of that component like a take-up adjustment on a chain stitch machine. If you want to measure the difference in thread pull off, you can thread something you can mark with a Sharpie, (like white thread). Sew on some material stopping with take up lever at the top with the needle up. Mark the thread where it comes through the first thread guide, and again at the eye of the needle. Cut and pull the marked portion of thread out of the machine, rethread and sew after adjusting whatever guide you want to the opposite position. Repeat the sewing, marking of the thread etc., then lay the two marked samples side by side. I do this on chainstitch machines to see which adjustments do the most, and which ones are more or less just guides. On lockstitch machines, you may see no difference at all, or some differences. As a general rule, I always set adjustable guides in the middle of their travel and seldom move them after that. It’s not an adjustment that requires much fuss, the check spring travel and stiffness, needle tension, are much more critical. It’s kinda interesting to do that test, some machines don’t change in the least, others just slightly, few make a bigger difference. What’s interesting, is look at some old Singer machines and you’ll find no adjustment at all. I suspect Singer made their take up levers exactly the right length and with the correct amount of travel. Regards, Eric
