CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. Hope this helps you. Bob
  2. I've worked on alot of this model over the yrs & they won't handle leather very good,they always seem to have a weak,slow running motor. It is hard to change it too.Look for the old black Singers w/a small can type motor & the bobbin goes in underneath,these will sew someleather & take 46 & even # 69 thread.
  3. The needles probably have a twist point on them,look @ the point & you'll see that the point runs @ an angle to the stitching line causing this. A diamond point runs in line with the stitching & will give you a straight stitch. Some people like the zig-zag look.It looks hand stitched that way.
  4. James, The 211 would make a great machine for chaps & lighter leather.The 188k1 is more for sewing clothes & thinner stuff. Good Luck & if you have anymore questions let me know. Bob
  5. It's a 9/64-40 that you'll have to get from a sewing machine place. Bob
  6. The best thing to do might be just take the head off the stand & take it in they'd be tack welding on the top,sure it all comes apart but you'll probably have less trouble in the log run.
  7. It's hard to tell from the pic because when I click on them they are to big to get any detail,but it looks like the washer has come undone from the collar underneath,originally they were just peened over & maybe somebody worked on the machine in the past & didn't repeen good enough,I would push the lower part back into the upper part so it doesn't have any play but still turns around & just tack weld it in 4 spots. They call these machine shoe patchers for a reason,that's what they were made for,BUT I know alot of people have done some fantastic sewing on them & as already mentioned,some tape,rubber or grind off the teeh will stop the marking but will also stop the feeding of the leather making you have to push it through.
  8. The big difference is the 225 has a small bobbin & no reverse & all 563 have a big bobbin but not all 563's had reverse. Otherwise they both will sew the same thickness.
  9. Just thought I'd mantion that all the parts are still available for these machine & it would be a great machine f/Chaps,it'll use 46,69 & 138 thread.
  10. Hello James, Yes,it has a walking foot & we have all the parts in stock for it. Good luck, Bob Kovar
  11. I'll agree w/Art that for holsters you might be pushing it some but I have alot of customers that use the heck out of the 31-15 making chaps & sewing boot tops.I have a roller & a nylon foot that will help the leather feed through & almost every part is still being made for it too. Put a DC Servo w/a gear reducer on it & you might be suprised how nice a stitch it'll make. Bob
  12. I have a Singer book which lists all the models of these 45B machines,I would scan it but it would probably break the binding so here's the list of models. 45B6BT=bottom feed ,flatbed 45B6C= same as above,cyl.arm 45B7BT=needlefeed,flatbed 45B7BC=same as above,cyl.arm 45B8BT=walking foot needlefeed,flatbed 45B8BC=same as above,cyl.arm
  13. I feel that when a machine has alot of rust & nicks in the paint that after all the work & parts we put into them that if they don't look as nice on the outside as the inside that we might as go ahead & paint them. Usually most 29-4's are sp old that they need paint,now if you just want to keep the machine & use it then it'll get nicked up anyways,so I guess it's up to you. Bob
  14. The 45B is a Consew 756 & it should sew up to 3/4" & has a walking foot needle feed ,BUT there isn't any other feet or needle plates available for it other than standard.It takes the same shuttle & bobbins as 441's & Adler 205-270's Bob
  15. We sell the GA-5 & have alot of the parts for them ,feed dog will fit ok,the needle plate screws don't lineup so they need to be elongated alittle. As for what goes in those screw holes I've worked on alot of 45's & never seen them holes before,if they are factory(which I doubt) maybe it had some kind on race cleaner on it something like a piece of metal with some felt on the end. Alot of home machines have them.
  16. Ruus, Bill brought up a good point,dirt,it is just like grinding your machine & I have some customers that won't sew blankets anymore because of it.They got tired of buying parts,it seems like no matter how much oil they put into the machine parts would wear pretty quick,even though they were washed. Bob
  17. Most threads will require a size 22 needle to sew#138
  18. Your machine just has a bottom feed that pulls the material through,an uph machine has a walking foot & needlefeed on it where the needle,center foot & feed dog all 3 go back as it's feeding ,I have sewn 2" of foam on this type of machine when I'm demostrating them & they pull it through w/o any problems.Since the needle is in the goods when feeding back it cannot slip while sewing.
  19. Hello Shooter, you mention that it isn't sewing correctly at all,so what is it doing?
  20. I've done alot of cast iron repair & like to weld using nickle rod,grind & preheat,I have seen alot of machines bazed either way if done properly should hold. I do have some bobbins in stock & will let you know tomorrow what I have.
  21. What else did you do?Did you unthread the needle to wind a bobbin or did you change the needle?
  22. The best lube is regular clear sewing machine oil,do not ever put grease on a roller it'll build up in front & cause it to stop turning & make a flat spot. We have the round leather belts in stock for it. Here's some info on the 29's which is what yours is it just has an open back,different bobbin winder & hand lifter & handwheel are different & the top arm is smaller which they improved on the newer 29's with the added strength of the bridgework. They were also called U.F.A. for Universal Feed Arm
  23. I think those suspenders you sewed are close to the max for this machine,the largest thread you can use is #92 in it. Bob
  24. Jim, We have a D.C.Servo motor that has a built-in reducer that should mount in the same 3 holes that your table has for the 3-phase motor for less $$ & it'll work better because when you have a motor & reducer separate you have to slide the belt off to tilt the machine back. Let me know if you have anymore questions. Thx, Bob
  25. A 29K in good shape should use up tp #138 w/a #22 needle.
