fredk
Contributing Member
Everything posted by fredk
  1. No, I do not think you will be able to turn it . . . . unless you totally soak the leather with water
  2. I bought my 99 just for putting holes and sometimes thread through 1mm leather. I'll not say 'sew' as the job isn't actually sewing The main reason it was chosen was for the non-stop stitch spacing, ie variable spacing without 'stops' at different settings
  3. frayed knot, never took photos of them. I gotta make a few bags soon. Maybe I'll take photos as I do
  4. I do one style of book cover. One is a cheapie made in upholstery grade leather and is just glued together, for the other I use 2.5mm [afair] 'belting' leather. That one is much stiffer but not unduly so The cheapie, the leather is very soft and pliable. It relies on the stiffness of the book covers; [the same book cover, its the camera exposure which makes it look different] The 'expensive' one, same basic pattern as the cheapie but a bit different with pockets in the front & rear flaps and I use a pen to 'lock' it Absolutely no problems with this one opening and closing. No self-closing, no cracking or wrinkling of the spine/bendy bit I think it comes down to your choice of leather and the 'temper' it has. I choose my leather for a project according to which leather will work best without me having to fight it
  5. Trilby = looks like a fedora but with narrower brim and the turned up rear of the brim and slopey look to the crown If you have to adapt a fedora pattern; just reduce the width of the brim, [down to about 2 or 2.5 inches ], and wire the edge so you can turn it up at the rear. Narrow the top of the Crown piece and reduce the size of the Crown former, this will give the crown that sloped inwards look
  6. I would describe that hat as a Trilby
  7. There be a couple of fedora type on this https://tandyleather.com/blogs/leathercraft-library/2662-leather-hat-pattern-pak?_pos=3&_sid=63393a5f8&_ss=r dieselpunk does a few patterns, eg; https://www.etsy.com/uk/listing/628831400/leather-hat-pattern-diy-pattern-hat-diy?click_key=3192e9a2829f90051e7f7d3184613984aa5867f2%3A628831400&click_sum=77f64076&ref=shop_home_active_168&pro=1&sts=1 or this one from another seller https://www.etsy.com/uk/listing/976301141/leather-hat-pattern-digital-pdf-template?ref=internal_similar_listing_bot-2 I have the dieselpunk one. I dunno if I can share it with you.
  8. Bic pen spring = too small in diameter, but would do
  9. Same thread
  10. All that spring does is to keep that lever over into its slot. My spring isn't geat and its only between the side and the end of the lever, When I rotate the lever the spring compresses slightly. It doesn't and wont affect sewing at all
  11. I think I may have figure out what that spring is for; That bar which the big screw goes thru - you lift its end and move to the front of the machine. This to get the bobbin case out. Under that lever is a thin metal spring type thing which bears on the bobbin case. The coil spring seems to bear on that to keep it tight on the bobbin case edit; nope, I'm wrong. All that spring does is to keep that lever over into its slot. My spring isn't geat and its only between the side and the end of the lever, When I rotate the lever the spring compresses slightly
  12. press the bobbin ejection lever and see if springs back down. I turned my machine a good few times [I have it converted to manual] and I could not see anything happening to that coil spring edit; I checked my manual. Nothing about the spring. But it says, never loosen that big screw. Doing that will alter the clearance of the thread between the bobbin case and the bobbin position bracket
  13. This is mine; As far as I can see that coiled spring does not act on the bobbin ejection lever
  14. Why do we use Sham Poo to wash our hair? Is Real Poo not as good or too expensive?
  15. I don't have the red fuzzy but I do have a coiled spring there. Almost looks like yours is detached or broken. I've no idea what it does or what its for though
  16. Good one. Your tooling is fine and the colour is nice Did you go by a supplied picture or something? to match the old one? Ach, sure you have a heart of gold and the faeries will always smile at you PS. I hate lacing too, I always try to avoid it
  17. Ornamental picture frame corners or box corners Examples; https://www.ebay.co.uk/itm/163857612955?hash=item2626acc09b:g:lgoAAOSwyRNdePnc https://www.ebay.co.uk/itm/164169067027?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20200818142055%26meid%3D35e844301b78429cb361ea5359562c0a%26pid%3D101113%26rk%3D7%26rkt%3D12%26sd%3D174909568862%26itm%3D164169067027%26pmt%3D0%26noa%3D1%26pg%3D2563228%26algv%3DDefaultOrganicWeb&_trksid=p2563228.c101113.m2108
  18. I never ever use any thing like just nfo on my book covers. I've had experience of this coming off on paper. I do use a nfo/wax mix to polish them but I only use a real minimal amount Actually, you not really want the book cover to be too pliable. A stiff cover is better imo
  19. Here is what I do 1. on both the front & rear panel I glue on slightly stiff coloured lining leather - but 2. on the front panel I just glue around the edges and leave a middle section unglued. I also leave a long strip along near one side unglued. These have been decided before hand and marked. At the top of these patches which are not to be glued I cut a slot at the top of them. Thus when the lining is glued in these form a pocket and a slot for a pen or pens 3. on the rear lining I do much the same but I cut a wider slot and glue a zipper over that slot, so when the lining leather is glued in that forms a zippered pocket. 4. Sometimes I've mixed these, with a small zippered pocket on the front as well as an 'open' one and the pen slots on the back panel with an open or zippered pocket or even pen slots on the gussets The glued edges are caught up in the main assembly sewing of the bag
  20. All my machines use the same bobbin [15 class] so I use a cheap Singer clone machine for bobbin winding. I got the machine in a charity [thrift] shop for £10 as a 'non-runner' [needle was down, bent and jammed in the dogs]
  21. Thanks, gotchya. Its a fine bit of using what you have to the mostest degree
  22. I use an ad-blocker so I don't see adverts on any forums. I just turned it off for this site and the usual normal adverts have appeared
  23. Just cut that bit of bashed up thread off. Its obvious that its not needed. The wing nut can be replaced with a thinner lock nut There seems to be some hammer-bashing damage to this tool
  24. Are you sure its A4? It looks more like A3 to me
  25. If you can get that wing-nut off the end, then the roller unit I'd dunk into some hot oil for a while. Really hot oil, either clean engine oil, diesel, home-heating oil or even home cooking oil. Keep the oil real hot. Eventually the metal will expand enough to allow the oil to get between the bar and roller and allow you to separate them or, is that wing nut just tightened up too much?
