Everything posted by fredk
I disagree; the hole is always best to be oval. When the buckle 'prong' goes into the hole and the strap is pulled down it forces a round hole to become oval. This puts strain on the hole and becomes unsightly, but if the hole is oval to start with then this doesn't happen and the strap lies down more neatly I have, did, replace many vintage car bonnet straps because the round holes had torn the leather trying to make the holes oval. Mostly the straps were still serviceable but had to be replaced because of the mis-shapen holes and the damage around them
Benny Hill was a great comic of his time. We all laughed at his jokes and antics We bellowed with laughter and in this he wore Lederhosen probatur quod quaeritur
@MikeRock, for you
Well, I have a sort-of beader. It works I made the working end at a slight angle. I thought it would be easier to work Total width across is about 6.5mm (1/4 inch), with the bead about 4mm The test leather is only 2.1mm (5 oz ?) thick. The beader needs running to and back, going deeper on each run. I went as deep as I could on my test piece but I reckon I would get a better rounded bead on thicker leather I might try to make a smaller sized beader
In the past I bought cut straps from Le Prevo. If the thickness and width was not 'stock' they cut the straps for me, although the length was a bit more normal. I needed the straps for bonnet (hood) straps on vintage cars and the straps had to be a regulation width and thickness
Years ago, a friend in the medieval presentation group I was in wanted to try to make shoes. Being on a tight budget but being clever he obtained a pair of boot style shoes about one size smaller than his regular fit. Then he removed some of the insole and poured in thick cement. almost concrete. When that had set he cut away the cheap shoe, covered the cement cast with scraps of thick-ish leather, obtained from me. Extra thick layers of leather on the sole area. He made several pairs of medieval shoes on those cement/concrete lasts. His report was that the next time he would go down 2 sizes for the cast and cover the cast with strips of wood then cover that in leather. I don't know if he ever did that. Only real downside was that the cement casts were very heavy. Oh, btw, as the cement hardened he inserted an iron bar, about 12 inches long, so about 8 inches stuck out the ankle bit. With this he could hold the last in any vice of his choosing. And the cement cost him nowt as he was working on a building site and the boss allowed him to have some. After this my friend got the nickname 'the gangster' as he was making Chicago style concrete boots! I sometimes have thought of copying his idea
@Aven you need to do it as well,
That flower one on the right, using the dragon scale stamp, is much better than the earlier one, which I guess was just a try-it-out & see (?) So far the only alternatives I've done (photo to follow) is to use a long thin beveller and a seeder to make a !
@Plumejason you don't say where in the world you are thus its hard for us to direct you to places where you might get fixed asset supplies. If you are in the UK or Europe, go to antique or jumble shops. Not antique dealers though. Try the wee back-street 'antique' shops just about every tourist orientated town has numerous of
That looks nice. Its colouring matches the hat rather well. Not too ostentatious
Start one and we'll all follow
An archery type joke. You'll need to check English history for this if you don't know it already Harold Godwinson, sometimes called King Harold, was getting his army into place to fight the Norman invaders led by Duke William the bastard As Harold was getting ready a giant of a karl carrying four long spears approached and said ' Lord, I claim the right to fight by your side, in your bodyguard. I fought alongside you at Stamford Bridge 3 weeks ago. There I killed at least 50 of the invaders with my trusty spears. And my father has fought in the Royal bodyguard afore me' 'Let me see what you can do' says Harold The spearman takes out an apple, gives it to an axe thrower and tells him to throw it high, far and as fast as he can. As the apple flies through the air, high and far the spearman throws one of his spears after it. The spear strikes and slices the apple exactly in two. 'Impressive' says Harold 'you have earned the right to fight on my right side, close by me' Then an axeman approaches. 'I too claim the right to fight by your side Lord, I too was at Stamford Bridge and killed many invaders. I have fought in the Royal Bodyguard for many years, as did my father and his father before him' 'Let me see what you can do' says Harold The axeman takes out an apple, throws it high into the air. As the apple flies through the air the axeman cuts his axe blade, like a flash of lightning, at the apple. The apple comes down in thin neatly cut slices 'Impressive' says Harold 'you have earned the right to fight on my left side, close by me' Then a very elderly archer approaches. He says 'I too claim the right to fight by your side Lord. I didn't manage to get to Stamford Bridge. T'was a bit too far for me arthritis. but I have fought in the Royal Bodyguard for many years, as did my father and his father before him and his father before, all the way back to King Alfred' 'Let me see what you can do' says Harold The archer takes out an apple, gives it to an axe thrower and tells him to throw it far and as fast as he can. As the apple flies through the air, fast and far the archer takes an arrow and lets fly. The arrow misses the apple and hits an ox pulling a cart. The archer gets another apple, does the same, the arrow misses and hits the ox cart driver in the arse. Just as the archer was getting out a third apple - ' Enough! Impressive' says Harold 'you have earned the right to fight with the other archers on the left wing' As the old archer walks away, happy that he impressed the King, King Harold turns to his chief Huscarl and says 'Alfric, please keep that bluddy old fool away from me! He'll have somebody's eye out!' Here we see the proof; the spearman, on the left of the picture with the white shield, the axeman getting killed on the right of the picture and King Harold with that famous arrow-in-the-eye. But who shot the arrow??
Interesting. An off-side look to what a stamp can do
Thats what we call a 'Triggers Broom'. From this comedy show, Trigger is the road sweeper with the medal,
Thats what I mean by thick
Not worth any more than £10, and that's just so you can pull it apart and use the bits as patterns for constructing a new one. Not even RE-constructing 'cos it sounds like there isn't anything TO RE-build ALL the leather would need replacing, almost all the wood needs replacing, the metal parts are missing so they need fabricating. Its not even a 'Triggers Broom' Best place for this bellows is in a non-working historical display in a museum somewhere
Another Give away Holster to a Veteran
fredk replied to Bert03241's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Nice, simple looking. He will like it You'e a kind hearted crafter to do this for him -
I think its real enough but very old and very dried out
@Tequila - two questions; 1. what weight/thickness of leather would you use? 2. what width of rounded bead would you use? I want to try and match your requirements to see if miine works
Simples. If I have the time I'll make a nylon one over the weekend and see how it works
Yes, but I reckon it would need to be quite thick to with-stand either a thump from a mallet or pressure from a press
What do you mean by a 'bead' ? I think I and maybe you have two different ideas of what a 'bead' edge looks like You can make a push beveller for a swivel knife. If you cut the end right you can have a rounded top 'bead' These are simple bevellers I made out of nylon rod for my swivel knife; The materials cost me less than $10 and I have lots left to make more. They took only a short time to make I might go and make a 'beader' now !
I only, or did only, shoot traditional Long Bow. My prefered wood for arrow shafts is Port Orford Cedar or Ash. Ash is now hard to get in the UK because a disease has wiped out the ash trees. Also; I have a long draw so standard 32 inch shafts are too short for me. I used to get shafts made by a specialist who made mine 35 inch long in P.O. Cedar, made them for my bow strength and made the shafts with the traditional belly and not dead straight. I think that can only be done by hand or by specialist machines. afair I used to pay about £24 for 6 for the shafts. I added in buffalo horn in the nock and of course whipped on goose feathers. I never had to buy many during a year as they rarely broke, got damaged or lost, but knicked ? (stolen), er occasionally
