Everything posted by Weaver Leather Supply
Are you looking for the line 20 (Dot or similar) snaps? Or something else?
Weaver Leather would like to introduce our Leather Craft Expert Chuck Dorsett, with Weaver Leather Craft Supply. From step by step instructions on projects for crafters of all skill levels to tool tutorials that help you discover new and creative ways to use your tools. Chuck has something for you in this breakout series of video tutorials! Check out the links below and let us know what you think. To learn more about Chuck, please visit the following link: http://www.weaverleathersupply.com/learn/about-chuck-dorsett For some educational videos with Chuck, containing plenty of tips and tutorials on mastering your leathercraft, please visit the following link: http://www.weaverleathersupply.com/learn/master-your-leathercraft We hope you enjoy Chuck and his videos.
TomG, let me know if i can help. We should have what you are looking for. My direct line is 330-521-7592 or send me an email at dustint@weaverleather.com I can send you some samples if needed.
Weaver sells the exact same red can with brush. Retail site www.weaverleathersupply.com and the item # is 65-6075, you can put that in the search field to pull it up. This is also available in our wholesale catalog.
Hermann Oak natural veg will be fairly firm. The back sounds like a typical dry-split piece of leather. Shaggyness is normally loose flesh which is also not desirable in a good piece of leather. What are you planning to make with it? If you are going to be doing any tooling or carving you want that firmness to accept nice crisp stamping. The finished piece will soften up some if you oil it and with use.
Both the 4 blade and 2 blade model come standard with #2 blades, but you can request another size when you order it and we will accommodate switching them out. We have sizes 0, 1, 2, and 3, similar to your standard hand edger sizes. If you have any other specific questions on either machine, let me know and I will be glad to help.
what is it I cant use on a side?
Weaver Leather Supply replied to Boriqua's topic in All About Leather
We have 3/4oz drum dyed Chahin English Bridle. Nothing in strap/tooling in that weight dyed however. -
We have a 103 and a 104 rivet. Our 104 rivet should have a 1/8" tube and a 5/16" head. We also sell a 103 which has a larger tube diameter and head diameter so i think the 104 is specific to the tube and head size. But yes, you should be able to find them anywhere Weaver is not the only place. However, our 104's do have a flat head and I am not sure how the driver will work with a domed head rivet. Sorry to hear your account was closed. The requirement is $1200 per calendar year, and if you don't hit that and are closed then it takes a $500 opening order to open back up. Once open again there is no order minimum through the year. If you wouldn't hit the $1200 in 2017 then again next year you would need a $500 opening order. I understand your frustrations, but just wanted to clarify. You do not need to place a $1000 order to be able to buy wholesale. The anvil you need for the cap is our item # 65-6455 and is available for $18.25 on our retail site www.weaverleathersupply if you choose not to open your wholesale account back up. Good luck with your Little Wonder.
If you can cut a small bit off take it outside with a lighter and hold the lighter to it for a minute or so then let it smolder a bit. If its chrome the ash will be a bluish to greenish tint. Veg will just be normal ash.
If you find a setter I bet you could use a copper burr for the washer as well.
These look like a regular tubular rivet set with a washer and a rolled edge vs a double cap or a splashed/split back. I have seen these used and they make a nice finished smooth look. However I actually do not know where to buy them or the setters.
You guys are correct that none of our double shoulders are from Chahin, only sides. I am not sure if ALD natural shoulders are Chahin tanned or not, I would ask before you order to confirm that. We basically carry a line of strap/tooling, English bridle, latigo, harness, and skirting from both Hermann Oak and Chahin. I would be glad to discuss leather with you further if you have any questions or get you out cuttings of anything you would like to see. Shoot me a pm if you wish...would like to hear which line of double shoulders you had an issue with as well and I would check into that also. Thank you -
We have a heel bar roller buckle in black in 1", 1-1/4 and 1-1/2. We also have a 225 snap in 1"...but it is the standard style snap and a round eye. We will have more in our line of black hardware in our next catalog in April, and I believe the scissor style snaps are on that list. The item # for the buckle is our 00050-BA-1 00050-BA-11/4 00050-BA-11/2 http://www.weaverleathersupply.com/search/Search/00050/001/10
What I understand about the dyeing process is that aniline is more the type of dye used. Not the process. For instance you can have an aniline drum dyed leather. And neither aniline nor drum dyed necessarily means struck through (the color is fully penetrated through the center). Aniline is the type of dye (it is translucent and allows blemishes/wrinkles/scars show through) and drum dyed is the process of dye application. So, you are correct in that most people wanting a full grain leather wants an aniline dye so that you see the natural characteristics. What you see in the center is not necessarily cheap leather. A lot of harness and english bridle leathers are not struck through so they will have a natural center. I am not 100% sure what allows a drum dyed leather to be struck through. I believe it is a combination of the ph level and time in the drums. But all drum dyed leather should have some penetration into the fibers. Now in your chrome tan leather that center will be a bluish gray, which is the color of a chrome tanned hide before finishing. The alternative to drum dying is spray dying in which you can apply an aniline dye but there will be very little or zero color penetration. Then you have the alternative to aniline which is pigment. Pigment is non translucent and will cover blemishes and defects. A combination of the 2 is a semi-aniline. A lot of chrome tanned leather is top grain (surface grain has been buffed off to remove defects) and then pigmented to give it uniformity (and you can use low grade hides).
