Everything posted by dikman
TT, you'd probably blow every breaker in the neighbourhood when that monster was turned on! Gigi, that sounds simple enough.
Could be a bit tricky to implement, Sticks, but worth trying as basically all it will cost you is time. If it works then fine, if not you (we) will have learned a bit more.
TT has a good point about proffering information that could cause problems for someone who doesn't really understand the subject. If you already have a 3-phase motor on your sewing machine then a suitable VFD (particularly if the price is right) could be a viable solution to speed control. However, as Gigi has pointed out, there are problems making speed adjustments on-the-fly unless you have three hands! It will need work to enable speed control via a foot pedal. If you have a conventional (single-phase) clutch motor then a servo is the only way to go. Fitting a VFD/3-phase setup will be costlier and require additional work, whereas swapping to a servo is a straightforward changeover process. Gigi also mentioned changing her clutch motor to a "normal" motor, but again unless you can pick up a suitable 3-phase motor cheap (unless you have one lying around) then it would be much simpler to just fit a servo.
The 4500 S. E. - "True American style" they say........ I'm a little surprised that the 341 can handle 1/2" of leather but only up to #138 thread, otherwise seems like a nice enough machine.
I will have to disagree with you on this one, Sticks. My first machine had a clutch (of course) which scared the daylights out of me the first time I used it!! I made a larger handwheel pulley and made a speed reducer (modified a couple of times) in an attempt to control this beast, all to no avail. Yes, they slowed it down some, but I still had issues, and without fitting a gearbox(!) had reached the limit of a mechanical solution. After reading about servos here (and finally figuring out what they were talking about) I bought one from Aliexpress, Chinese company, of course but with a warehouse here in Australia. Cost was $250 Aus, about $220 US. Best thing I bought, in fact I bought two more! No problems so far, and the control it gives me is awesome. There is no way I would spend $1000 on a servo, not for my needs (and I'm pretty sure many will agree, it's a bit over-the-top for a hobbyist).
Yeah, I can see where that can be a problem (I'm sort of rural but close to the city, so almost the best of both worlds - almost). I forgot to comment on Mr. Gibson's excellent blog, much truth in there.
I'm with you, Big Sioux. I love music and when I'm casting boolits I'll play some nice easygoing instrumental/orchestral stuff but when I'm working with the leather - nothing. It's too distracting because I listen to the music, rather than concentrating on what I'm doing (and as you know, one mistake can ruin a project!).
Pfaff are nice machines, but be aware parts can be expensive.
I do lots of that too . I think you'll find your setup is perfectly adequate without a speed control.
" Apparently servos are all pretty much generic in their design." While this is generally a true statement, design does change, for example the optical operation you refer to appears to be an "older" design and they are using a different design now where the optical gradient isn't used. None of my three units has it, and it seems that once one changes the design the other makers follow suit. The best thing with a servo is to experiment with the start speed and top speed settings and in my case they appear to be interactive to some extent. Also, if you want to maximize the torque at low speed then fitting a speed reducer as well is highly recommended.
Just got back to this post. Your setup looks good, similar to what I use. I'll bet you're really enjoying burnishing now!! As for the servo motor you mentioned, there's lots written about these in the Sewing Machine section. They are generally used to replace the large, heavy (and fast!) clutch motors on industrial sewing machines. I have 3 spare clutch motors that I'm trying to think of a use for! Would be great for a burnisher (bit of overkill, though) if I had somewhere to set one up. If I can sell one of my bikes then I may have room in my garage to make a decent burnishing stand. Something TT said has got me thinking, i.e.mounting the motor vertically with a table around the shaft to act as a guide. Might also be possible to mount a sanding drum in place of the burnisher to give nice square edges.
I guess it all depends whether variable speed is required.
