brmax
Everything posted by brmax
Another agreement with the holster/cartridge belts. Thats some bigger leather I think, and to much of a stretch for the smaller machines you mentioned. The fabricator machine they have is an upholstery class size and peferfectly fine for smaller thread 138. This is their competitor as many brands have and are a copy or partial copy to other older bigger names. And thats just todays world. That model comes with a servo, its first benefit is slower controlled speeds, somewhat slower start speed, this is a fact. The others are their kinda quiet and maybe cheaper on electric as ya know. So with that model they have, similar choices can also be had in other brands. These and others with some dealers that are mentioned on the site here sometimes. In any case it will be a happier choice with a servo upgrade, and with their smallest pulley option for it. Have a good day Floyd
- 5 replies
- budget
- lightweight
(and 2 more)
Ya thats really nice work there. Good day Floyd
With projects in leather I would think as much as flat bed machines. In all honesty there are so many leather Pros on the site here that have been doing these task so much more than me, I have to ask them to cover that better. I feel it still is the very slow speed that many projects require that pushes one to consider this option. Theres no doubt more torque and thats a plus in starting, but my servos gave a slight grunt from a stop but marched confidently no problem. Still a bit more torque is a wise motor maintenance thought. I would like to try one in the next few weeks on a cylinder arm. Good day Floyd
Sure, initially I had thought needle positioning. This feature is great especialy in upholstery and the like. Yet this option has limits of capable usage when reducing the speed of a machine much with pulley reduction systems. Particularly the speeds leatherworkers like to use. Theres the top shelf 1541N7 that would be a realy realy nice upholstery setup. And as always the Durkopp machines that, uh well just rule. I can only dream Anyway the 1508N top loader your considering is nice and the NH is even better. These are a bit tougher machine in my opinion relating to their needle and hook arrangement. They are just made to punch holes effeciently ( i dont really have to make an opinion on that, the price should be a tell ) as you well know. Tip: Put the extreme smallest motor pulley on with all your servos and try that and have fun! Floyd
I agree with you those choices in cylinder arm machines like 1341 or the 26 are great choices. You sure dont want a dozer doing shovel work. Seen that to many times! Remember they all can be made great and they all had one for their goal. I thought a bit myself about this and particularly like the access ability of the newer machine insides. And so a 1341 at the moment was my luck and available. Other than that there are few and subtle differences in these newer choices. To be honest there are 1342 model machines and clones also, or I had seen some a couple years ago. These have an additional neat feature. But again the majority of your work obviously sounds like 138 thread and under so good choices you all made. The local shop is always a respectable choice to start some level of business with. For sure this can be an advantage with ability to sit in front of a machine for your future use. The easy usage of a machine choice far outweighs the dusty one in the corner. In closing I would respectfully say the flat bed machine needs more conversation in that the nice efficiencies of a machine “these days” are available to canvas and upholstery that you honestly dont use in leather projects, or I should say you may like but cant have all of them. Good day Floyd
Im sure The ball park figure on that newer Juki is in the $7K range for starters. With that Im not qualified to run it good day Floyd
Most all machines your looking for will come standard with a toothed feed dog on bottom with some finer than others but this is the norm. I will say only the dealers around here chatting sometimes have on hand all smooth replacements if that is a need. Good day Floyd
I like that Singer back there, always wanted one and none were in the papers. Then when I do find other machines here they all show up. I believe that 156 has been sitting for awhile so a watch to see if it works would be the big sale observation. They have been or are possibly a member I havent a clue but a better price would have interested me several years ago. That machine may take a bit of polish and tune. I suspect this anyway, just as many new ones do. Good day and have patience Floyd
Suggestions for slowing down machine
brmax replied to rockthecasbah121's topic in Leather Sewing Machines
It may be two different task your decribing that can be done. I believe the first she could be refering to is the “ needle positioning “ this is a electronic motor setting, be it servo motor or older clutch type with great electronics. The second is an attachment your mentioning; there is the presser foot that can raise with your knee on a cushioned lever and or by hand near the needle, with another lever. The electronic needle positioning may only work correctly with the reducer if a reduction ratio is limited to 3 to 1, this has been talked about in post somewhat. So it may not work. Good day Floyd -
Timing got off with reducer pulley!
