Everything posted by dikman
Nice carving. Looks much nicer than roses!
- 6 replies
- 45
- magazine holder
(and 1 more)
I must admit if I saw that I'd probably remove it too! Pipe cleaners....who'd of thought?
Cylinder arm machine for sewing leather handbags
dikman replied to LearningLeather's topic in Leather Sewing Machines
Agree with showing the location (personally I think it should be compulsory). I bought a Pfaff 335, which as Constabulary said was set up for edge binding. It can be used for normal stitching as is, but isn't ideal. It cost me about $200 to get all the bits I needed to convert it back to a normal feed (plus a bit of work). Another thing to consider is the motor. The chances are that the Pfaff will come with a clutch motor, which is not the best for a newcomer to start with (I changed mine to a servo = extra cost). The chances are that the Cowboy will come with a servo motor which will give you much better low speed control. If you can afford it I'd go with the Cowboy. Parts will also be cheaper and easier to obtain. -
Yes, forgot to say - good idea.
A chrome-painted sewing machine - very funky .
Ruger Super Blackhawk Cowboy Holster
dikman replied to SLP's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I was wondering that myself..... -
An elephant in the window
dikman replied to OLDNSLOW's topic in Gun Holsters, Rifle Slings and Knife Sheathes
oldnslow, I'm not quite sure what the problem is, I reckon it looks great. -
I just had a look at that link - are those feet gold-plated??? The prices have very impressive numbers attached to them!
I thought the same thing as Mike but couldn't put it as elegantly. My limited experience is that dying the leather can make it stiffer and tougher to sew. I was going to suggest increasing the needle size too, but again Mike beat me to it.
Now that is very nice! The sort of thing that appeals to me, dressy, but not enough to detract from the understated simplicity of the design. I note, though, that when I used British Tan it came out redder. -
As a hobbyist you're facing a common dilemma - should I buy a machine that may take a long time to pay for itself (if at all)? The need to sew holsters immediately eliminates many machines, as you're probably looking at a Cowboy 3200-type machine as a starting point. (While I have several machines, none are suitable for holsters (ok for belts) so I still hand stitch them).
What he said. If the machine isn't manufactured with a reverse lever then you can't sew "backwards". The usual method in this case is to turn the material around, if possible, and sew a few stitches then turn it back and start sewing normally. This will lock the stitches. As to which motor to buy, yes, that can be confusing with the choices out there. A 500w (3/4 hp) should be more than adequate for your needs. If you have any qualms about buying one from China, via ebay, then I suggest you look at the sponsors/vendors on this site and buy locally. You are lucky, in the US, in that you have dealers who sell these motors at reasonable prices. This will at least give you peace-of-mind and they're not that much dearer than buying via ebay.
With a LOT of practice you could learn to feather the clutch and control the speed somewhat, but for newbies these things are notoriously difficult to master. A "speed control switch" isn't really a viable option, the usual way to gain some control is to fit a speed reducer pulley setup or, and this is the best way, change the motor for a modern servo motor which will give you much better speed control. Photos are always a good idea as I'm a bit puzzled by what you mean by the clutch material being screwed to the pulley.
What type of Servo Motor and Reducer for a Consew 230?
dikman replied to MaryGladys's topic in Leather Sewing Machines
MG, all the motors I've seen (so far) have the same mounting hole pattern - 2 bolts at the left hand end and one bolt at the right. Check the new motor first and make sure it's the same. No big deal if it's not, but you'll have to drill new holes. If you can get someone to help you then you can probably remove the old motor without flipping the table. Remove the belt and all the electrical bits and let them hang down, loosen the bolts and while someone is holding the motor up remove the right hand bolt, the motor should then slide out from the other two bolts.- 28 replies
I just got around to watching the video, and yes, I wouldn't last long with that infernal beeping! That's really bizarre.
That's good. My homemade burnisher (a bit like TT's) is attached to a grinder motor that runs at 3450 rpm and works fine.
That speed control mentioned earlier may not work with your motor. That control is meant for brush-type motors (as used in most power tools, hence their reference to a router). Most AC motors are induction types and if you use that controller it will probably go poof!
Thanks Ralf, if so seems pretty expensive for a speed reducer?
Darren, thanks for the comment on the serial numbers, all good info.
A very interesting setup. I have a vague recollection of seeing something similar to that small cylindrical device but I can't remember! My guess is a small motor to drive some sort of adjustment inside the main motor? Anyhow, my recommendation, with something that old, is don't touch it! Generally the insulation on old things like that will be deteriorating and will fall apart if moved too much. That servo JLS has should suit you fine and you'll find the speed adjustment knob will be easier to use than messing around with the settings like mine has. Looks like a good deal. Fit that and it'll be like a new machine . A couple of photos of mine, which is a fairly generic China made servo (I have three of them and so far had no issues). Two are 500w and one is a 750w, and to be honest the 500w has more than enough power for my needs.- 28 replies
An extra 500 Euros for a "tuned" servo motor? Wonder what an earth a "tuned" servo motor is, first time I've heard of that in all my searching.
Well, he's had many years using it so it's no wonder he can handle it. My first effort with a clutch motor was scary, to say the least! I quickly realised that it wasn't going to work for me. There are two or three vendors on this site who will no doubt be able to help you out with supplying a servo motor (I'm assuming you don't want to to order one via ebay/China). The controller is simply the device that controls the servo, I won't bother you with the technical details.Some servos may be an all-in-one unit with the motor, some may have a separate controller and motor, but they all do the same thing. A needle positioner allows the machine to stop with the needle either up or down, depending on the setting, when you take your foot of the pedal. I don't think too many on here use them. I bought one but decided I didn't really like it, I'm sewing slow enough that's it's easy to stop the needle just where I want it. Fitting a speed reducer as well as a servo will allow you to get very slow speeds with lots of torque, but may not be necessary for your needs. Start with a servo first (easiest) and fit a speed reducer later if you think you need it.- 28 replies