We are looking for a Randall R-12 strap cutter. If you have one to sell or even any leads please PM me. Thanks!
how to identify chrome or veg tan
Weaver Leather Supply replied to chuckgaudette's topic in All About Leather
We are seeing some leather being sold as "synthetic tannage" but i am not sure what it is. -
Working with really oily leather
Weaver Leather Supply replied to JerseyFirefighter's topic in All About Leather
Weaver sells their Strong Leather Cleaner. We use this in house to remove excess fats and things from leather. Then you can follow it up with the Spew Remover which locks in the fat and stops it from coming back up to the surface. These are both in the new Master line of leather care products. These 2 products I have personally seen used here on multiple leathers. They do work. The cleaner will take the residue off with little effort, then you follow up with the Spew Remover. Be sure to follow the directions on each for best results. -
You can buy custom steel rule dies retail and you just have to pay sales tax. Again, if you want a quote, send me an email. No obligation to buy...
Just seeing this post. Weaver makes clicker dies in house as well. We can take any file as far as I know, including CAD as well as traced drawings, or cut patterns in the mail. No obligation for a quote. We strive to keep lead times at a week, sometimes they stretch out 2 weeks depending on how busy they are. We can take your die orders even if you are not a wholesale customer. Any questions, or if you want a quote send me a pm on here or an email at Dustint@weaverleather.com and I will get you in contact with the guy who does the die quotes. Our standard steel rule is 4x32mm Viking made in Austria.
That is an interesting video, I hadn't heard of that test before. I have done the burn test. If you burn a corner of the leather the ash on the chrome will turn visibly green. However, I don't know about retans and if they perform like a straight chrome or veg in these tests, or a combination. -
The word on the street at the Rocky Mountain show in Sheridan was that Sheridan Leather was still planning on hosting this year but then that was it. We have not heard confirmation of this from a firm source one way or the other however.
Weird specks from wet forming
Weaver Leather Supply replied to Flexo's topic in Leatherwork Conversation
If you keep having issues with the spots Weaver sells a product called Pro Carv Casing Concentrate that you put right in the water before you wet your leather. It will eliminate those specks from what we have seen. Whether they are caused by something in or on the leather or the water. We have had some people still get the spots even using distilled water. The Pro Carv has always worked. We also use it here daily. -
Recommendations For Veg Tan Hides?
Weaver Leather Supply replied to treq10's topic in All About Leather
We are a Hermann Oak distributor, and carry the full range of natural strap/tooling weights from them. We also carry Chahin natural strap in a full weight range. American Hides tanned in Mexico...very good quality tannage from them as well. We also have imported double back and double shoulder options in 8/9 and 9/10oz...the double backs are clear pasted on the flesh side. We also sell natural belt blanks anywhere from just cut straps to edge painted and buckle end punched. These are cut from double shoulders, not strap sides. We also offer a strap cutting service on any leather we sell, or a cut and edge bevel service. These are priced on a per hide basis. We sell retail here, www.weaverleathersupply.com If you are a wholesale eligible business PM me and we can get you setup with wholesale pricing. -
Weaver has a new line of black anodized that will be in the new catalog coming out in April. Some of it is in stock now. We do not have a scissor snap yet. If this line does well we will expand it, and a scissor snap is something that would be added next. We have a roller buckle (not the standard 999 style, but a nicer shaped #50), a dee, a ring, and a 225 snap.
Distressing yourself is an option. I wouldn't do a whole side though in case it doesn't turn out nice! I have seen people use many techniques to distress straps, driving over on gravel is one. Also a sanding block to the edges and slightly on the grain side in places. With some finesse this can look good. Beating with a chain is another method i have seen. Why are people requesting they not be veg? There is a lot of latigo that is pure veg these days so that may not get you away from veg anyway.
