Everything posted by grmnsplx
I see no difference in the methods. Left needle first, right needle goes over, then thread on the left is cast over the needle.
I purchased a double shoulder or the warrior when it was on sale av few months ago. I had had my eye on it. The thing is that not all of them are the same. I gad to pick through them but there were a few that were stiffer and had really fine pebble grain pattern. Lots of wax in it and it burnishes wonderfully. Looks like black plastic. And it does tool.I didd just a tiny bit with some stamps. I had talked about how there seemed to be two different leathers and he agreed that the newer stuff was different and that he much prefered the previous stuff. I'm not sure if this is permanent change or just the one batch, but I imagine they changed the supplier and thus the product. Looking at the sides thete seems to also be the older waxy awesome stuff and the newer less impressive stuff. For all I know, it's just an inconsistent product. One piece of leather ends up in one place in the drm/pile/whatever and gets more or less of a tanning/dyeing/conditioning agent and comes out different.
Yes south america is what I understand.
Teach me!
Interesting. I recently bought a tandy splitter. I just used it a few time playing around with it. I was looking at the cowboy, but the tandy one was on sale so I got that. I must say though, the design looks identical to me. but for plastic knobs and a different paint job, I think they're the same... Anyway, the tandy splitter worked fine out of the box. I split some 8oz and 5 oz veg down to 3oz and then I split that even further. I then grabbed a 3 inch wide piece of 2-3oz chrome tanned calf and split that in half or better. I was impressed. Sorry to hear about the cowboy. Maybe I dodged the bullet.
Walllet Makers.....reinforcing The Fold Of A Wallet...
grmnsplx replied to thekid77's topic in How Do I Do That?
I think you'll probably be just fine with your thin(ish) leather. -
That looks awesome!
Just FYI, 9 spi = 10 tpi (stitches vs teeth)
Stingray Lady's Wallet
grmnsplx replied to Windrider30's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Just a matter of taste, but I would have gone with a black thread. The stingray is flashy so there is not need for a highlight. I think the white thread kind of takes away from the stingray in that sense. Stitching looks pretty good though. I've heard quite difficult to sew that stuff.- 11 replies
I am also interested. taobao.com is almost entirely Chinese so searching it is a problem (for me). Have you got a contact for the seller? perhaps they also have an Alibaba store?
When To Stop Buffing?
grmnsplx replied to cldpsu's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Is it possible you got glue on it? -
Yes, there are some timelines around that stuff. But in general, if a name or brand is no longer in use, you give up your rights to it. As to the original post, sell the shop with or without the name and work out whatever arrangement works best for you. Be prepared to accept the fact that what happens afterwards is almost entirely out of your control (which is as it should be).
Actually, if you stop using a trademark (i.e. you close Lewis Saddle Shop) then you give up your trademark rights to the name.
Slotted Sides Messenger Bag. (Courtesy Of Opus56)
grmnsplx replied to tboyce's topic in Patterns and Templates
excellent -
Messenger Bag
grmnsplx replied to opus56's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
awesome! -
Need Help Fast - Fixing A Stitching Mistake On A Gusset
grmnsplx replied to Sjohnsone's topic in How Do I Do That?
What about just cutting the front panel to fit the gusset? I mean, cut the top off at an angle or swoop. Make it part of the design. You may want to be more aggressive than just half an inch, though. Snip the gusset and front panel off at 3 inches on the right side. I'd keep the back panel and back side of the gusset the original intended length though. -
I would try gluing the liner while the binder is half closed. If it's fully open and you glue it like that, then when you go to close the binder the liner which is on the inside of the curve is being compressed. Now, if you were to glue the liner while the binder is closed, the opposite would happen. if you open the binder, then the liner will be stretched taught, while the outside is compress and gets wrinkled up. Both, the liner have some give in terms of stretch and compression which is why I suggest trying something in-between. The result may still be undesirable though. you'll just have to try. Another approach is to not glue the middle bit at all. It will lay down flat when open and then (hopefully) make a little bump when closed. open: === = === closed: ==== |) ====
Thank you Nigel
Wow. My experience with Tandy - here in Calgary - has been quite good. The manager is quite knowledgeable as are the staff. And the staff are encouraged (required) to make the items in the kits and display them and they often have their own items there as well. I will say that I have not been impressed with the quality of the craftsman oak and oak leaf tooling leathers. That said, my first double shoulder that I bought there was excellent. I don't recall what it was though...
I don't think it's a must.
In Nigel Armitage's walletvideo he splits down some leather. http://youtu.be/PMzj3a9nL4Q?t=11m54s What type of splitter is he using? I was considering buying an inexpensive pull through splitter like the cowboy for the same purpose. Do you guys think this would work? Thanks!