I assume you mean 1181? Anyhow, pretty well all modern (and some not-so-modern) machines that use clutch motors have a standard 3-bolt mounting. It's become a de-facto standard for mounting motors, and all servos should use the same system so any servo should be a bolt-on replacement. Any servo will give you the ability to set the speed, the one Wiz refers to is probably the easiest to use as most others require setting the speed parameters via push buttons and a digital display. I'm not sure what you mean by "small one"?
- 4 replies
- servo motor
- 1811
(and 1 more)
And that, my friends, is part of the problem! When I get interested in something I have a tendency to collect "things". Space has also become something of an issue, so the little voice is saying to wait - until the right one comes along. While it would be nice to have, it's not going to be the giant leap forward that I need/want.
The big worry is where it actually went - you don't want to run the machine unless you're sure it's not hiding inside, waiting to jam/break something.
Thanks MADMAX, you came up with better stuff than when I searched! After reading it all my feeling is that while it can handle slightly thicker material (and slightly thicker threads) than my existing machines there's no huge advantages to be gained in buying one (unless it is real cheap!). I think if I intend getting a bigger machine the next step has to be a 441-type.
For the reasons Tom has stated, I use speed reducers with two of my servos but on the third (the Pfaff) I fitted a much larger pulley in place of the handwheel, which gives the same effect as a speed reducer. Top speed is severely reduced, but that doesn't matter as I'm only interested in slow speed control. As for the motor you linked to, it's pretty typical of most Chinese sewing machine servos - motor and mounting plate, linkage to the foot pedal and control box. The major difference between models/makes is usually how the settings are changed, some use two buttons, some use four. No reason that it shouldn't work. One difference that I just noticed is that it has a 12 mm shaft, most that I have seen have 15 mm shafts, no big deal but 15 mm seems to be the de-facto standard for shaft/pulley sizes. If you buy it make sure, if possible, that it is fitted with the smallest pulley size you can get (usually 2"/50 mm).
Yeah, you're probably right. Plus the grind on every needle would have to be identical or changing needles could be a problem. On reflection, perhaps not one of my brightest ideas......
I know it can sew plywood (!) and horse rugs (ughh!) but the heavier thread could be useful - if I can find heavier thread. Given that it's not a compound feed, are there any potential issues with sewing veg. tan leather? What sort of thickness can it handle? Are spare feet readily available? Sorry for the questions, but searching mainly said that it can sew plywood and horse rugs and so far I couldn't find a lot specific to leather work as we do it. I gather that it's a fair brute of a machine but how would it go sewing holsters?
Given the machines that I have, what advantage, if any, would there be in buying a 132K6?
You could try grinding a flat on the needle?
Martyn, of course, is quite right. I don't groove my holsters so I didn't even give it a thought. Not using grooves makes it simpler. Try using the machine like I said, to pre-punch the holes. If it doesn't work then use your punch. Either way do away with the Ezyawl, get the gear you need for saddlestitching and do it that way. I think you'll be pleased with the results. (Al Stohlman's books tend to emphasize grooving so many people seem to think that it has to be used. It has its place, but not on everything).
Axeman, there have been a couple of threads about these Chinese machines. The larger one sounds like the one you'll need as the smaller one is best with #69 thread (it may handle #138, although the bobbin is very small so won't hold much of that thread!). Darren is certainly the one who can best advise on these wee beasties. As Martyn said, you can't beat a good saddle stitch, which is how I still do my holsters. Have you tried punching the holes before grooving the back? That way you may be able to tweak the groove to line up with the holes. The other thing you could try is using the machine you have to punch the holes in the leather first (no thread, just the needle). I do this with some of my hand stitching as it gives a nice even spacing and makes it much easier to get the awl through when saddle stitching. Without thread loading the machine down they can punch through leather fairly easily.
Small footprint cylinder bed machine table
dikman replied to jacobkoski's topic in Leather Sewing Machines
That is what I would call a minimalist table! -
New to industrial sewing machines Juki LU-562
dikman replied to jshep's topic in Leather Sewing Machines
Instruction manual - https://www.manualslib.com/manual/790496/Juki-Lu-562.html
