Everything posted by torker32
Adult area on Leatherworker.net
torker32 replied to Johanna's topic in Announcements and Administrivia
Please add me. Thanks -
Well I finally got this glob of glue out of the container. Soaking in thinner didn't do much, but made a mess. So to plan B, Took container and placed in in the Texas Sunshine for several days. Really cooked it good. It became a solid mass of glob with some flexibility. A flat tip screwdriver and some elbow grease, Started at the edges and worked the mass into a ball form. Lifted off the sides and bottom with no residue. Nice and clean inside now. A lesson was learned here. Do more projects, Use different glue container with an airtight lid of some sort. Thanks for the advice guys.
Well, Seems that I got side tracked with other chores around the house. Been busy and have not been out to the shop lately. Went to use the glue and behold, the brush applicator was stuck in the pot. Glue was thicker than dried molasses. Darn near solid substance. ( Barge glue of course ) Could someone please advise me on how to clean this mess. Are there any chemicals that would dissolve glue? Any Help on this matter would be greatly appreciated. First I have to figure out how to get the top off. Thanks. How do you guys keep your glue fresh?
To answer some comments, Thanks for the advice. I made an inside carry holster the other day. I used the method of putting the machine in Rev while the needle was on the up stroke, but still in the leather piece. It did result in a much cleaner stitch. I'll continue to use this procedure. On the comment of using a lighter thread on the bobbin, seems like a good method. I've heard of that before. Might be a time to change. The Tension procedure seems like it would work, because the loops were always on the bottom piece. Will give that one a try. Again Thanks for the advice. ( I'll attach pics next time, Like they say, Pics or it didn't happen.)
I found some interesting sheaths on Youtube for your project. Some of them were very detailed. Hope this helps some.
Thanks for the reply guys. I'll use that method of putting the machine in Reverse when the needle has caught the loop, and has not left the leather piece. Again thanks.
Hello to all, The situation is when locking my stitch. It seems no matter when I use reverse the stitches always seem to get knotted up. I've tried putting in Rev. when the needle is down all the way, Same thing happens. Tried it with needle up all the way, still same results. I'm using Cowboy 3200, 277 thread top and bottom. The results are ugly. Can someone please advise me on the proper procedure for locking stitches. Thanks. ( only on the backside of leather piece )
Welcome neighbor.
I like the design, Nice work, Probably need a microscope to find the errors.
Dad's Genuine Norlund Camp Axe Sheath
torker32 replied to Vikefan's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Looks nice, Simple yet functional, like the lacing. -
My attempt at a Slim Jim
torker32 replied to Mark Peters's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Nice work, I like it. -
Suspenders
torker32 replied to venator's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Nice work. They look comfortable and functional. -
Thanks Guys, Would never guessed it was for removing staple stitches. Guess that piece will go on my oddities shelf.
Hey Guys, Going through an old box with Misc. tools and such. Found this tweezer/cutter/ Don't know what it is thingamajig. I searched on several sites with no luck. Thought maybe for fly tying? It's light duty, stainless, no name or stamp on it anywhere. Does not seem to be any type of scissors?
Good find on the motor, I think the RPM is kinda high for what your intending to use it for. ( Mech. burnisher). The risk of over burnish ( Rough edge, burnt leather) is going to be a little tricky unless, The RPM should be between 1250-1500 according to the more experienced leatherman. Do you plan on running the motor at full tilt? Possibly if you were to use a Pulse width Modulator with an infinite adjustment, This would allow you to use your motor without overheating the unit. The usage of a hardware store bought rheostat switch placed in line wont work for long. This only reduces wattage which the motor needs to run, it strains the coils. $13.00 PWM switch off amazon would ensure your motor lasts for years. It wires in-line just like any other switch. Hope this helps some.
Hello Neighbor, I would like to know if anyone is using an alternative glue pot container? The standard one from Tandy, and other suppliers i've seen used seems a little on the costly side. $30 - $42. The brush applicator in my Barge can busted off. Thinking on drilling hole in top cap and using JB to attach it back. A picture of your container would perhaps give me an alternative solution. thanks in advance.
Paring Knife Sheath
torker32 replied to flux41's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Very nice...- 1 reply
- paring knife
- english
(and 1 more)
Nice work and detail.
Recent work
torker32 replied to thefanninator's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Nice work. -
Very nice Craftsmanship.
Just a picture of my new 3200, Saved my nickels and dimes, collected pop bottles in my little red wagon. Only had it for 2 weeks and have been impressed with it. Haven't owned any machine before this one. Like someone here before said ( Welcome to the Jungle) Thanks guys...
Long wallet
torker32 replied to Windrider30's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
nice work, Think i may make a similar wallet.
