Everything posted by immiketoo
With the galvanized steel, you would most likely be looking at an avenger style holster or one that is folded at the sight channel. The reason steel is nice is that's malleable. You can lay it flat, carve your leather, stitch it inside and then curve it to the shape you want already tooled and stitched. The glue and stitch line will keep it in place. It is a process of exploration for you and there is only one way to do it. Prototyping and as you said, to wing it. IT doesn't change the overall design much, but it opens a lot of doors. Have to agree with Dwight here, 4 layers of molded veg tan can be very solid, and it will take a lot of abuse. I hadn't thought about rawhide. Good call!
If you already have a pattern, adding a steel insert should be relatively easy to adjust. I use galvanized steel in mine because its firm, thin and malleable. Kydex is a pita but doable if you have the skills. Usually, you just add a stiffener between leather layers, but if you wanted to , you could build the whole rig in metal and cover with leather.
ELWATS 2018, Arnhem Netherlands (Pic heavy)
immiketoo replied to immiketoo's topic in Leatherwork Conversation
I have seen a lot of leather art, and that tiger is amazing. The bracelet was out of his bag for 5 seconds and I said I had to have it. Fine work for sure!- 12 replies
- leathercraftersjournal
- iloveteaching
(and 1 more)
My true heroes are those who inspire me to do better. And those who challenge me to keep improving. As examples, Bobby Park took me under his wing at Sheridan the first time while in his class, Serge Volken and Bob Beard have mentored me many times, and Peter Main with his subtle nudges in the right direction have each have influenced me significantly, while encouraging me to have my own style. All of the above people teach paid classes at various shows around the world, and I have gladly given my hard earned money to each of them and would do so again. Why? Because nothing is as good as being immersed with a master for a few days with them looking closely at what you do and offering advice about how to improve.
Perfect reply.
What if you leave it oversized and trim after you stitch?
Ok, here's what I do. I glue an over sized piece and then trim it to the proper size, making sure I glued past the line where I want to cut. I also tap my edges where I glue. TAP, not whack, and I use a mirror smooth cobblers hammer which leaves no marks in the leather. Once it is dry, use a sharp knife to trim your piece to the desired shape and you'll never have that problem again. Tapping the seam where you glue ensures the best bond possible between the pieces and you'd be hard pressed to separate the pieces.
You're stitching too close to the edge, or you're using thread too thick for the distance of the stitch line from the edge. My suggestion is to use thinner thread, or move you stitch line in a bit further. You'll never have that problem again. You also may try cutting your piece out after stitching if possible. Then your edge will be ready for edging and no ripples.
Sand Belt Edges After Bevel & Before Burnish
immiketoo replied to superpacker's topic in How Do I Do That?
If you make your belts slightly oversized and then cut them to the width you want after everything else is finished, you have a perfectly smooth edge. Then bevel and burnish. Theres nothing smoother than a freshly cut edge. Except a burnished freshly cut edge. -
Question. Have you let everything dry thoroughly before applying a finish? Sometimes, dissimilar products react poorly with each other. I had completed a pair of barstools and the finish started to crack then flake off. I hadn't let my dye fully dry and the solvents killed the finish. A suggestion if you haven't already tried it is to pre bend the fold a little while the leather is lightly moist, then add your dye. Stops a lot of spine cracks, but you may end up with wrinkles when its open. Lastly, try RTC as a finish if all else fails. Its easily the best finish out there in my experience.
Gengado, At four months, most of us were still trying to figure out which end of the tool to hold. Your wallet is functional sound and it looks well made. You lack experience with making things out of leather, and in this craft, mistakes equal experience. Unless you have a mentor showing you how to do things, it all comes down to trying something, and in that regard you're already way ahead of folks who read a lot but never try anything. Each time you make something, whether it has mistakes or not, you learn how to or how not to do it in the future. People who are masters of the craft have made all the same mistakes and a thousand more. As mentioned above, learning how to hide them is key. Eventually, you'll have enough experience to know how to avoid mistakes MOST of the time. Nice work.
This happened because of the inconsistencies when using a dauber. They are heavily loaded at the beginning and lose dye as you move it. There are very few colors that will apply smoothly at anything less than 100% saturation. This is why people gravitate toward dip dyeing or air brush. Lighter tones are possible with thinned dye when dipped and sprayed. It CAN be done by thinning and daubering (made that word up), in circles, but I've never had the patience to figure it out. Looks like you had good luck with full strength.
Munky is correct. Serge is a great man and mentor. He's also a great teacher. I am the ginger in many of the pics, and I'm older than I look.- 12 replies
- iloveteaching
(and 1 more)
Items stolen from Boot & Saddle show in Wichita Falls, TX
immiketoo replied to Johanna's topic in Leatherwork Conversation
There's no statute of limitations on being an asshole. Rest assured if I ever find out who was responsible, they will regret it. -
It was the least intimidating place ever. EVERYONE was super nice, and helpful. All of the instructors there are awesome at their job and you can ask them anything. This is why I love trade shows and push people towards them so much. I learned more there in my first 6 months and it set the course of my career for sure. Arnhem was as good or better than any other leather show in existence, and it is now my favorite. What an amazing place. Kathy is adorable, and truly gifted. Plus, she lugged that and a box of tools across the world for me.- 12 replies
- iloveteaching
(and 1 more)
The weather in Arnhem was perfect fall weather, but yeah we have the sun here! as for the slabs, yep. People from all over dragged them with! Gotta love leather workers!- 12 replies
- iloveteaching
(and 1 more)
Everyone said they loved class. Took 8 hours to teach it. Everyone had an embossed Popeye by the time we were done. I had an absolutely amazing time. I want to live there, it’s that good.- 12 replies
- iloveteaching
(and 1 more)
I had the honor of teaching again at this year’s ELWATS in Arnhem, Netherlands along with some great friends. The city of Arnhem is an amazing, world class city filled with history, culture and warm, friendly people. Oh, and the night life is great! I can’t speak highly enough about it. Charil and Ralph, along with the help of a local leather worker, Danielle picked an amazing venue and organized a show that rivals Sheridan or Prescott. My class consisted of 7 students from all over the world, including Canada, Spain and the Netherlands. They were a talented group of individuals of all levels. The best part was hanging out with my international leather community friends, especially those I don’t get to see often. Kathy Flanagan and I were across the hall from each other, and we finally got to exchange work pieces! I love my tiger! Enjoy the pics and if you ever have a chance, be sure to come to Europe and see the show. I guarantee it will be a good time!
- 12 replies
- iloveteaching
(and 1 more)
Depth could be part of the issue, although it looks plenty deep to me. I think its because of the smooth pear shaders. Textured tools hold antique much better than smooth ones. Another option is to use a block dyeing technique when you wipe off your excess antique. Put a block of wood or firm foam in your paper towel and only wipe the surface. The block will prevent the paper towel from wiping out the antique in your recessed areas.
Fine work, Matt. All the way around.
How to avoid presser foot marks?
immiketoo replied to lyricsonwings's topic in Leather Sewing Machines
I adjusted the tension on my foot until it barely touched the leather and added tension until it left a faint mark. Then I backed off a bit and polished the foot. Mine doesn't leave marks and it feeds fine.