As best as I can see the hook looks to be in the scarf area. Though it may need to sit a bit lower, so the point is above the thread slot of the needle. As mentioned, and its happened to many the needle needs to be checked so its up in its mount fully. Good day Floyd -
I cannot be positive but, as in his normal ads he has stickers with his name on any machines he sells. Like in his home base of Tennessee so I dont think the shop in Hurculaneum is his, imo. He did though put in a new shop in west St Charles. With all that out the way I have seen some great machines in the CS ads in Saint louis, its just the waiting. But your price could be better estimated at 1200. for a great litely used machine, possibly with a newer servo. They seem to run at two bills. They all will sew pretty much, I say that just to relate to particular materials being made and so they can or could be tweaked for that. That should be kept in mind I think. Good day Floyd
To me it really does look easy to cycle the lever. The repetition could be the workout I agree. It has my interest in all its functions and such, yep! Pretty cool. Good day Floyd
- 28 replies
- cowboy outlaw
- cowboy outlaw sewing machine
- (and 3 more)
I would try to be patient and keep a real good eye on craigslist or some local sales. In the mean time keep stitchin away building the bank. Good day Floyd
A video would possibly be a great help. I am trying now this morning to reconsider the mention: accelerate to the problem, yet if let off and re-accelerate quickly this issue disappears. Good day Floyd
You may have done this already. But if you can eliminate the machine belt, so to check the other drives. This may isolate an issue easier. Also it seems this aproach also works for listening or feeling the machine issues. This can be a great method in troubleshooting. Good luck and keep us posted Floyd
Help choosing my first industrial machine
brmax replied to MStone's topic in Leather Sewing Machines
Any of the machine companies most likely will send their product by truck freight. In total this would be the cheapest I’m sure. Figure that amount, it’s not much of a negotiable cost. Although the cost can be moved about within the dealer cost and profit. Probably need a project list to have a more specific answer here. As this question can lead several to suggest a thread size. So with strictly 69-138 the standard machines are great, with standard adjustments. Now finding a longer cylinder arm non- shuttle machine. Well this is a real stretch I believe, best of luck though. Good day Floyd- 23 replies
Increasing snap hold? Solid brass snaps?
brmax replied to bradkincaid's topic in Hardware and Accessories
You may have to locate a seller with quantities your intetested in. Sometime this is the kicker. With that the Scovil company is a pretty old supplier. I can say with this company the Durable snaps they offer that are plated with nickel are brass based. Or the ones I get in 24 size but they do make a lot. Anyway each snap has a spring in it, this wire is brass in color; for regular tension. The tougher snap offered has a bronze color spring, wire color. Now ya know the rest of the story. There seems to be many companys now that have some really cool styles and finishes. I am only familar with the above, good luck. http://www.scovill.com/products/ Good day Floyd -
Newb question on changing pulleys to slow down machine
brmax replied to EvanBrent's topic in Leather Sewing Machines
You scored bigtime! I also agree, even with the 40mm smaller pulley, its only a bit slower. With yours or really all others interested in leather particularly. The reducer pulley systems offered are the best option. These will seriously put you where you want with control. Thats more than two cents, but all I got so Floyd -
If you could find and replace the lower pulley as mentioned, it would be in your best interest. Good day Floyd
Just Picked up a Pfaff 138 - Time to Get It Sorted Out
brmax replied to JJN's topic in Leather Sewing Machines
I can say two things factually : that machine would look better in my shop : ) The other is that machine must have been in a clean corner in its past. Nice find! good day Floyd -
Needle Size, Thread, Spi And Leather Weight Rule Of Thumb?
brmax replied to Bluesman's topic in Leather Sewing Machines
Thank you Wizcrafts, as I had been curious lately and wondered if the 3200 may have different and or lighter tension and presser spring. Good day Floyd -
What other company’s are in your locations. Just thinking here and curious if somethings in the U.K. Especially within a 250.euro range and is obtainable with reasonable shipping or freight charges. Good day Floyd
I am extremely happy with the Olfa 60mm rotary knife. I do think this can be another tool for your task there. Initially after hearing almost the same I got interested. There was a good discount coupon ( like 40% off ) for the craft store and this was the boost. I can and will say the blade out of the box is excellent. With smaller corner cuts a different or smaller diameter blade would be a benefit. ( both my and family member opinion ) The Fiskars brand I have acquired has a smaller 45mm diameter blade. I still have both with original blades installed this Fiskars blade is not as sharp period, and this at its beginning. Although the handle does give a better sense of safety, with its style, but if more pressure is required this safety sense aspect is lost. Just my opinion ( i do have extra blades ) For reference: olfa usage, 2 year, 30 yards of cuts, marine canvas, leather trimming. As above just refference: fiskars usage, 4 months, first 5 yards thin cotton fabric I think these rotary blades are, just a tool and have a place. Its my best opinion a couple lengths of protective straightedge can be a great addition with these. There are some benefits if the straight edge has a gripp type bottom surface. Good day Floyd
Thanks for the reply, it helped steer me away from thinking any capacitor issues. I have to mention an investment in a Servo motor will be a good choice. It will help a serious amount in a slower machine speed. If an extreme reduction is needed the use of a pulley speed reducer is warranted. These can be purchased and or built, there are some very new styles. These new styles have some benefits, in either case the reducers do have a steep cost. A point to think about is the factory handwheel pulley, most are very small diameter. This as you know is for speed, as garmet sewing is all about putting out the products, a lot! Good day Floyd
We initally should ask or address your mention of “ it needs quite a push”. So I think I might understand one reason but more importantly the picture leads me to this question: When does the motor need this push? Is it when the power is turned on or well after and any time later when you want to hit the sew/go pedal. Good day Floyd
